This partition ends after the disk limits (1TB)
filipous
#1 Post by filipous »
Dear Gurus,
I'm facing very similiar situation to http://forum.cgsecurity.org/phpBB3/post ... imit#p3434 , but with different size of disk and I do not know if I can apply the very same steps like in "try folowwing" from http://forum.cgsecurity.org/phpBB3/post ... icky#p1093
If so, what should be the cylinder value?
My disc:
WESTERN DIGITAL WD My Book Essential 1TB Ext. 3.5" USB2.0, 16MB cache (single drive)
Using TestDisk 6.14WIPwin64 on W7 Home.
Log:
Drive H: - 999 GB / 930 GiB - CHS 121515 255 63
BAD_RS LBA=925781040 9747443
FAT32 57627 52 10 322344 7 21 4252675782
This partition ends after the disk limits. (start=925781040, size=4252675782, end=883489525, disk end=1952149504)
The harddisk (999 GB / 930 GiB) seems too small! (< 2651 GB / 2469 GiB)
Thanks a lot for any feedback.
Filip
Re: This partition ends after the disk limits (1TB)
Don't select H: but the physical drive if possible.
filipous
#3 Post by filipous »
UPDATED
Thanks a lot for help. I tried the physical disk deep analyze, it ends with error:
Disk \\.\PhysicalDrive1 - 999 GB / 930 GiB - CHS 121515 255 63
FAT32 57627 84 42 322344 39 53 4252675782
Here is log:
Sun Sep 23 04:18:43 2012
TestDisk 6.14-WIP, Data Recovery Utility, July 2012
Compiler: GCC 4.7, MinGW 3.11
Compilation date: Aug 14 2012 11:59:38
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=999501594624
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Nesprávná funkce.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Nesprávná funkce.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1004795944960
filewin32_getfilesize(\\.\D:) GetFileSize err Nesprávná funkce.
filewin32_setfilepointer(\\.\D:) SetFilePointer err Nesprávná funkce.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=700448768
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=995494985728
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=999500546048
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=5500665856
Disk \\.\PhysicalDrive0 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 999 GB / 930 GiB - CHS 121515 255 63, sector size=512
Drive C: - 1004 GB / 935 GiB - CHS 122159 255 63, sector size=512
Drive F: - 700 MB / 668 MiB - CHS 167 64 32, sector size=2048
Drive G: - 995 GB / 927 GiB - CHS 121028 255 63, sector size=512
Drive H: - 999 GB / 930 GiB - CHS 121515 255 63, sector size=512
Drive J: - 5500 MB / 5245 MiB - CHS 1311 64 32, sector size=2048
Analyse Disk \\.\PhysicalDrive1 - 999 GB / 930 GiB - CHS 121515 255 63
NTFS at 0/32/33
 1 * HPFS - NTFS              0  32 33 121515 207 36 1952149504 [My Book]
Failed to read index block: Input/output error.
NTFS at 0/32/33
filesystem size           1952149504
sectors_per_cluster       8
mftmirr_lcn               122009343
clusters_per_mft_record   -10
     NTFS, blocksize=4096, 999 GB / 930 GiB
dir_partition inode=5
file_win32_pread(92,16,buffer,3615408(225/12/28)) read err: read after end of file
file_win32_pread(92,1,buffer,3615408(225/12/28)) read err: read after end of file
ntfs_readdir failed
       5 dr-xr-xr-x     0      0         0 21-Aug-2012 11:55 .
       5 dr-xr-xr-x     0      0         0 21-Aug-2012 11:55 ..
NTFS at 0/32/33
BAD_RS LBA=925783088 9747443
This partition ends after the disk limits. (start=925783088, size=4252675782, end=883491573, disk end=1952151552)
NTFS at 121515/207/36
     NTFS found using backup sector, blocksize=4096, 999 GB / 930 GiB
All ideas and hints are really apreciated.
Thanks and have a good rest of weekend.
Filip
filipous
#4 Post by filipous »
I really feel that my issue is similiar to
and
but I do not know what should be the number of cylinders for my 1TB WD harddisk.
Can somebody support me?
Cheers, Filip
