Help with my MyBook
BlackWitch
Help with my MyBook
Hi there.
I have a WD MyBook. It's a Raid unit with x2 1TB hard drives.
Yesterday, when I plugged it in, I got a lovely error... "This drive needs to be formatted" or something similar.
So I found Testdisk and started the tutorial. But I'm a little unsure about what to do next because I'm not sure if my drive is any different to a normal HDD.
I'm currently scanning my drive as I type. Here is the log so far (below) but it's just thrown up this in testdisk which hasn't been written in to the log yet:
HPFS - NTFS 0 65 2 121600 108 28 1953506736
Check FAT cannot read FAT boot sector
Invalid FAT boot sector
0 D FAT12 343174 142 62 521156 85 54 2859710987
Could someone guide me to what to do next?
Many thanks
Current Log
Thu Aug 20 08:50:11 2020
TestDisk 7.2-WIP, Data Recovery Utility, August 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=2000392994816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000392994816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=308679802880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=1000195448832
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD50 00BEVT-22A0R, S/N:W -DXW1C5AM02812, FW:01.0
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243200 255 63, sector size=512 - WD My Book, S/N:WU2Q10140339, FW:1015
Disk /dev/sdb - 2000 GB / 1863 GiB - WD My Book
Analyse Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243200 255 63
Invalid NTFS or exFAT boot
1 * HPFS - NTFS 0 32 33 121600 75 59 1953506736
Many thanks
Current Log
Re: Help with my MyBook
Try TestDisk, Advanced, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit and restart your computer.
BlackWitch
Hi.
Many thanks, I'll try that now.
Here's the log file from that last session. It didn't look good to me, but I don't really know what it all means?
NTFS at 0/65/2
filesystem size 1953506736
mftmirr_lcn 122094170
BAD_RS LBA=1217698266 10583
file_pread(5,3,buffer,1217698266(343147/142/62)) lseek err Invalid argument
file_pread(5,1,buffer,1217698266(343147/142/62)) lseek err Invalid argument
FAT12 343147 142 62 521156 85 54 2859710987
This partition ends after the disk limits. (start=5512665562, size=2859710987, end=8372376548, disk end=3907017568)
file_pread(5,2,buffer,3907018751(243200/170/42)) lseek err Invalid argument
file_pread(5,1,buffer,3907018751(243200/170/42)) lseek err Invalid argument
file_pread(5,2,buffer,3907018752(243200/170/43)) lseek err Invalid argument
file_pread(5,14,buffer,3907018754(243200/170/45)) lseek err Invalid argument
file_pread(5,3,buffer,3907018768(243200/170/59)) lseek err Invalid argument
file_pread(5,3,buffer,3907018815(243200/171/43)) lseek err Invalid argument
file_pread(5,8,buffer,3907018831(243200/171/59)) lseek err Invalid argument
file_pread(5,11,buffer,3907018878(243200/172/43)) lseek err Invalid argument
file_pread(5,2,buffer,3907020800(243200/203/12)) lseek err Invalid argument
The harddisk (2000 GB / 1863 GiB) seems too small! (< 4286 GB / 3992 GiB)
* HPFS - NTFS 0 65 2 121600 117 53 1953507328
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 0/65/2
You seem to have lots of read errors.
Checkout the available tools from WD to get two SMART reports for both drives.
For single drives I would recommend smartmontools but as your combined drives have to act like one unique drive but I have no experience how to get 2 individual reports.
Maybe it's possible to put one drive after the other into a docking station running under Linux.
Post the SMART parameters here attaching them as a text file or picture using the attachment function below.
The next hint would be to duplicate the RAID array using ddrescue.
BlackWitch
Hi.
Thanks for the advice.
My laptop somehow re-booted over night but trying the re-build option again it's come up with this, any further advice?:
TestDisk 7.2-WIP, Data Recovery Utility, August 2020 Christophe GRENIER <grenier@cgsecurity.org> https://www.cgsecurity.org Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243200 255 63 Partition Start End Size in sectors 1 * HPFS - NTFS 0 32 33 121600 75 59 1953506736 Boot sector Status: Bad Backup boot sector Status: Bad Sectors are not identical. A valid NTFS Boot sector must be present in order to access any data; even if the partition is not bootable. >[ Quit ] [Rebuild BS] [ Dump ] Return to Advanced menu
BlackWitch
Using a quick search in Data Lifeguard it's come up as a PASS
I'm confused now.
Unfortunately I don't use Linux.
Any other suggestions? I really need to save my drive.
I'm confused now.
If you can't follow the advice given you would have to bite the bullet and contact a professional data recovery company.
BlackWitch
I can and I have followed the advice but I am unable to use Linux, that is all.
I'm just looking for any other advice.
Thanks
Thanks
There is no Windows equivalent to ddrescue in Linux => There is no other advice.
smartmontools is available for Windows, too.
BlackWitch
Many thanks.
Do you think my drive beyond repair? Should I just re-format it?
I can't understand how this happened to my drive. It was working fine the other week. I've not used it in a few weeks.
If you have any other ideas on how I can recover the data, please update me.
Many thanks
Many thanks
