hello, i have this laptop hdd which stopped working after i updated my windows 10 (disk was dynamic so i want it to be change to basic)
after getting nowhere analyzing, i chose advanced, boot , rebuild bs and the program gave me can't find cluster size issue.
here's my log
Mon May 24 22:42:37 2021
TestDisk 7.2-WIP, Data Recovery Utility, May 2021
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255533776896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=104855502848
Disk \\.\PhysicalDrive0 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - SanDisk X400 M.2 2280 256GB, S/N:170201427672, FW:X4130012
Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - HITACHI HTS725050A7E630, S/N:TF1501Y9GLD2PF, FW:GH2ZB390
Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - HITACHI HTS725050A7E630
test_FAT()
1 P FAT16 >32M 0 32 33 12748 21 9 204795904
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
2 E extended LBA 12748 53 42 25496 139 51 204802048
fat1x_boot_sector
Bad
i hope you guys can help me pleaseeee
Re: can't find cluster size
"after getting nowhere analyzing"
That is a pretty short useless test description!
Read here:
The manual, the wiki everything is already there. In addition to that there is a forum where I repetively always give the same advice to the ever repeating same question.
Read here:
applemartini
right, sorry about that i have no idea what im doing right now
by getting nowhere i meant analyze - no partition found or selected for discovery - deep search - repeat and also this,
Invalid FAT boot sector
after getting this error i tried advanced - boot - rebuild bs but still no luck
i've already read the test disk step by step section but i still don't know what to do...
applemartini
i've read most of the threads and yes there already are answers to my problems but the thing is it seems i have multiple issues regrading the fixes itself
for example rebuilding bs didnt worked, and after deep search i have this issue
1 * HPFS - NTFS 12748 86 11 25496 139 51 204800000
Status: Bad
Status: OK
Sectors are not identical.
and i dnt even know what to search for unfortunately
Status: Bad
Status: OK
