lost ext4 partitions
robbingTM
#1 Post by robbingTM »
Hi all,
I had a spare server with a bunch of storage so I thought I might as well get Ubuntu going on there and use the storage for farming CHIA.
I formatted the drives and created Ext4 volumes and got to plotting.
A few months later, I wanted to use the PC for a test environment so I added another HDD and installed Windows 10 on there and had 1 for Ubuntu, and another disk for Windows.
When in Windows, I wanted to keep the CHIA going so I installed Chia blockchain app but obviously with the partitions on the HDDs being Ext4 Windows didn't natively see them.
I went and took a look in Disk Management and it popped up saying "Do you want to initialize the disks?"
I STUPIDLY said YES. BOOM, within 1-2 seconds all my CHIA plots were gone.
So I calmly went back into Ubuntu and tried to run TestDisk to recover the partitions, but I'm having difficulty in doing so. I have done nothing to the disks except say 'yes' to Windows initialization, so I know the data should still be there, just Windows did it's thing and re-wrote the tables headers or something.
When using TestDisk and analyse the disk, it defaults to type 'none'. It finds the partition / volume named CHIA009 but it disables write because the disk type is 'none'. I'm not sure how to get around this. Could anyone lend a hand please? This isn't critical data but damn, it took me 2 months to plot 722 plots so I'd really appreciate a way to get these back without needing to start over. TIA!
I attach the logs, including the full scan it did. Unfortunately it is clouded somewhat due to old partitions being remnant on there too.
Sun Jul  4 15:41:51 2021
OS: Linux, kernel 5.8.0-59-generic (#66~20.04.1-Ubuntu SMP Thu Jun 17 11:14:10 UTC 2021) x86_64
Compiler: GCC 9.2
ext2fs lib: 1.45.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.1
/dev/sda: LBA, LBA48 support
/dev/sda: size       27344764928 sectors
/dev/sda: user_max   27344764928 sectors
/dev/sdb: size       19532873728 sectors
/dev/sdb: user_max   19532873728 sectors
/dev/sdb: native_max 19532873728 sectors
/dev/sdc: LBA, LBA48 support
/dev/sdc: size       19532873728 sectors
/dev/sdc: user_max   19532873728 sectors
/dev/sdd: LBA, HPA, LBA48, DCO support
/dev/sdd: size       19532873728 sectors
/dev/sdd: user_max   19532873728 sectors
/dev/sdd: native_max 19532873728 sectors
/dev/sde: LBA, HPA, LBA48, DCO support
/dev/sde: size       19532873728 sectors
/dev/sde: user_max   19532873728 sectors
/dev/sde: native_max 19532873728 sectors
/dev/sdf: LBA, HPA, LBA48, DCO support
/dev/sdf: size       19532873728 sectors
/dev/sdf: user_max   19532873728 sectors
/dev/sdf: native_max 19532873728 sectors
/dev/sdg: LBA, HPA, LBA48, DCO support
/dev/sdg: size       19532873728 sectors
/dev/sdg: user_max   19532873728 sectors
/dev/sdg: native_max 19532873728 sectors
/dev/sdh: LBA, HPA, LBA48, DCO support
/dev/sdh: size       19532873728 sectors
/dev/sdh: user_max   19532873728 sectors
/dev/sdh: native_max 19532873728 sectors
Warning: can't get size for Disk /dev/loop11 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop8 - 0 B - 0 sectors (RO), sector size=512
Disk /dev/sda - 14 TB / 12 TiB - CHS 1702132 255 63, sector size=512 - ST14000VN0008-2JG101, S/N:ZHZ2A81G, FW:SC60
Disk /dev/sdb - 10000 GB / 9314 GiB - CHS 1215865 255 63, sector size=512 - HGST HUH721010ALE604, S/N:4DH3N87Z, FW:LHGNW92C
Disk /dev/sdc - 10000 GB / 9314 GiB - CHS 1215865 255 63, sector size=512 - ST10000VN0008-2JJ101, S/N:ZPW0GKTG, FW:SC60
Disk /dev/sdd - 10000 GB / 9314 GiB - CHS 1215865 255 63, sector size=512 - HGST HUH721010ALE604, S/N:4DH9HG4Z, FW:LHGNW92C
Disk /dev/sde - 10000 GB / 9314 GiB - CHS 1215865 255 63, sector size=512 - WDC WD101FZBX-00ATAA0, S/N:VCGNDRKP, FW:01.01A01
