Boot sector and backup boot sector bad Topic is solved
Starfish
#1 Post by Starfish »
I have a 4TB disk (non-bootable) that I am trying to recover. It has a single partition. The steps I have tried so far are Analyze (with Deep Search) and RebuildBS. RebuildBS failed (see screenshot), saying Boot sector is bad and Backup boot sector is bad. So I cannot List the files ("Can't open filesystem. Filesystem seems damaged"). It seems to have correctly identified the primary partition, but at this point I'm not sure what the next step should be. Could anyone please advise? With the Deep Search I was a little bit confused about the FAT16 partition it seemed to find (which it said "This partition ends after the disk limits"). I've included the full log below.
The files I'm trying to recover are from niche scientific software so I don't think PhotoRec would work, but please correct me if I'm wrong.
On trying to Rebuild BS
After Deep Search
Mon Mar  8 12:02:08 2021
OS: Windows 8 (9200)
Compiler: GCC 6.4, Cygwin32 2009.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249405733376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=256042336256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=3000457232384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500096991744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1000202043392
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Samsung SSD 850 EVO M.2 250GB, S/N:S33CNX0J500309W, FW:EMT21B6Q
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - SAMSUNG HD103SJ, S/N:S246J9KB705572, FW:1AJ10001
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - ST3000DM001-1CH166, S/N:Z1F0TE1K, FW:CC43
Disk /dev/sdd - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - Sabrent, S/N:6479_A732_9002_2759., FW:RKT303.3
Disk /dev/sde - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - ST4000LM 024-2AN17V, S/N:L25W3KCW
Disk /dev/sde - 4000 GB / 3726 GiB - ST4000LM 024-2AN17V
Analyse Disk /dev/sde - 4000 GB / 3726 GiB - CHS 486401 255 63
Invalid NTFS or exFAT boot
 1 P HPFS - NTFS              0   1  1 60799 254 63  976751937
BAD_RS LBA=2911158969 12897716
file_pread(8,3,buffer,2911158969(715909/245/42)) lseek err Invalid argument
file_pread(8,1,buffer,2911158969(715909/245/42)) lseek err Invalid argument
     FAT16 >32M           715909 245 42 891696 184 59 2824014330
This partition ends after the disk limits. (start=11501093561, size=2824014330, end=14325107890, disk end=7814037168)
file_pread(8,2,buffer,3519070207(486401/86/21)) lseek err Invalid argument
file_pread(8,1,buffer,3519070207(486401/86/21)) lseek err Invalid argument
file_pread(8,2,buffer,3519070208(486401/86/22)) lseek err Invalid argument
file_pread(8,14,buffer,3519070210(486401/86/24)) lseek err Invalid argument
file_pread(8,3,buffer,3519070224(486401/86/38)) lseek err Invalid argument
file_pread(8,3,buffer,3519070271(486401/87/22)) lseek err Invalid argument
file_pread(8,8,buffer,3519070287(486401/87/38)) lseek err Invalid argument
file_pread(8,11,buffer,3519070334(486401/88/22)) lseek err Invalid argument
file_pread(8,2,buffer,3519072256(486401/118/54)) lseek err Invalid argument
The harddisk (4000 GB / 3726 GiB) seems too small! (< 7334 GB / 6830 GiB)
Backup partition structure
partition_save
partition_save
Not an exFAT boot sector.
ntfs_boot_sector
filesystem size           1 1
sectors_per_cluster       0 0
mft_lcn                   0 0
mftmirr_lcn               0 0
clusters_per_mft_record   0 85
clusters_per_index_record 0 85
Status: Bad
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
mft at 457
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn             786432
ntfs_find_mft: mftmirr_lcn         0
ntfs_find_mft: mft_record_size     4096
mft at 6291897
ntfs_boot_sector
filesystem size           1 1
mft_lcn                   0 0
mftmirr_lcn               0 0
Status: Bad
Status: Bad
Re: Boot sector and backup boot sector bad
With a sector size of 512 bytes - as outlined in the log - selecting GPT is mandatory for a 4TB drive. Please rerun Testdisk with this settings.
You can run Photorec to evaluate the supported file formats. "niche scientific software" is not specific.
Starfish
#3 Post by Starfish »
recuperation wrote: 10 Mar 2021, 12:29 With a sector size of 512 bytes - as outlined in the log - selecting GPT is mandatory for a 4TB drive. Please rerun Testdisk with this settings.
Really appreciate the quick reply, thanks a lot recuperation. After selecting GPT I am able to list my files and copy. I think I can recover everything like this.
For anyone experiencing similar issues:
  • My partition table type was automatically identified as Intel - I originally went with this and ran into the issues described earlier in the thread
  • Changing to type GPT worked immediately
