Can I retrieve the NTFS file system from this 1tb external drive that I accidentally reformatted in to FAT32?
Thelump1
#1 Post by Thelump1 »
I am a bit of a newbie so please bear with me. I accidentally reformatted my NTFS external drive to FAT 32 with EaseUs Partition Master. I realized as soon as I did it and don't believe I did anything further as far as writing to the drive which now shows as being empty. I did run EaseUs Data Recovery and recovered most of my files I believe. I also ran testdisk to see if it could locate the NTFS partition. Unfortunately I don't understand what I'm seeing and am afraid to do something that will make it worse. My hope is that I can retrieve that partition because it contains thousands of audio and video files for my studio and while I have recovered many of them, most are RAW files with no name or way to associate them with programs to which they belong. To reconstruct that file structure would be next to impossible. Can this be done? I am including the testdisk log of what I have done so far. Thanks for any help you can give me.
Mon Dec 28 19:48:41 2020
TestDisk 7.2-WIP, Data Recovery Utility, Novembre 2020
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=127777374208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=127777374208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=499630825472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000194015744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1500302418432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1500290528768
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=127777357824
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Hitachi HTS727550A9E364, S/N:J3310081H8XVEB, FW:JF3OA0E0
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ASMT ASM1156-PM, S/N:00000000000000000000
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - ASMT ASM1156-PM, S/N:00000000000000000000
Disk /dev/sdd - 127 GB / 119 GiB - CHS 15534 255 63, sector size=512 - PNY USB 2.0 FD, S/N:A0321H06YD80000051, FW:1100
Disk /dev/sdb - 1000 GB / 931 GiB - ASMT ASM1156-PM
BAD_RS LBA=16128 63
FAT32 at 1/1/1
Info: size boot_sector 1953503937, partition 1953503937
FAT1 : 32-119249
FAT2 : 119250-238467
start_rootdir : 238468 root cluster : 2
Data : 238468-1953503875
sectors : 1953503937
cluster_size : 128
no_of_cluster : 15259886 (2 - 15259887)
fat_length 119218 calculated 119218
1 E extended LBA 1 0 1 121600 254 63 1953504000
5 L FAT32 1 1 1 121600 254 63 1953503937 [AV DATA]
Bad relative sector.
BAD_RS LBA=16128 63
FAT32 at 1/1/1
FAT1 : 32-119249
cluster_size : 128
FAT32 at 1/1/1
FAT: cluster=2(0x2), pos=254596
FAT32 LBA 1 1 1 121600 254 63 1953503937 [AV DATA]
FAT32, blocksize=65536, 1000 GB / 931 GiB
file_pread(5,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
file_pread(5,7,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,8,buffer,1953525768(121601/90/34)) lseek err Invalid argument
file_pread(5,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(5,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(5,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(5,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
L FAT32 LBA 1 1 1 121600 254 63 1953503937 [AV DATA]
add_ext_part_i386: max
add_ext_part_i386: min
5 L FAT32 LBA 1 1 1 121600 254 63 1953503937 [AV DATA]
BAD_RS LBA=16128 63
FAT32 at 1/1/1
FAT1 : 32-119249
cluster_size : 128
FAT32 at 1/1/1
FAT32 at 1/1/7
FAT1 : 32-119249
cluster_size : 128
FAT32 at 1/1/7
FAT32 LBA 1 1 1 121600 254 63 1953503937 [NO NAME]
NTFS at 121600/254/63
filesystem size 1953503937
mft_lcn 3
mftmirr_lcn 122093996
HPFS - NTFS 1 1 1 121600 254 63 1953503937
NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
mft_lcn 3
HPFS - NTFS 121600 254 63 243200 253 62 1953503937
This partition ends after the disk limits. (start=1953520064, size=1953503937, end=3907024000, disk end=1953525168)
The harddisk (1000 GB / 931 GiB) seems too small! (< 2000 GB / 1863 GiB)
5 L HPFS - NTFS 1 1 1 121600 254 63 1953503937
1 * HPFS - NTFS 1 1 1 121600 254 63 1953503937
1 P HPFS - NTFS 1 1 1 121600 254 63 1953503937
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Not an exFAT boot sector.
Invalid partition structure.
BAD_RS LBA=16128 63
FAT32 at 1/1/1
FAT1 : 32-119249
cluster_size : 128
BAD_RS LBA=16128 63
FAT32 at 1/1/1
FAT1 : 32-119249
cluster_size : 128
FAT32 at 1/1/1
BAD_RS LBA=16128 63
FAT32 at 1/1/1
FAT1 : 32-119249
cluster_size : 128
FAT32 at 1/1/1
FAT32 at 1/1/7
FAT1 : 32-119249
cluster_size : 128
FAT32 at 1/1/7
mft_lcn 3
mft_lcn 3
BAD_RS LBA=16128 63
FAT32 at 1/1/1
FAT1 : 32-119249
cluster_size : 128
Re: Can I retrieve the NTFS file system from this 1tb external drive that I accidentally reformatted in to FAT32?
Testdisk found the remains of a NTFS partition but cannot open it as its too dammaged.
Third party software may still succeed in recovering stuff including directory structure but you have to test that.
Thelump1
#3 Post by Thelump1 »
Thank you so much for your reply. Can you possibly suggest an application(s) that would be able to accomplish recovering the file structure? Thanks again.
I have no particular recommendation.