Disk /dev/sdf - 10000 GB / 9314 GiB - CHS 1215865 255 63, sector size=512 - HGST HUH721010ALE604, S/N:4DH5XD6Z, FW:LHGNW92C
Disk /dev/sdg - 10000 GB / 9314 GiB - CHS 1215865 255 63, sector size=512 - HGST HUH721010ALE604, S/N:4DH8YKPZ, FW:LHGNW92C
Disk /dev/sdh - 10000 GB / 9314 GiB - CHS 1215865 255 63, sector size=512 - HGST HUH721010ALE604, S/N:4DH9HKMZ, FW:LHGNW92C
Disk /dev/sdi - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - Kingston SNA-DC/U, FW:1.08
Disk /dev/loop0 - 58 MB / 55 MiB - 113504 sectors (RO), sector size=512
Disk /dev/loop1 - 58 MB / 55 MiB - 113544 sectors (RO), sector size=512
Disk /dev/loop10 - 33 MB / 32 MiB - 66120 sectors (RO), sector size=512
Disk /dev/loop2 - 229 MB / 218 MiB - 448496 sectors (RO), sector size=512
Disk /dev/loop3 - 229 MB / 219 MiB - 448512 sectors (RO), sector size=512
Disk /dev/loop4 - 68 MB / 65 MiB - 133320 sectors (RO), sector size=512
Disk /dev/loop5 - 53 MB / 50 MiB - 104360 sectors (RO), sector size=512
Disk /dev/loop6 - 53 MB / 50 MiB - 104360 sectors (RO), sector size=512
Disk /dev/loop7 - 33 MB / 32 MiB - 66104 sectors (RO), sector size=512
Disk /dev/loop9 - 65 MB / 62 MiB - 127160 sectors (RO), sector size=512
Disk /dev/nvme0n1 - 1000 GB / 931 GiB - CHS 953869 64 32, sector size=512
Disk /dev/nvme1n1 - 500 GB / 465 GiB - CHS 476940 64 32, sector size=512
Disk /dev/sda - 14 TB / 12 TiB - ST14000VN0008-2JG101
Partition table type: None
Filesystem created: Sun Jun  6 13:28:50 2021
   P ext4                     0   0  1 1702132 227 47 27344764928 [CHIA009]
     ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 14 TB / 12 TiB
search_superblock
block_group_nr 1
recover_EXT2: s_block_group_nr=1/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
recover_EXT2: s_blocks_count 3418095616
recover_EXT2: part_size 27344764928
Ext2 superblock found at sector 262144 (block=32768, blocksize=4096)
block_group_nr 3
recover_EXT2: s_block_group_nr=3/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
Ext2 superblock found at sector 786432 (block=98304, blocksize=4096)
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
Ext2 superblock found at sector 1310720 (block=163840, blocksize=4096)
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
Ext2 superblock found at sector 1835008 (block=229376, blocksize=4096)
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
Ext2 superblock found at sector 2359296 (block=294912, blocksize=4096)
block_group_nr 25
recover_EXT2: s_block_group_nr=25/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
Ext2 superblock found at sector 6553600 (block=819200, blocksize=4096)
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
Ext2 superblock found at sector 7077888 (block=884736, blocksize=4096)
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
Ext2 superblock found at sector 12845056 (block=1605632, blocksize=4096)
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
Ext2 superblock found at sector 21233664 (block=2654208, blocksize=4096)
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
Ext2 superblock found at sector 32768000 (block=4096000, blocksize=4096)
superblock 32768, blocksize=4096 [CHIA009]
superblock 98304, blocksize=4096 [CHIA009]
superblock 163840, blocksize=4096 [CHIA009]
superblock 229376, blocksize=4096 [CHIA009]
superblock 294912, blocksize=4096 [CHIA009]
superblock 819200, blocksize=4096 [CHIA009]
superblock 884736, blocksize=4096 [CHIA009]
superblock 1605632, blocksize=4096 [CHIA009]
superblock 2654208, blocksize=4096 [CHIA009]
superblock 4096000, blocksize=4096 [CHIA009]
To repair the filesystem using alternate superblock, run
fsck.ext4 -p -b superblock -B blocksize device
dir_partition inode=2
ext2fs_dir_iterate failed with error 2133571387.
