Hey there, I tried to create an img file of my old iPhone 5s.
Using this instruction
https://www.cgsecurity.org/wiki/Recover ... _an_iPhone
But it always says I use an invalid dd command or dd comma d is unknown
I am running this with an windows 10 PC...
Perhaps this Windows PC doesn't know the command?
Any ideas?
Iphone Img create
Re: Iphone Img create
The procedure is for Linux or macos X.
Under Windows, you need to follow https://docs.microsoft.com/en-us/window ... tall-win10 to install WSL first.
Thank you so far.
Do I just need wsl or Linux also?
OK I now installed wsl and virtual machine...
Still dd invalid or unknown.
Another problem is, that the iPhone is not shown as a hard drive when connected to pc. So I think I have to enter the command on the iPhone terminal and not in windows itself...
It seems the whole command is wrong for windows... Anyone any idea how to fix this?
I tried following
dd if=\dev\rdisk0 | ssh -C username@IP of=C:\Users\iPhone.img bs=4096
Then I got for rdisk0 invalid argument
0+0 records in
0+0 records out
And after entering password for ssh I got wrong "of" command
I tried following
0+0 records in
0+0 records out
