Surprise SSD failure, got "the following partitions can't be recovered"
AsukaIsBestGirl
#1 Post by AsukaIsBestGirl »
Win10 Lenovo M900 <1 year old
1TB SSD
No signs of issues before one day the computer simply wouldn't boot. I tried updating the BIOS first, just in case, but it had no effect.
I put TestDisk on a USB drive and I ran the deep scan, which took like 4 hours. It showed two NTFS partitions and said "the following partitions can't be recovered"
There weren't any options, except to "Continue" so I pressed Continue with the larger partition highlighted.
I get this screen:
I don't know what I'm supposed to do next. How do I know what letter I'm supposed to put next to each partition?
My hope is to get it to boot once, put in a thumb drive, and transfer off everything I can get. I don't know if this is a realistic goal.
I've ordered a new SSD, but it won't be in for a couple days.
Re: Surprise SSD failure, got "the following partitions can't be recovered"
Check each partition for valid content using the "p"-key ("list files").
AsukaIsBestGirl
#3 Post by AsukaIsBestGirl »
Partitions:
1 - Seems okay, had recycle bin and system volume info
2 - Can't open file system.
3 - Can't open file system.
Partition 4:
Scrolling down showed many more red files.
Partition 5 - Seemed okay, only a few items, recovery and system volume info
6 - Can't open file system.
Partition 7:
Partition 8:
AsukaIsBestGirl
#4 Post by AsukaIsBestGirl »
Okay, so 3 of those partitions (the ones with screenshots) have bootmgr and bootmgr.efi which I am assuming are needed to try to boot from the drive.
Two more partitions seemed okay.
The rest said Can't open file system.
Assumptions I have:
1 - "Can't open file system." partitions need to keep the D next to their name.
2 - The two mostly empty partitions need to say either L or E. I'm not sure which.
3 - One of the three partitions with bootmgr and bootmgr.efi needs to say *
4 - One of the three partitions with bootmgr and bootmgr.efi needs to say P
5 - One of the three partitions with bootmgr and bootmgr.efi needs to say L or E, I'm not sure which.
Are my assumptions correct, or am I on the wrong track?
#5 Post by recuperation »
Did you find the data that you were missing?
AsukaIsBestGirl
#6 Post by AsukaIsBestGirl »
Looking inside the partitions that aren't "Can't open file system." I've gone through them, but there doesn't seem to be like any windows file structure.
There was another smaller partition detected on the previous step (when I did the deepscan), but I don't know how to go back to that page and select the other partition without doing a deep scan again. (Takes about 4 hours to deep scan.)
#7 Post by recuperation »
You will have to rerun the deep scan again.
If you don't see the data you expect you are left to use Photorec or any other recovery software.
AsukaIsBestGirl
#8 Post by AsukaIsBestGirl »
Running deep scan again didn't help. I'll just accept it as lost. I'm just surprised there were no warnings... no BSoD, no crashes, no weird behaviour at all.
#9 Post by recuperation »
You could try Photorec or other commercial recovery software.
If you want to prevent failure you have to monitor at least SMART parameters regularly. It seems to me that SDD failures are not preceded by warning signs.
