any hope? raw partition/hdd, prolly destroyed both mft records.
marsi
#1 Post by marsi »
Hi guys,
very fcked few days (week) behind me. i had to move from win7 (unvoluntary) to win10 because of work. took me like 3+ days to install win10 and also few linux distros with the fck the win10 idea, eventualy...
anyway, in midst of all that chaos i kinda lost 3rd hdd, but didn't pay too much attention to it at the time since i had other (bigger) problems to solve.
not exaclly sure when and why 3rd hdd stop working and what i did at the time :( . looking back now, at some point, i did all the things that i shouldn't do, but its nothing i wasn't doing last 20yrs...
1. in win, in disk managment i changed drive letter from D to X, in order to assing letter D to 2nd hdd. assigned D to 2nd hdd, and changed from X to E for 3rd hdd. not sure if i closed disk managment, while i was making usb with linux installation. hit restart prolly.
2. in linux, in gparted, i was doing some changes on 1st hdd few times. not sure, but maybe 3rd hdd was opened/mounted in gparted when i restarted linux. prolly in disk managment app also.
3. puled out USB stick few times while pc was reseting/booting...
not sure what fcked my 3rd hdd, its prolly me and something i did that i'm not aware off, but i'll go with blaming win10.
anyway, here is what i got now:
from win: i need to format hdd before i can use it. raw partition. (very elegant solution imo :), i'm surprised they don't offer buying new hdd as better (quicker) solution)
from chkdsk /f:
The type of the file system is NTFS.
The first NTFS boot sector is unreadable or corrupt.
Reading second NTFS boot sector instead.
Unable to determine volume version and state. CHKDSK aborted.
and from testdisk:
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=8001563222016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=8001563222016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=277825454080
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=7891327123456
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - TOSHIBA HDWD120, S/N:7760WS0AS, FW:MX4OACF0
Disk /dev/sdb - 8001 GB / 7452 GiB - CHS 972801 255 63, sector size=512 - TOSHIBA HDWF180, S/N:Y769K0SIFZ1D, FW:GX0B
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - NVMe Samsung SSD 960, S/N:0025_3851_81B0_A8FB., FW:3B7Q
Disk /dev/sdb - 8001 GB / 7452 GiB - TOSHIBA HDWF180
Partition table type: EFI GPT
Analyse Disk /dev/sdb - 8001 GB / 7452 GiB - CHS 972801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=15628053167 (expected 15628053167)
hdr_lba_start=34
hdr_lba_end=15628053134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Data                   264192 15413012479 15412748288 [Poker]
NTFS at 0/32/33
filesystem size           15412748288
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=1048576, part_size=7891327123456, sector_size=512
NTFS at 0/32/33
mftmirr_lcn               2
     MS Data                     2048 15412750335 15412748288 [Poker]
     NTFS, blocksize=4096, 7891 GB / 7349 GiB
NTFS at 959415/166/47
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 7891 GB / 7349 GiB
mftmirr_lcn               2
     MS Data               15413012479 30825760766 15412748288
This partition ends after the disk limits. (start=15413012479, size=15412748288, end=30825760766, disk end=15628053168)
NTFS at 959415/166/48
filesystem size           921600
mft_lcn                   38400
mftmirr_lcn               2
     MS Data               15412090881 15413012480     921600
     NTFS found using backup sector, blocksize=4096, 471 MB / 450 MiB
mft_lcn                   38400
mftmirr_lcn               2
     MS Data               15413012480 15413934079     921600 [Recovery]
     NTFS, blocksize=4096, 471 MB / 450 MiB
FAT32 at 959473/5/21
FAT1 : 6654-7422
FAT2 : 7423-8191
Data : 8192-204799
sectors : 204800
cluster_size : 2
no_of_cluster : 98304 (2 - 98305)
fat_length 769 calculated 769
FAT: cluster=2(0x2), pos=15413942272
     EFI System            15413934080 15414138879     204800 [EFI System Partition] [NO NAME]
     FAT32, blocksize=1024, 104 MB / 100 MiB
NTFS at 959485/196/8
filesystem size           213913600
mftmirr_lcn               2
     MS Data               15200225281 15414138880  213913600
     NTFS found using backup sector, blocksize=4096, 109 GB / 102 GiB
mftmirr_lcn               2
     MS Data               15414138880 15628052479  213913600
     NTFS, blocksize=4096, 109 GB / 102 GiB
file_pread(5,2,buffer,15628054528(972801/102/38)) lseek err Invalid argument
file_pread(5,1,buffer,15628054528(972801/102/38)) lseek err Invalid argument
file_pread(5,2,buffer,15628054529(972801/102/39)) lseek err Invalid argument
file_pread(5,1,buffer,15628054531(972801/102/41)) lseek err Invalid argument
file_pread(5,1,buffer,15628054532(972801/102/42)) lseek err Invalid argument
file_pread(5,1,buffer,15628054533(972801/102/43)) lseek err Invalid argument
file_pread(5,1,buffer,15628054534(972801/102/44)) lseek err Invalid argument
file_pread(5,1,buffer,15628054535(972801/102/45)) lseek err Invalid argument
next 300+ rows same thing, different numbers maybe
file_pread(5,1,buffer,15628053304(972801/83/11)) lseek err Invalid argument
file_pread(5,1,buffer,15628055217(972801/113/34)) lseek err Invalid argument
The harddisk (8001 GB / 7452 GiB) seems too small! (< 15 TB / 14 TiB)
$MFT has invalid magic.
ntfs_mft_load(): Failed.
dir_partition inode=5
ntfs_readdir failed for cluster 5: Input/output error
       5 dr-xr-xr-x     0      0         0  5-May-2021 14:40 .
