Can't open external HDD
Fox678
#1 Post by Fox678 »
I have an enternal HDD (500 GB), but I can't read it anymore. It seems to have happened because I copied several files until it was full, and deleting old files to free space.
Normally I would have to format the disk, but I don't want to loose my files.
TestDisk lists all files, so they are not lost (PHEW!). What should I do next?
I have read somewhere to do a quick format on the disk, then trying to undelete the files. Is that the correct approach?
Thanks a lot. ;)
Re: Can't open external HDD
Fox678 wrote: 05 Nov 2020, 07:39 TestDisk lists all files,
They same screen offers you a function to copy files and folders.