New options :
 Dump : No
 Align partition: Yes
 Expert mode : Yes
Analyse Disk /dev/sda - 14 TB / 12 TiB - CHS 1702132 255 63
block_group_nr 1
recover_EXT2: part_offset problem
block_group_nr 1
echo "0 27344764928 linear /dev/sda 0" | dmsetup create test0
Write isn't available because the partition table type "None" has been selected.
block_group_nr 1
block_group_nr 1
block_group_nr 3
block_group_nr 3
block_group_nr 5
block_group_nr 5
block_group_nr 7
block_group_nr 7
block_group_nr 9
block_group_nr 9
block_group_nr 25
block_group_nr 25
block_group_nr 27
block_group_nr 27
block_group_nr 49
block_group_nr 49
block_group_nr 81
block_group_nr 81
block_group_nr 125
block_group_nr 125
block_group_nr 243
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 343
block_group_nr 343
recover_EXT2: "e2fsck -b 11239424 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=343/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 625
block_group_nr 625
recover_EXT2: "e2fsck -b 20480000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=625/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 729
block_group_nr 729
recover_EXT2: "e2fsck -b 23887872 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=729/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
cramfs Marker at 14567/220/63
recover_cramfs
     CramFS               14567 220 63 14584 127 25     267208 [\A6(\A7\866\B3e\8E>,\F54\A3\F8\D3]
     cramfs, 136 MB / 130 MiB
cramfs Marker at 14567/221/1
recover_cramfs
     CramFS               14567 221  1 14584 127 26     267208 [\A6(\A7\866\B3e\8E>,\F54\A3\F8\D3]
     WBFS                 21987  97 35 2294146753 116 23 12939602591481856
     WBFS, 6625076 TB / 6025472 TiB
This partition ends after the disk limits. (start=353227300, size=12939602591481856, end=12939602944709155, disk end=27344764928)
block_group_nr 2187
block_group_nr 2187
recover_EXT2: "e2fsck -b 71663616 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2187/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 2401
block_group_nr 2401
recover_EXT2: "e2fsck -b 78675968 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2401/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
LVM magic value at 44391/194/41
block_group_nr 3125
block_group_nr 3125
recover_EXT2: "e2fsck -b 102400000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=3125/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
     WBFS                 52527  12 24 3365980834  86 46 14543790056407040
     WBFS, 7446420 TB / 6772480 TiB
This partition ends after the disk limits. (start=843847034, size=14543790056407040, end=14543790900254073, disk end=27344764928)
cramfs Marker at 93870/148/59
recover_cramfs
     CramFS               93870 148 59 93912  30 35     667272 [Uf\95\F8\92\D7\CE\FA4\AB'\F3
\E7]
     cramfs, 341 MB / 325 MiB
cramfs Marker at 93870/148/60
recover_cramfs
     CramFS               93870 148 60 93912  30 36     667272 [Uf\95\F8\92\D7\CE\FA4\AB'\F3
\E7]
HFS magic value at 96493/48/36
part_size 957153282
     HFS                  96493  48 36 156073  57 50  957153282
     HFS blocksize=16777216, 490 GB / 456 GiB
HFS magic value at 96493/48/38
part_size 957153282
     HFS                  36913  39 25 96493  48 39  957153282
     HFS found using backup sector!, 490 GB / 456 GiB
block_group_nr 6561
block_group_nr 6561
recover_EXT2: "e2fsck -b 214990848 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=6561/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
     BeFS                 149281  14 61 595377144 176 23 19053189628055504 [1\DA\F5\D2\F4\B2\9C\C1\AF-\8E\AE'"\E2/H\EA\8B-F
\B0,b\87\ED\81]
     BeFS blocksize=2048, 9755233 TB / 8872332 TiB
This partition ends after the disk limits. (start=2398200207, size=19053189628055504, end=19053192026255710, disk end=27344764928)
HFS magic value at 151619/26/52
