Unable to recover Partition but can copy files - Linux
christobal
#1 Post by christobal »
Hello!
In my rush this morning I managed to delete my storage/backup drive. I am able to locate it and browse/copy files but after writing it does not show up post reboot.
Here are pictures of the steps I take, any help would be much appreciated :)
https://imgur.com/a/okGdEUT
And this is the log I get:
Disk /dev/sda - 1000 GB / 931 GiB - ST1000DM010-2EP102
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
 1 * Linux                    0  32 33 121601  57 56 1953521664
block_group_nr 1
recover_EXT2: s_block_group_nr=1/7452, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 244190208
recover_EXT2: part_size 1953521664
Filesystem created: Mon Oct  1 22:23:59 2018
     Linux                    0  32 33 121601  57 56 1953521664 [Stuff]
     ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 1000 GB / 931 GiB
   * Linux                    0  32 33 121601  57 56 1953521664 [Stuff]
echo "0 1953521664 linear /dev/sda 2048" | dmsetup create test0
 1 * Linux                    0  32 33 121601  57 56 1953521664 [Stuff]
write!
Need to fix
Re: Unable to recover Partition but can copy files - Linux
You are better off uploading images here. Your pictures will disappear at some time in the future and this posting won't help others anymore.
You did not run deep search.
Unfortunately I have no experience with file systems from the ext family.
But there is a hint in the log file:
