Recover data from old HDD
Intercore
#1 Post by Intercore »
Hello everyone.
Didn't find the topic with this specific problem so created a new one.
I connected my old HDD via SATA to USB adadpter to my laptop. Windows can't access this drive because it says it's a dynamic disk (invalid). I tried TestDisk to attempt recover my very needed files but the only option I can select after analysing step is "Image Creation". Analysis shows that there are two invalid FAT boot sectors, no bootable partition. I'm newbie there so I don't know if it's complicated or not, sorry... :D What can I do to recover my files so I can access them?
BTW, I tried connecting this HDD in Linux Mint, and it showed up and mounted. I could access some folders but not everything because of "unknown error".
This is analysis results:
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63 The harddisk (500 GB / 465 GiB) seems too small! (< 4465 GB / 4159 GiB) Check the harddisk size: HD jumper settings, BIOS detection... The following partitions can't be recovered: Partition Start End Size in sectors > FAT32 LBA 90150 131 29 195973 114 46 1700045442 FAT12 276639 34 25 542947 240 35 4278251009
Re: Recover data from old HDD
Intercore wrote: 08 Jan 2021, 15:53 I connected my old HDD via SATA to USB adadpter to my laptop.
Which hard disk?
Intercore
#3 Post by Intercore »
recuperation wrote: 08 Jan 2021, 16:30
Which hard disk?
The Seagate 500 GB one I used in my PC for about 8 years with no problems (CrystalDiskInfo shows that everything's alright with it). But the motherboard died so I wanted to recover all my files from that disk to my laptop but unfortunately I couldn't do that because Windows can't access it.
There are many harddisks from Seagate. Especially when you include old models. Which information am I looking for?
Intercore
#5 Post by Intercore »
recuperation wrote: 08 Jan 2021, 17:24 There are many harddisks from Seagate. Especially when you include old models. Which information am I looking for?
Here's the exact model: Seagate Barracuda ST500DM002.
#6 Post by recuperation »
What kind of connection is that?
Where does the power come from?
A docking station or an externally powered case with a USB or eSata connector would be nice.
Intercore
#7 Post by Intercore »
recuperation wrote: 08 Jan 2021, 19:07
I'm using this one: https://www.unitek-products.com/product ... sd-adapter
#8 Post by recuperation »
Please provide a smartmontools log file.
viewtopic.php?p=31986#p31986
Intercore
#9 Post by Intercore »
recuperation wrote: 08 Jan 2021, 19:39 Please provide a smartmontools log file.
Results:
smartctl 7.2 2020-12-30 r5155 [x86_64-w64-mingw32-w10-20H2] (sf-7.2-1)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST500DM002-1BD142
Serial Number: S2A80G74
LU WWN Device Id: 5 000c50 051debb9d
Firmware Version: KC45
User Capacity: 500 107 862 016 bytes [500 GB]
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Fri Jan 08 22:06:41 2021 FLEST
SMART support is: Enabled
SMART Status command failed: IOCTL_SCSI_PASS_THROUGH_DIRECT failed, Error=121
Warning: This result is based on an Attribute check.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 592) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 78) minutes.
Conveyance self-test routine
SCT capabilities: (0x303f) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
1 Raw_Read_Error_Rate 0x000f 108 084 006 Pre-fail Always - 16181800
3 Spin_Up_Time 0x0003 098 097 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 091 091 020 Old_age Always - 9552
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 088 060 030 Pre-fail Always - 5018525028
9 Power_On_Hours 0x0032 078 078 000 Old_age Always - 19409
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 091 091 020 Old_age Always - 9630
183 Runtime_Bad_Block 0x0032 001 001 000 Old_age Always - 266
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 25277
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 6 6 7
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 074 051 045 Old_age Always - 26 (Min/Max 21/26)
194 Temperature_Celsius 0x0022 026 049 000 Old_age Always - 26 (0 4 0 0 0)
195 Hardware_ECC_Recovered 0x001a 050 030 000 Old_age Always - 16181800
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 19297h+46m+00.816s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2883988123
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3879497291
SMART Error Log Version: 1
ATA Error Count: 25674 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 25674 occurred at disk power-on lifetime: 16016 hours (667 days + 8 hours)
ER ST SC SN CL CH DH
40 51 00 60 23 07 05 Error: UNC at LBA = 0x05072360 = 84353888
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 00 a0 23 07 45 00 02:36:42.548 READ FPDMA QUEUED
60 00 00 a0 22 07 45 00 02:36:42.548 READ FPDMA QUEUED
61 00 08 f0 07 6b 40 00 02:36:42.432 WRITE FPDMA QUEUED
61 00 08 60 02 6b 40 00 02:36:42.431 WRITE FPDMA QUEUED
61 00 08 b0 f9 a7 45 00 02:36:42.431 WRITE FPDMA QUEUED
Error 25673 occurred at disk power-on lifetime: 16016 hours (667 days + 8 hours)
60 00 00 a0 23 07 45 00 02:36:30.191 READ FPDMA QUEUED
60 00 00 a0 22 07 45 00 02:36:30.189 READ FPDMA QUEUED
61 00 60 00 6e 99 46 00 02:36:30.188 WRITE FPDMA QUEUED
60 00 60 18 f3 18 47 00 02:36:30.188 READ FPDMA QUEUED
61 00 60 a0 6d 99 46 00 02:36:30.187 WRITE FPDMA QUEUED
Error 25672 occurred at disk power-on lifetime: 16015 hours (667 days + 7 hours)
60 00 00 a0 23 07 45 00 02:35:17.266 READ FPDMA QUEUED
60 00 00 a0 22 07 45 00 02:35:17.265 READ FPDMA QUEUED
61 00 10 e8 94 a1 45 00 02:35:16.683 WRITE FPDMA QUEUED
61 00 08 98 93 a1 45 00 02:35:16.682 WRITE FPDMA QUEUED
61 00 08 28 87 a1 45 00 02:35:16.682 WRITE FPDMA QUEUED
Error 25671 occurred at disk power-on lifetime: 16015 hours (667 days + 7 hours)
60 00 00 a0 22 07 45 00 02:34:56.235 READ FPDMA QUEUED
60 00 00 a0 23 07 45 00 02:34:56.223 READ FPDMA QUEUED
61 00 28 00 fa 6b 40 00 02:34:56.222 WRITE FPDMA QUEUED
ef 02 00 00 00 00 a0 00 02:34:56.171 SET FEATURES [Enable write cache]
00 00 00 00 00 00 00 ff 02:34:55.929 NOP [Abort queued commands]
Error 25670 occurred at disk power-on lifetime: 16015 hours (667 days + 7 hours)
60 00 00 a0 23 07 45 00 02:34:52.226 READ FPDMA QUEUED
60 00 00 a0 22 07 45 00 02:34:52.224 READ FPDMA QUEUED
61 00 60 18 f3 18 47 00 02:34:52.223 WRITE FPDMA QUEUED
60 00 60 38 2d 40 45 00 02:34:52.222 READ FPDMA QUEUED
61 00 60 b8 f2 18 47 00 02:34:52.222 WRITE FPDMA QUEUED
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 17831 -
# 2 Short offline Completed without error 00% 17086 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
#10 Post by recuperation »
:roll:
Even though I don't understand every attribute I would recommend you duplicating the drive using ddrescue as described in the manual.
183 Runtime_Bad_Block 0x0032 001 001 000 Old_age Always - 266 ???
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 25277 ???