part_size 865468418
     HFS                  151619  26 52 205492   5 47  865468418
     HFS blocksize=16777216, 443 GB / 412 GiB
HFS magic value at 151619/26/54
part_size 865468418
     HFS                  97746  47 60 151619  26 55  865468418
     HFS found using backup sector!, 443 GB / 412 GiB
LVM magic value at 160373/224/13
HFS magic value at 164049/55/51
part_size 2056454146
     HFS                  164049  55 51 292057 145  6 2056454146
     HFS blocksize=16777216, 1052 GB / 980 GiB
HFS magic value at 164049/55/53
     HFS                  36040 221 36 164049  55 54 2056454146
     HFS found using backup sector!, 1052 GB / 980 GiB
SYSV4 Marker at 212518/212/52
recover_sysv4
     SysV 4               212518 212 52 412441 104 32 3211756172 [\ABfn\BF\BC\F4]
     SysV4, 1644 GB / 1531 GiB
block_group_nr 15625
recover_EXT2: "e2fsck -b 512000000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=15625/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 16807
recover_EXT2: "e2fsck -b 550731776 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=16807/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
HFS magic value at 315655/68/59
part_size 271712258
     HFS                  315655  68 59 332568 146 57  271712258
     HFS blocksize=16777216, 139 GB / 129 GiB
HFS magic value at 315655/68/61
part_size 271712258
     HFS                  298741 246  1 315655  68 62  271712258
     HFS found using backup sector!, 139 GB / 129 GiB
block_group_nr 19683
recover_EXT2: "e2fsck -b 644972544 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=19683/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
cramfs Marker at 329636/216/1
recover_cramfs
     CramFS               329636 216  1 329872  51 52    3780996 [\E7Z\88\D6\A91*\F3\F3pRt\E4]
     cramfs, 1935 MB / 1846 MiB
cramfs Marker at 329636/216/2
recover_cramfs
     CramFS               329636 216  2 329872  51 53    3780996 [\E7Z\88\D6\A91*\F3\F3pRt\E4]
HFS magic value at 338745/88/58
part_size 364052482
     HFS                  338745  88 58 361406 144 46  364052482
     HFS blocksize=16777216, 186 GB / 173 GiB
HFS magic value at 338745/88/60
part_size 364052482
     HFS                  316084  33 10 338745  88 61  364052482
     HFS found using backup sector!, 186 GB / 173 GiB
LVM magic value at 339286/254/49
LVM magic value at 366910/231/50
     BeFS                 372232 229 59 1724019438  77 60 17139355495694336 [\D977\AAG؁\96U\FC\90\D6IӰōlm\82@j\AA~뇗\A4\81\D9\EE!]
     BeFS blocksize=4, 8775350 TB / 7981134 TiB
This partition ends after the disk limits. (start=5979921565, size=17139355495694336, end=17139361475615900, disk end=27344764928)
HFS magic value at 399010/232/38
part_size 2556952578
     HFS                  399010 232 38 558173 216 28 2556952578
     HFS blocksize=33554432, 1309 GB / 1219 GiB
HFS magic value at 399010/232/40
     HFS                  239847 248 51 399010 232 41 2556952578
     HFS found using backup sector!, 1309 GB / 1219 GiB
     Sys=0C               400137 220 49 467185 161 29 1077122384
     FATX, 551 GB / 513 GiB
LVM magic value at 403102/113/56
LVM magic value at 405504/144/36
SYSV4 Marker at 412828/113/54
recover_sysv4
     SysV 4               412828 113 54 488000  81  2 1207636113 [[k\F71\D0H]
     SysV4, 618 GB / 575 GiB
LVM magic value at 452132/62/36
LVM magic value at 483071/227/16
HFS magic value at 515604/60/44
part_size 525991938
     HFS                  515604  60 44 548345 184  4  525991938
     HFS blocksize=67108864, 269 GB / 250 GiB
HFS magic value at 515604/60/46
part_size 525991938
     HFS                  482862 192 24 515604  60 47  525991938
     HFS found using backup sector!, 269 GB / 250 GiB
LVM magic value at 534624/48/25
cramfs Marker at 565911/208/2
recover_cramfs
     CramFS               565911 208  2 566242  90 16    5310095 [\D1)!ԝd\B8\A8\F0\87\C7z\D1R\B6]
