recover file from a ps3 hdd that wont start
chrisa123
#1 Post by chrisa123 »
HI!
how can i use photorec to recover lost pictures on a PS3 hdd that wont start on my ps3?
i`Ve used a isb cable to connect the hdd to my laptop. but win 7 won`t find it.
but photorec did.
i`Ve startet photorec. and when its done the files that was stored in my pc was ( a .jsp file, 2 gpg file and a mplayer audio file, and a xml file named "report"
what are i supossed to do with those files?
i do not speak english good, but hope someone understand.
regards Chris
chrisa123
what is a gpg file?
#2 Post by chrisa123 »
i`Ve retrived som files from a ps3 hdd. but i only got 2 gpg files 1 12gb and one in 8gb.
i also got an mplayer aduio file and a .jsp. those are about 100kb.
but i don`t know what to do with the gpg files???
anyone?
Re: recover file from a ps3 hdd that wont start
#3 Post by cgrenier »
The recovery has failed, the recovered files are false positive. The problem is that ps3 harddisk are encrypted.
It's possible to disable the encryption but you loose your data, I don't know if there is a way to decrypt a PS3 HDD...
