Request to improve TestDisk partition display
SteveSi
#1 Post by SteveSi »
First, I must thank you very much for the marvellous TestDisk utility which I have used many times to recover data from drives.
However, with larger drives the CHS notation displayed by TestDisk is not very useful.
For MBR drives:
Separate the column headings with an empty line
It also does not display the partition type number which would be very useful (in hex). Type 07 is displayed as 'HPFS - NTFS' but can also be exFAT.
Most of all, it does not display the LBA addresses for Start, Size and calculated End for each partition.
These would be easy to add and would make it a lot easier to use (most other utilities use LBA)
It would also help if, as well as the partition size in sectors, you could also display the size in byte units - e.g. KiB, MiB, GiB, TiB.
When adding partitions to make a new partition table, I can easily look at the Start and End LBA numbers to see if they make sense.
TestDisk 6.10, Data Recovery Utility, July 2008
Disk /dev/sde - 500 GB / 465 GiB - CHS 60801 255 63
1 P HPFS - NTFS 0 32 33 52885 177 28 849606656 [M2_1_NTFS]
2 P FAT32 LBA 52885 201 21 56675 17 14 60874752 [M2-2_FAT32]
3 P HPFS - NTFS 56675 25 55 60801 80 15 66287616 [M2_PTN3]
Maybe like this:
(NEW LINE HERE]
Partition Start(CHS) End(CHS) Size in sectors
1 P HPFS - NTFS 0 32 33 52885 177 28 849606656 [M2_1_NTFS] LBA Start=2048 End=849608703 Size=849606656 (414847MiB)
2 P FAT32 LBA 52885 201 21 56675 17 14 60874752 [M2-2_FAT32] LBA Start=849610208 End=xxxxxx Size=xxxxxxx (xxxxMiB)
3 P HPFS - NTFS 56675 25 55 60801 80 15 66287616 [M2_PTN3] LBA Start=xxxxx End=xxxxxx Size=xxxxxxx (xxxxMiB)
Or perhaps you could add an option to display as CHS or LBA so the user could choose?
Many thanks.
Re: Request to improve TestDisk partition display
Please note that the current version of the Testdisk package is 7.2 WIP.
If you don't use the most recent version anyway adding a new feature for you does not really look convincing.
With GPT in modern computers becoming more and more common Testdisk shows you exact LBA figures.
SteveSi
#3 Post by SteveSi »
Thanks for reply. I did use 7.2 but somehow I seem to have taken the screenshots with an old version!
According to wiki, location offset 8 of the MBR partition table entry contains the LBA start address
https://en.wikipedia.org/wiki/Master_boot_record
'0x08 4 bytes LBA of first absolute sector in the partition[f]'
This must be used for larger drives and so must be valid.
It is used instead of the old CHS values and so it ought to be displayed?
Adding the LBA Start address and End address would be most useful.
P.S. Once Analyse has started with 7.2 I am having trouble pressing S to stop it??? It does not stop... I also don't see any progress indicator but HDD LED is flashing.
Have to close the console window to stop it.
I don't plan to add LBA display for PC/Intel partition table in the interactive text interface but "testdisk -lu" lists the LBA address of all partitions.