     cramfs, 2718 MB / 2592 MiB
cramfs Marker at 565911/208/3
recover_cramfs
     CramFS               565911 208  3 566242  90 17    5310095 [\D1)!ԝd\B8\A8\F0\87\C7z\D1R\B6]
cramfs Marker at 569509/91/3
recover_cramfs
     CramFS               569509  91  3 569777 100 34    4306018 [\C8\F5\8A\A8j\F5j\8D\9B \B7\AE\B5n#\C9]
     cramfs, 2204 MB / 2102 MiB
cramfs Marker at 569509/91/4
recover_cramfs
     CramFS               569509  91  4 569777 100 35    4306018 [\C8\F5\8A\A8j\F5j\8D\9B \B7\AE\B5n#\C9]
LVM magic value at 594692/22/8
     WBFS                 596412  48 57 559891250 219 45 14636698788954112
     WBFS, 7493989 TB / 6815744 TiB
This partition ends after the disk limits. (start=9581361860, size=14636698788954112, end=14636708370315971, disk end=27344764928)
SYSV4 Marker at 623050/131/52
recover_sysv4
     SysV 4               623050 131 52 762078 106 48 2233483242 [\AE\89\D1 ]
     SysV4, 1143 GB / 1065 GiB
SYSV4 Marker at 676859/121/41
recover_sysv4
     SysV 4               676859 121 41 675611514  53 37 79841474838528 [v"t\CE']
     SysV4, 40878 TB / 37179 TiB
This partition ends after the disk limits. (start=10873747498, size=79841474838528, end=79852348586025, disk end=27344764928)
     Sys=0C               686163  44  7 853407  94 60 2686778064
     FATX, 1375 GB / 1281 GiB
     BeFS                 762232 210  2 4120509183  11 51 32012558504296448 [\8B\B6\C4\C1\CD\C6&\B5l\CCl\A4\86^\B9\CD5`\F7HC]
     BeFS blocksize=1, 16390429 TB / 14907009 TiB
This partition ends after the disk limits. (start=12245270311, size=32012558504296448, end=32012570749566758, disk end=27344764928)
LVM magic value at 766094/213/13
SYSV4 Marker at 785065/202/63
recover_sysv4
     SysV 4               785065 202 63 785065 202 62          0 [\8E;~\D2]
     SysV4, 0 B
Partition not added.
HFS magic value at 818711/223/8
part_size 3789815810
     HFS                  818711 223  8 1054616 254 39 3789815810
     HFS blocksize=33554432, 1940 GB / 1807 GiB
HFS magic value at 818711/223/10
     HFS                  582806 191 43 818711 223 11 3789815810
     HFS found using backup sector!, 1940 GB / 1807 GiB
     Sys=0C               837355  53 58 1012223  78 38 2809255976
     FATX, 1438 GB / 1339 GiB
recover_EXT2: s_block_group_nr=0/104312, s_mnt_count=7/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
Last mount time:    Thu Jun 24 09:36:49 2021
     ext4                 850886 243  6 2553019 215 52 27344764928 [CHIA009]
     ext4 blocksize=4096 Large_file Sparse_SB Recover, 14 TB / 12 TiB
This partition ends after the disk limits. (start=13669498904, size=27344764928, end=41014263831, disk end=27344764928)
cramfs Marker at 853815/166/49
recover_cramfs
     CramFS               853815 166 49 853846  39 24     489989 [\908Ȇ\A5\D1\B6\BA\85n\ACY\C1\8D\80]
     cramfs, 250 MB / 239 MiB
cramfs Marker at 853815/166/50
recover_cramfs
     CramFS               853815 166 50 853846  39 25     489989 [\908Ȇ\A5\D1\B6\BA\85n\ACY\C1\8D\80]
     BeFS                 854647 147  6 3318259047 248 58 14681007819063296 [[9N\89\A1\F1\EDP\943\9E\9A\E7\A9\DA a\83\CE\D6$\E4\E8)LZ\D6\C3[]
     BeFS blocksize=128, 7516676 TB / 6836377 TiB
This partition ends after the disk limits. (start=13729913321, size=14681007819063296, end=14681021548976616, disk end=27344764928)
LVM magic value at 900955/161/53
HFS magic value at 903854/147/43
part_size 1241579522
     HFS                  903854 147 43 981139  84  8 1241579522
     HFS blocksize=16777216, 635 GB / 592 GiB
HFS magic value at 903854/147/45
     HFS                  826569 211 18 903854 147 46 1241579522
     HFS found using backup sector!, 635 GB / 592 GiB
LVM magic value at 915189/146/11
block_group_nr 59049
recover_EXT2: "e2fsck -b 1934917632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=59049/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
