Partition Can't Be Recovered after quick and deep scan
slashscreen
#1 Post by slashscreen »
Hey, I'm trying to repair my friend's internal HDD (1TB, shown here as ST1000LM035-1RK172) for a laptop that I totally screwed up, and I am attempting to undelete some files.
In short, what happened to the poor thing was:
-Partitions Deleted
-Partially overwritten with 0s (only about .1%)
-New partition over it
And while trying to quick and deep scan to find partitions to undelete files from, only a malformed(?) partition showed up which roughly equated to the new partition over it, but did not have the proper name in brackets.
This is what the log for this run said. What does this mean and how do I fix it? I'm starting to run out of options...
Tue Apr 6 17:54:20 2021
TestDisk 7.2-WIP, Data Recovery Utility, March 2021
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=15931539456
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=15931539456
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1000199946240
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=998988041216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=524288000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=13442220032
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=524288000
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Samsung SSD 970 EVO Plus 2TB, S/N:0025_3853_1190_D3F7., FW:2B2QEXM7
Disk /dev/sdb - 15 GB / 14 GiB - CHS 1936 255 63, sector size=512 - Multiple Card Reader, S/N:AU6485, FW:1.00
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000LM035-1RK172, S/N:WQ97SHLD, FW:RTM2
Drive E: - 524 MB / 500 MiB - CHS 16000 2 32, sector size=512
Disk /dev/sdc - 1000 GB / 931 GiB - ST1000LM035-1RK172
Analyse Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 121488/200/57
filesystem size 1794048
mft_lcn 74752
mftmirr_lcn 2
HPFS - NTFS 121488 200 57 121600 117 53 1794048
NTFS, blocksize=4096, 918 MB / 876 MiB
NTFS at 121601/57/56
filesystem size 1007616
mft_lcn 41984
mftmirr_lcn 2
HPFS - NTFS 121538 128 63 121601 57 56 1007616
NTFS found using backup sector, blocksize=4096, 515 MB / 492 MiB
mft_lcn 41984
mftmirr_lcn 2
file_pread(6,2,buffer,1953859589(121622/34/18)) lseek err Invalid argument
file_pread(6,1,buffer,1953859589(121622/34/18)) lseek err Invalid argument
NTFS: Can't read MFT
HPFS - NTFS 121601 57 56 121663 241 49 1007616
NTFS, blocksize=4096, 515 MB / 492 MiB
This partition ends after the disk limits. (start=1953523711, size=1007616, end=1954531326, disk end=1953525168)
file_pread(6,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(6,1,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(6,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(6,1,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(6,2,buffer,1953525767(121601/90/33)) lseek err Invalid argument
file_pread(6,1,buffer,1953525767(121601/90/33)) lseek err Invalid argument
file_pread(6,2,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(6,1,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(6,2,buffer,1953525830(121601/91/33)) lseek err Invalid argument
file_pread(6,1,buffer,1953525830(121601/91/33)) lseek err Invalid argument
file_pread(6,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(6,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(6,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(6,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(6,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
file_pread(6,8,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(6,8,buffer,1953525768(121601/90/34)) lseek err Invalid argument
file_pread(6,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(6,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(6,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(6,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(6,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 1000 GB / 931 GiB)
interface_load
Invalid partition structure.
mft_lcn 41984
mftmirr_lcn 2
mft_lcn 41984
mftmirr_lcn 2
* HPFS - NTFS 121538 128 63 121601 57 56 1007616
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Not an exFAT boot sector.
1 * HPFS - NTFS 121538 128 63 121601 57 56 1007616
mft_lcn 41984
mftmirr_lcn 2
mft_lcn 41984
mftmirr_lcn 2
mft_lcn 41984
mftmirr_lcn 2
mft_lcn 41984
mftmirr_lcn 2
Thanks in advance.
Re: Partition Can't Be Recovered after quick and deep scan
After running quick search, you need to enter the possible partitions for recovery using the "p"-key ("list files").
If you that fails continue with deep search and retry the above.
If that fails - what I assume - run Photorec or any commercial recover software.
slashscreen
#3 Post by slashscreen »
it says filesystem is damaged when i try that with the only partition that shows up (which isn't the one I want)
See above.
