Recovering SD card that was used as internal memory for Android Phone
Maximilian
#1 Post by Maximilian »
Hello everyone and thanks for having me!
I have an issue and I want to see if the community can assist me in order to use TestDisk & PhotoRec to solve it.
I have a micro SD SanDisk Ultra 32 GB.
This was formatted in an Android Phone in order to act as internal memory.
(So I suppose that this means that the card is encrypted so only that phone can access it)
Problem is that the card has been removed from the phone and the phone no longer exists.
When I insert the card in another android phone it asks to be formatted (which I haven't done it).
When I try to access it through the laptop's card reader it won't mount.
I have already tried running PhotoRec but I only get 5 files out of it that are unreadable.
And did one TestDisk attempt and this is the output.
Thu Nov 26 12:34:39 2020
OS: Linux, kernel 5.4.0-53-generic (#59-Ubuntu SMP Wed Oct 21 09:38:44 UTC 2020) x86_64
Compiler: GCC 9.2
ext2fs lib: 1.45.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.1
User is not root!
Using locale 'LC_CTYPE=en_US.UTF-8;LC_NUMERIC=el_GR.UTF-8;LC_TIME=en_US.UTF-8;LC_COLLATE=en_US.UTF-8;LC_MONETARY=el_GR.UTF-8;LC_MESSAGES=en_US.UTF-8;LC_PAPER=el_GR.UTF-8;LC_NAME=el_GR.UTF-8;LC_ADDRESS=el_GR.UTF-8;LC_TELEPHONE=el_GR.UTF-8;LC_MEASUREMENT=el_GR.UTF-8;LC_IDENTIFICATION=el_GR.UTF-8'.
Thu Nov 26 12:34:44 2020
Command line: TestDisk /debug
Compiler: GCC 9.2
/dev/sda: LBA, LBA48, DCO support
/dev/sda: size       976773168 sectors
/dev/sda: user_max   976773168 sectors
Warning: can't get size for Disk /dev/loop0 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop1 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop2 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop3 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop4 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop5 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop6 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop7 - 0 B - 0 sectors, sector size=512
Disk /dev/mmcblk0 - 31 GB / 29 GiB - CHS 973968 4 16 (RO), sector size=512
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500LM021-1KJ152, S/N:W62ALF4C, FW:0002YXM1
Media is opened in read-only.
Disk /dev/mmcblk0 - 31 GB / 29 GiB (RO)
Partition table type: EFI GPT
Analyse Disk /dev/mmcblk0 - 31 GB / 29 GiB - CHS 973968 4 16 (RO)
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=62333951 (expected 62333951)
hdr_lba_start=34
hdr_lba_end=62333918
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
19a710a2 b3ca 11e4 b0 26 10 60 4b 88 9d cf
193d1ea4 b3ca 11e4 b0 75 10 60 4b 88 9d cf
 1 P Unknown                     2048      34815      32768 [android_meta]
 2 P Unknown                    34816   62333918   62299103 [android_expand]
Backup partition structure
partition_save
The general question is:
Can you recover the files of an SD card that was configured to act as an internal storage for an Android Phone if the phone has been lost or factory reset?
Re: Recovering SD card that was used as internal memory for Android Phone
AFAIK due to encryption, you cannot recover the lost files.