     Sys=0C               965427 237 19 1133808 153 49 2705035504
     FATX, 1384 GB / 1289 GiB
SYSV4 Marker at 984231/157/21
recover_sysv4
     SysV 4               984231 157 21 1031288  75 23  755965542 [P\BCG\9E+\80]
     SysV4, 387 GB / 360 GiB
cramfs Marker at 988165/172/40
recover_cramfs
     CramFS               988165 172 40 988459  88 20    4717798 [B\99\C3;w,\D5qi\C0\FBhP ]
     cramfs, 2415 MB / 2303 MiB
cramfs Marker at 988165/172/41
recover_cramfs
     CramFS               988165 172 41 988459  88 21    4717798 [B\99\C3;w,\D5qi\C0\FBhP ]
HFS magic value at 1018866/103/57
part_size 35356674
     HFS                  1018866 103 57 1021067  65 59   35356674
     HFS blocksize=16777216, 18 GB / 16 GiB
HFS magic value at 1018866/103/59
part_size 35356674
     HFS                  1016665 141 58 1018866 103 60   35356674
     HFS found using backup sector!, 18 GB / 16 GiB
SYSV4 Marker at 1047298/76/5
recover_sysv4
     SysV 4               1047298  76  5 85946832 241 27 1363911024128 [h(\B5\DB\A0]
     SysV4, 698 TB / 635 TiB
This partition ends after the disk limits. (start=16824847162, size=1363911024128, end=1380735871289, disk end=27344764928)
LVM magic value at 1096006/192/32
cramfs Marker at 1111865/133/43
recover_cramfs
     CramFS               1111865 133 43 1112109 142 15    3920399 [\8D\8F\FFx\CF
c\D8\D72)́	\9AD]
     cramfs, 2007 MB / 1914 MiB
cramfs Marker at 1111865/133/44
recover_cramfs
     CramFS               1111865 133 44 1112109 142 16    3920399 [\8D\8F\FFx\CF
c\D8\D72)́	\9AD]
LVM magic value at 1115083/185/38
LVM magic value at 1136668/139/58
SYSV4 Marker at 1200173/122/61
recover_sysv4
     SysV 4               1200173 122 61 1200173 122 60          0 [\98\8F\E8\E4\A0\D9]
     SysV4, 0 B
     BeFS                 1221455 205 49 3896690030 192  4 11240361939515392 [\F9\A6`CV\B2ǚ\A5>{\9B\8Ac=s\D8,`\EDSTQ\968\8D ]
     BeFS blocksize=524288, 5755065 TB / 5234201 TiB
This partition ends after the disk limits. (start=19622687538, size=11240361939515392, end=11240381562202929, disk end=27344764928)
LVM magic value at 1223147/97/17
LVM magic value at 1234523/83/34
block_group_nr 65535
recover_EXT2: "e2fsck -b 2147450880 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=65535/104312, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
     ext4                 205439 244 52 1907572 217 35 27344764928 [CHIA009]
This partition ends after the disk limits. (start=3300392958, size=27344764928, end=30645157885, disk end=27344764928)
     ext4                 205439 244 54 1907572 217 37 27344764928 [CHIA009]
This partition ends after the disk limits. (start=3300392960, size=27344764928, end=30645157887, disk end=27344764928)
     WBFS                 1277047 248  1 436681842 222 43 6994778030080
     WBFS, 3581 TB / 3257 TiB
This partition ends after the disk limits. (start=20515775679, size=6994778030080, end=7015293805758, disk end=27344764928)
     WBFS                 1343582 104  6 2119147 211 31 12459458492
     WBFS, 6379 GB / 5941 GiB
This partition ends after the disk limits. (start=21584651387, size=12459458492, end=34044109878, disk end=27344764928)
LVM magic value at 1344123/139/46
LVM magic value at 1352311/48/53
SYSV4 Marker at 1354389/61/39
recover_sysv4
     SysV 4               1354389  61 39 1372176  54  3  285747679 [\BFz"\E2L]
     SysV4, 146 GB / 136 GiB
LVM magic value at 1356867/252/52
SYSV4 Marker at 1383160/112/22
recover_sysv4
     SysV 4               1383160 112 22 32396532  31  8 498229816064 [W\EFD8]]
     SysV4, 255 TB / 232 TiB
This partition ends after the disk limits. (start=22220472477, size=498229816064, end=520450288540, disk end=27344764928)
LVM magic value at 1401490/146/21
LVM magic value at 1419323/133/24
SYSV4 Marker at 1429459/16/61
