Cannot write to disk (sector mismatches 4096 (FAT) != 512 (HD))
AleXSR700
#1 Post by AleXSR700 »
Hello everyone,
I was using an SSD with a Raspberry Pi and it suddenly stopped working.
I had some concerns with the case I was using as it was showing a block size of 4096 although I was pretty sure the drive was 512. Anyhow, it worked and worked and now, suddenly, no more.
I replaced the case with a StarTech USB3S2SAT3CB adapter and want to get my drive up and running again- Restoring data would be great, getting the drive to work is more important though.
I ran Testdisk and it seems to recognize everything but I cannot write. I had also tried fdisk from a Knoppix Live DVD which also could not write any changes.
Can anybody help me get the drive up and running again? As I said, if the only way, I don't mind destroying all data just to be able to use the drive again.
Thank you very much :)
Alex
Here is the log
Tue Aug 10 19:55:29 2021
TestDisk 7.2-WIP, Data Recovery Utility, May 2021
OS: Windows 8 (9200)
Compiler: GCC 9.3, Cygwin32 3001.4
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1000150663168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=33554432
Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - SanDisk SDSSDH3 1T00, S/N:20513V803898, FW:415000RL
Disk \\.\PhysicalDrive1 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - ASMT ASM105x, S/N:B0CD87654321
Disk \\.\PhysicalDrive1 - 256 GB / 238 GiB - ASMT ASM105x
Analyse Disk \\.\PhysicalDrive1 - 256 GB / 238 GiB - CHS 31130 255 63
Geometry from i386 MBR: head=25 sector=20
test_FAT()
 1 P FAT32 LBA                0   4  5     4  24 20      65536
sector_size  0
cluster_size 0
reserved     0
fats         0
dir_entries  0
sectors      0
media        00
fat_length   0
secs_track   0
heads        0
hidden       0
total_sect   0
check_part_i386 2 type EE: no test
Invalid FAT boot sector
 2 P EFI GPT                  0   0  2     0   4  4        255
check_FAT: number of bytes per sector mismatches 4096 (FAT) != 512 (HD)
block_group_nr 1
recover_EXT2: s_block_group_nr=1/1907, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 62514432
recover_EXT2: part_size 500115456
Filesystem created: Wed May 19 09:04:42 2021
     Linux                    0  32 33 31130 223  5  500115456
     ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 256 GB / 238 GiB
file_win32_pread(604,8,buffer,500117704(31130/226/17)) read err: read after end of file
file_win32_pread(604,11,buffer,500117751(31130/227/1)) read err: read after end of file
file_win32_pread(604,6,buffer,500117762(31130/227/12)) read err: read after end of file
file_win32_pread(604,8,buffer,500117888(31130/229/12)) read err: read after end of file
file_win32_pread(604,8,buffer,500118016(31130/231/14)) read err: read after end of file
file_win32_pread(604,8,buffer,500118144(31130/233/16)) read err: read after end of file
   * Linux                    0  32 33 31130 223  5  500115456
file_win32_pread(604,2,buffer,264192(16/113/34)) read err: read after end of file
interface_load
 1 * Linux                    0  32 33 31130 223  5  500115456
Change partition type:
   * FAT32                    0  32 33 31130 223  5  500115456
write!
file_win32_pread(604,1,buffer,0(0/0/1)) read err: read after end of file
Partition: Read error
Store new MBR code
file_win32_pwrite(604,1,buffer,0(0/0/1)) write err
Partition: Write error
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
Write error: Can't write new MBR code.
Write error: Can't clear partition table.
Re: Cannot write to disk (sector mismatches 4096 (FAT) != 512 (HD))
When looking at the read and write errors in the log file I assume your SSD is at least partly broken.
Please post your SMART parameters. Extraction is described here:
viewtopic.php?f=5&t=10910
AleXSR700
#3 Post by AleXSR700 »
Good morning,
I apologize for the late reply. I was away fro work for a few days and could not check remotely.
I attached the two files created.
Again, thank you for your help :)
Alex
myreport2.txt
(5.47 KiB) Downloaded 825 times
myreport.txt
(5.47 KiB) Downloaded 1055 times
I can't see something extraordinary in the log file.
With 42 sectors being reallocated I can't tell if that error matters in case of using a SSD, too.
Run a self-test and open a case with your manufacturer.
AleXSR700
#5 Post by AleXSR700 »
How do I run a self-test or what do you mean by that?
The manufacturer does not seem to care. No warranty left, no support. Send it in or dump it. -.-
#6 Post by recuperation »
You would run smartmontools and start a device selftest with the -t parameter
https://linux.die.net/man/8/smartctl
A short introduction to smartmontools can be found here:
