GPT Partition Lost Raw Disk
Eltharion
#1 Post by Eltharion »
Goodmorning everyone,
I would need your help to recover a disk partition that is no longer visible.
I was running a simple robocopy on Windows 10 (copying files from a source to an empty target disk 3Tb-> 4Tb)
from a disk whose smart reported me problems (3Tb), through a dual slot usb docking.
I start the copy, everything seems to be fine until it finds a possibly corrupt file. At that point an endless series of
copying attempts begins. At that point I read that by default Robocopy tries an unlikely number of times before
moving on.
I try to stop copying, but nothing can stop it.
At that point, I very naively turn off the docking.
I figured that at the worst, only the disc I was writing on could have problems. I was wrong, both drives now
no longer have a visible partition.
If you can help me recover my files, I would appreciate it.
I tried Disk Drill, it recovers something, but it renames the files and doesn't give the original directory structure.
In this way I would have to open file by file to understand what it contains (assuming that what is recovered is readable).
I am enclosing the TestFile log file.
Thank you.
Thu Jun 24 09:46:24 2021
TestDisk 7.2-WIP, Data Recovery Utility, May 2021
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255401918464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=4000785104896
Disk \\.\PhysicalDrive0 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - KBG40ZNV256G KIOXIA, S/N:0100_0000_0000_0000_8CE3_8E04_0156_CF0E., FW:HP00AE00
Disk \\.\PhysicalDrive1 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - WDC WD40 EFZX-68AWUN0, S/N:00A123456884, FW:0107
Disk \\.\PhysicalDrive1 - 4000 GB / 3726 GiB - WDC WD40 EFZX-68AWUN0
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive1 - 4000 GB / 3726 GiB - CHS 486401 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=7814037167 (expected 7814037167)
hdr_lba_start=34
hdr_lba_end=7814037134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Data 2048 7814035455 7814033408 [Basic data partition]
NTFS at 0/32/33
filesystem size 7814033401
mft_lcn 30575
mftmirr_lcn 4
NTFS part_offset=1048576, part_size=4000785101312, sector_size=512
NTFS at 0/32/33
mft_lcn 30575
mftmirr_lcn 4
MS Data 2048 7814035448 7814033401
NTFS, blocksize=4096, 4000 GB / 3726 GiB
NTFS at 486401/53/52
mft_lcn 30575
mftmirr_lcn 4
MS Data 2055 7814035455 7814033401
NTFS found using backup sector, blocksize=4096, 4000 GB / 3726 GiB
mft_lcn 30575
mftmirr_lcn 4
NTFS: Can't read MFT
MS Data 7814035455 15628068855 7814033401
This partition ends after the disk limits. (start=7814035455, size=7814033401, end=15628068855, disk end=7814037168)
file_win32_pread(600,11,buffer,3519069867(486401/80/59)) read err: read after end of file
file_win32_pread(600,8,buffer,3519069866(486401/80/58)) read err: read after end of file
file_win32_pread(600,8,buffer,3519069870(486401/80/62)) read err: read after end of file
file_win32_pread(600,14,buffer,3519069859(486401/80/51)) read err: read after end of file
file_win32_pread(600,14,buffer,3519069860(486401/80/52)) read err: read after end of file
file_win32_pread(600,14,buffer,3519069861(486401/80/53)) read err: read after end of file
file_win32_pread(600,14,buffer,3519069862(486401/80/54)) read err: read after end of file
file_win32_pread(600,14,buffer,3519069863(486401/80/55)) read err: read after end of file
file_win32_pread(600,14,buffer,3519069864(486401/80/56)) read err: read after end of file
file_win32_pread(600,14,buffer,3519069866(486401/80/58)) read err: read after end of file
file_win32_pread(600,14,buffer,3519069868(486401/80/60)) read err: read after end of file
file_win32_pread(600,14,buffer,3519069870(486401/80/62)) read err: read after end of file
The harddisk (4000 GB / 3726 GiB) seems too small! (< 8001 GB / 7452 GiB)
Incomplete multi sector transfer detected in $MFT.
ntfs_mft_load(): Failed.
$MFT has invalid magic.
Re: GPT Partition Lost Raw Disk
Use ddrescue to duplicate your faulty drive.