recover_sysv4
     SysV 4               1429459  16 61 284234261  82 60 4543259148288 [Q1-v\D7\E8]
     SysV4, 2326 TB / 2115 TiB
This partition ends after the disk limits. (start=22964259903, size=4543259148288, end=4566223408190, disk end=27344764928)
     Sys=0C               1440538 171 54 1453987  93 58  216053276
     FATX, 110 GB / 103 GiB
SYSV4 Marker at 1465097/25/37
recover_sysv4
     SysV 4               1465097  25 37 3729289707  40 17 197884801581056 [\F0)\B2qy\F4]
     SysV4, 101317 TB / 92147 TiB
This partition ends after the disk limits. (start=23536784916, size=197884801581056, end=197908338365971, disk end=27344764928)
     BeFS                 1479875  59 63 753817942   7 55 31682466482143232 [\BA\D3\F1\AF\C5j\E9s7A\82\A8K\CB\B5\E14\E2\FAw\F4R᳭\81\9D]
     BeFS blocksize=4194304, 16221422 TB / 14753298 TiB
This partition ends after the disk limits. (start=23774195654, size=31682466482143232, end=31682490256338885, disk end=27344764928)
cramfs Marker at 1479910/46/49
recover_cramfs
     CramFS               1479910  46 49 1479917 116 55     116871 [\EA8\87\90\B9\B1N\E0èdt\9E\FD]
     cramfs, 59 MB / 57 MiB
cramfs Marker at 1479910/46/50
recover_cramfs
     CramFS               1479910  46 50 1479917 116 56     116871 [\EA8\87\90\B9\B1N\E0èdt\9E\FD]
     Sys=0C               1485214 103 14 1664905 221 48 2886743384
     FATX, 1478 GB / 1376 GiB
cramfs Marker at 1547997/219/9
recover_cramfs
     CramFS               1547997 219  9 1548089   5 33    1464522 [1\A6\E1\AB\DDRZ\BAsy\C0]
     cramfs, 749 MB / 715 MiB
cramfs Marker at 1547997/219/10
recover_cramfs
     CramFS               1547997 219 10 1548089   5 34    1464522 [1\A6\E1\AB\DDRZ\BAsy\C0]
check_FAT: Unusual, only one FAT
check_FAT: number of bytes per sector mismatches 54635 (FAT) != 512 (HD)
     WBFS                 1652116 149 59 141104174  27 38 3728167376257024
     WBFS, 1908821 TB / 1736063 TiB
This partition ends after the disk limits. (start=26541252985, size=3728167376257024, end=3728193917510008, disk end=27344764928)
LVM magic value at 1655597/172/52
     Sys=0C               1668096  73 40 1921765  76 41 4075192676
     FATX, 2086 GB / 1943 GiB
This partition ends after the disk limits. (start=26797966878, size=4075192676, end=30873159553, disk end=27344764928)
LVM magic value at 1674232/109/17
The harddisk (14 TB / 12 TiB) seems too small! (< 16390436 TB / 14907014 TiB)
\B0,b\87\ED\81]
robbingTM
Re: lost ext4 partitions
#2 Post by robbingTM »
part 3:
Disk /dev/sdd - 10000 GB / 9314 GiB - HGST HUH721010ALE604
Filesystem created: Mon May 10 21:06:17 2021
   P ext4                     0   0  1 1215865  39 46 19532873728 [CHIA007]
     ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 10000 GB / 9314 GiB
search_superblock
block_group_nr 1
recover_EXT2: s_block_group_nr=1/74512, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
recover_EXT2: s_blocks_count 2441609216
recover_EXT2: part_size 19532873728
block_group_nr 3
recover_EXT2: s_block_group_nr=3/74512, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 5
recover_EXT2: s_block_group_nr=5/74512, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 7
recover_EXT2: s_block_group_nr=7/74512, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 9
recover_EXT2: s_block_group_nr=9/74512, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 25
recover_EXT2: s_block_group_nr=25/74512, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 27
recover_EXT2: s_block_group_nr=27/74512, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 49
recover_EXT2: s_block_group_nr=49/74512, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 81
recover_EXT2: s_block_group_nr=81/74512, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
block_group_nr 125
recover_EXT2: s_block_group_nr=125/74512, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=4096
