Invalid FAT Boot Sector
Jade
#1 Post by Jade »
Hi there,
I have a bunch of old hard drives I am trying to access, this first one I am connecting to my PC with USD. It is IDE. MY goal is to just get the data off it onto my PC.
It hangs for a few minutes when trying to access then comes up "Parameter Incorrect" when trying to view files.
The below is the Analysis on TestDisk.
I did QuickSearch which found nothing so did a Rebuild BS...which ran for a few hours then got stuck at 24%.
I am now doing a DeeperSearch (which I should have done before the Rebuild BS I guess), but I feel as if this may get stuck aswell as I am thinking it may be a hardware problem.
I will post results (should be around 7 hours the speed it's going) but am thinking I might need to do a DDRescure to PC HD and then rerun?
Thanks - should be a Analyse pic below and the log.
Fri Apr 9 10:43:17 2021
TestDisk 7.2-WIP, Data Recovery Utility, March 2021
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=128035676160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=126775733248
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=966917095424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1099956224000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1099956224000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=1099956224000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=700781166592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=500105217024
Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512 - TOSHIBA THNSNH128GMCT, S/N:43FS10BATKAY, FW:HTCAN102
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST1000DM003-1CH162, S/N:S1DD0BP4, FW:CC44
Disk /dev/sdc - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - WDC WD40EZRX-00SPEB0, S/N:WD-WCC4E3LLRXYT, FW:80.00A80
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Hitachi HDT725050VLAT80, S/N:20201102
Disk /dev/sdd - 500 GB / 465 GiB - Hitachi HDT725050VLAT80
Analyse Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63
Invalid FAT boot sector
1 * FAT32 LBA 0 1 1 60800 254 63 976768002
Re: Invalid FAT Boot Sector
Same recipe as here:
viewtopic.php?p=33716#p33716