       5 dr-xr-xr-x     0      0         0  5-May-2021 14:40 ..
      40 dr-xr-xr-x     0      0         0  6-Oct-2020 02:38 $RECYCLE.BIN
       5 dr-xr-xr-x     0      0         0  6-Oct-2020 11:28 .
       5 dr-xr-xr-x     0      0         0  6-Oct-2020 11:28 ..
      36 dr-xr-xr-x     0      0         0  6-Oct-2020 11:28 System Volume Information
dir_partition inode=36
Directory /System Volume Information
      36 dr-xr-xr-x     0      0         0  6-Oct-2020 11:28 .
      37 -r--r--r--     0      0     20480  6-Oct-2020 11:28 tracking.log
dir_partition inode=0
       3 drwxr-xr-x     0      0         0  6-Oct-2020 02:20 EFI
FAT: cluster=3(0x3), pos=15413942274
Directory /EFI
       3 drwxr-xr-x     0      0         0  6-Oct-2020 02:20 .
       0 drwxr-xr-x     0      0         0  6-Oct-2020 02:20 ..
       4 drwxr-xr-x     0      0         0  6-Oct-2020 02:20 Microsoft
   10807 drwxr-xr-x     0      0         0  6-Oct-2020 02:26 Boot
   91282 dr-xr-xr-x     0      0         0  6-Oct-2020 03:41 $AV_ASW
      64 dr-xr-xr-x     0      0         0  6-Oct-2020 04:46 $Recycle.Bin
   99261 dr-xr-xr-x     0      0         0  6-Oct-2020 03:36 AMD
   99099 dr-xr-xr-x     0      0         0  6-Oct-2020 03:34 CIMTEMP
   89707 dr-xr-xr-x     0      0         0 16-Nov-2019 01:01 Documents and Settings
      65 dr-xr-xr-x     0      0         0  6-Oct-2020 04:37 PerfLogs
      66 dr-xr-xr-x     0      0         0  7-Oct-2020 20:53 Program Files
    1543 dr-xr-xr-x     0      0         0  6-Oct-2020 03:53 Program Files (x86)
    1648 dr-xr-xr-x     0      0         0  6-Oct-2020 04:37 ProgramData
    1866 dr-xr-xr-x     0      0         0  6-Oct-2020 02:46 Recovery
   87994 dr-xr-xr-x     0      0         0  1-May-2021 18:36 System Volume Information
    1867 dr-xr-xr-x     0      0         0  6-Oct-2020 02:55 Users
    3003 dr-xr-xr-x     0      0         0  6-Oct-2020 04:42 Windows
      53 -r--r--r--     0      0 27435225088  5-May-2021 17:52 hiberfil.sys
     176 -r--r--r--     0      0 10200547328  5-May-2021 17:52 pagefile.sys
   33845 -r--r--r--     0      0 268435456  5-May-2021 17:52 swapfile.sys
dir_partition inode=40
ntfs_readdir failed for cluster 40: Input/output error
Directory /$RECYCLE.BIN
      40 dr-xr-xr-x     0      0         0  6-Oct-2020 02:38 .
   20988 dr-xr-xr-x     0      0         0  9-Jun-2018 10:49 S-1-5-18
      41 dr-xr-xr-x     0      0         0 29-Jun-2018 16:44 S-1-5-21-1350785218-4038914454-1068601573-1001
  100114 dr-xr-xr-x     0      0         0 27-Feb-2021 22:09 S-1-5-21-2960108660-746196553-3917765268-1000
dir_partition inode=100114
ntfs_readdir failed for cluster 100114: Input/output error
Directory /$RECYCLE.BIN/S-1-5-21-2960108660-746196553-3917765268-1000
  100114 dr-xr-xr-x     0      0         0 27-Feb-2021 22:09 .
      40 dr-xr-xr-x     0      0         0  6-Oct-2020 02:38 ..
NTFS at 0/32/33
mftmirr_lcn               2
NTFS at 0/32/33
mftmirr_lcn               2
recover_EXT2: s_block_group_nr=0/2, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8144
recover_EXT2: s_blocks_count 97656
recover_EXT2: part_size 781248
Last mount time:    Tue Aug  1 12:10:16 2017
     Linux filesys. data        39600     820847     781248
     ext4 blocksize=4096 Large_file Sparse_SB, 399 MB / 381 MiB
after this i started deep scan, and after 4-5 hours i kinda eyeboled (if thats the word) to ~10 days.
So, my question is: Is it worth to let deep scan run for 10 days (prolly ~5)? given the info above, is there a chance for easy fix after deep scan (without extracting data to other hdd and copying them back)?
i'm no expert, not even intermediate in this topic, but from what i could read from log feels that there is not much hope.
thanks!
btw. i hope someone will reply in next 10 days :D :D :D