superblock 32768, blocksize=4096 [CHIA007]
superblock 98304, blocksize=4096 [CHIA007]
superblock 163840, blocksize=4096 [CHIA007]
superblock 229376, blocksize=4096 [CHIA007]
superblock 294912, blocksize=4096 [CHIA007]
superblock 819200, blocksize=4096 [CHIA007]
superblock 884736, blocksize=4096 [CHIA007]
superblock 1605632, blocksize=4096 [CHIA007]
superblock 2654208, blocksize=4096 [CHIA007]
superblock 4096000, blocksize=4096 [CHIA007]
Analyse Disk /dev/sdd - 10000 GB / 9314 GiB - CHS 1215865 255 63
block_group_nr 1
block_group_nr 1
echo "0 19532873728 linear /dev/sdd 0" | dmsetup create test0
Disk /dev/sdf - 10000 GB / 9314 GiB - HGST HUH721010ALE604
Filesystem created: Mon May 10 21:05:19 2021
   P ext4                     0   0  1 1215865  39 46 19532873728 [CHIA002]
Analyse Disk /dev/sdf - 10000 GB / 9314 GiB - CHS 1215865 255 63
block_group_nr 1
block_group_nr 1
echo "0 19532873728 linear /dev/sdf 0" | dmsetup create test0
Disk /dev/sdg - 10000 GB / 9314 GiB - HGST HUH721010ALE604
Filesystem created: Mon May 10 21:05:40 2021
   P ext4                     0   0  1 1215865  39 46 19532873728 [CHIA004]
search_superblock
block_group_nr 1
block_group_nr 3
block_group_nr 5
block_group_nr 7
block_group_nr 9
block_group_nr 25
block_group_nr 27
block_group_nr 49
block_group_nr 81
block_group_nr 125
superblock 32768, blocksize=4096 [CHIA004]
superblock 98304, blocksize=4096 [CHIA004]
superblock 163840, blocksize=4096 [CHIA004]
superblock 229376, blocksize=4096 [CHIA004]
superblock 294912, blocksize=4096 [CHIA004]
superblock 819200, blocksize=4096 [CHIA004]
superblock 884736, blocksize=4096 [CHIA004]
superblock 1605632, blocksize=4096 [CHIA004]
superblock 2654208, blocksize=4096 [CHIA004]
superblock 4096000, blocksize=4096 [CHIA004]
Analyse Disk /dev/sdg - 10000 GB / 9314 GiB - CHS 1215865 255 63
block_group_nr 1
block_group_nr 1
echo "0 19532873728 linear /dev/sdg 0" | dmsetup create test0
Disk /dev/sdh - 10000 GB / 9314 GiB - HGST HUH721010ALE604
Filesystem created: Mon May 10 21:05:30 2021
   P ext4                     0   0  1 1215865  39 46 19532873728 [CHIA003]
Analyse Disk /dev/sdh - 10000 GB / 9314 GiB - CHS 1215865 255 63
block_group_nr 1
block_group_nr 1
echo "0 19532873728 linear /dev/sdh 0" | dmsetup create test0
#3 Post by recuperation »
robbingTM wrote: 05 Jul 2021, 12:38 Hi all,
This is unclear. If there is no file system that windows understands, windows will not write there unless you partitino and format it.
Do you remember your partition table type? What's the size of the drive and it's emulated sector size?
You might try setting it to GPT.
Furthermore you did not specify what kind of analysis you did and if you used the "p"-key to check the content of partitions that hade been found.
P.S: By error I suppressed the second part of your posting. Maybe Christophe Grenier is able to repair that fault.
Can you try TestDisk, partition type: None, Advanced, List ?
If you can see your files, try "fsck.ext4 -b 98304 -B 4096 /dev/sda"
robbingTM
#5 Post by robbingTM »
recuperation wrote: 05 Jul 2021, 17:33 This is unclear. If there is no file system that windows understands, windows will not write there unless you partitino and format it.
Yea Windows didn't recognise the volumes as anything so it offered to initialize them like they were new disks. I didn't realise this would alter them like it did.
I have no idea sorry - I used thre built in GUI for Ubuntu to create them. Does native / default Ubuntu EXT4 tell us the answers here at all?
robbingTM
#6 Post by robbingTM »
cgrenier wrote: 05 Jul 2021, 17:44 Can you try TestDisk, partition type: None, Advanced, List ?
I'll give this a shot, and report back my findings. thx for the advice
robbingTM
#7 Post by robbingTM »
I just get the message:
No file found, filesystem may be damaged.
