ext4 drive unmountable after windows install
talormanda
#1 Post by talormanda »
I installed windows 10 to update my bios, this was successful. After going back to Ubuntu MATE, my secondary 3TB hdd somehow gained a NTFS partition on it, and the other partition was marked as "unallocated". I deleted the NTFS partition and now I am left with a single ext4 partition that can't be mounted. I am not sure what happened or if I am able to get this mounted again to get my data off. I am new to all of this and looking for a place to start. Is it possible the partition table was simply damaged? I did not format or write to this partition when I installed windows.
Re: ext4 drive unmountable after windows install
talormanda wrote: 08 Aug 2020, 00:26 I installed windows 10 to update my bios, this was successful. After going back to Ubuntu MATE, my secondary 3TB hdd somehow gained a NTFS partition on it, and the other partition was marked as "unallocated". I deleted the NTFS partition and now I am left with a single ext4 partition that can't be mounted. I am not sure what happened or if I am able to get this mounted again to get my data off. I am new to all of this and looking for a place to start. Is it possible the partition table was simply damaged?
No. An additional NTFS partition is not created by a damaging operation.
A good place to start is:
and
#3 Post by cgrenier »
Run as root "fsck.ext4 /dev/sdb". What is the output ?
talormanda
#4 Post by talormanda »
cgrenier wrote: 08 Aug 2020, 11:57 Run as root "fsck.ext4 /dev/sdb". What is the output ?
e2fsck 1.45.5 (07-Jan-2020)
3TB: clean, 89101/183148544 files, 399232435/732566646 blocks
I must also note that since this post, I deleted the NTFS partition and now it is one big partition again. It shows there is 1.2TB free, but when mounting, it is empty. If I do a "quick search" on it, I can see the files (in a folder called "lost+found"). There is also a lot of files listed in red text. Unsure what to do at this point. It looks possible to copy the files, but I have no idea how to select only what I want (unless you have to do it one by one?). Or can something be done to the files to become visible again when I mount it?
#5 Post by recuperation »
talormanda wrote: 09 Aug 2020, 17:04
Another NTFS partition? There is no NTFS partition on the pics you posted. You were talking about one NTFS partition in your first posting.
[...and now it is one big partition again...] ??? And what is it?
Please specify, what "it" is.
If files can be recovered the keys for recovering are indicated. Did you see them?
