Adding an Extension to Photorec - Begginer
MeloB
#1 Post by MeloB »
I am desperately trying to retreive some lost videos from my Panasonic camcorder and Photorec found and recovered one in .m2ts. The other ones, however, with .mts extensions can't be found. I can't figure out how to add the extension in fidentity after multiple attempts following instructions. Can't figure out where the starting point is, don't know if the Terminal (macbook pro) is the right place to to be entering the commands.
Photorec.sig doesn't exist either
Please help and be as detailed as possible, as I have no experience with programming.
Thanks,
MB
s73v3
Re: Adding an Extension to Photorec - Begginer
#2 Post by s73v3 »
Hi ,
I know you must create a photorec.sig file in the photorec dir. Then enter the MTS signature in that file.
Try posting the first few lines of hex that you see in the MTS file. I will try to work it out for you. However I'm stuck at a similar point. I hope helping you helps me.
Cheers.
MeloB
#3 Post by MeloB »
I created the file photorec.sig but how do I find out the .mts signature? Also, in the directions provided on the site it says:
Run fidentify with a file sample in parameter:
[kmaster@adsl ~]$ fidentify /home/kmaster/src/testfiles/sample.pfi
/home/kmaster/src/testfiles/sample.pfi: unknown
How do I do this? When I double click on fidentify and run it, it goes through my entire hard drive. I am totally lost at this point so any help would be appreciated.
Have you try using the m2ts and ts file famillies in FileOpts ?
Chili
#5 Post by Chili »
Somebody can help possibly...
Accidentally I deleted with bad rsync argument on my Readynas (v1) 6 dmg files and did not write any new file to the disk.
How to make the photrec.sig file? I want' search only apple dmg files on the disk.
Thanks your advice!
