Windows XP64 - unbootable_boot_volume BSOD
Apex
#1 Post by Apex »
Main PC decided to reboot randomly and ever since i've been getting the above BSOD.
PC would not boot into safe mode etc bombs out with the BSOD.
Finally tracked my install cd and attempted to boot the computer to run a chkdsk / fix mbr etc but each time the machine would blue screen at the end of the windows blue txt setup part so could not get to recovery console.....
Finally fixed that issue (have to set sata ports to ide mode from AHCI mode :s )
Now boots past that bit but i am now greeted with something very worrying; my primary partition is seen by the windows setup but it does not reconise the format of the disk and says it's empty / raw (i know it's not empty)
The disk is now a slave disk (installed win7 to a new disk) - i have copied all the data i need off the two partitions that are reconised but i still need to fix the first primary boot.
The disk is a 2TB disk with a 80GB primary NTFS boot partition then the rest is a extended partition with a 80GB "Backup" NTFS formated partition and then the remainder of the disk set aside for Games and Apps again NTFS formated
Test disk sees all three partitons "WinXP" "Backup" "Apps" on the slave disk what that means i don't know.
attached is the testdisk log.
Hope you can help
Drew
Apex
Re: Windows XP64 - unbootable_boot_volume BSOD
#2 Post by Apex »
I would have attached the log file but for some reason the system will not allow .txt or .log files so heres the output from the log file.
Sun Aug 26 11:50:18 2012
TestDisk 6.14-WIP, Data Recovery Utility, July 2012
Compiler: GCC 4.7, MinGW 3.11
Compilation date: Aug 14 2012 11:59:38
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1000097185792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=85896566784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=85896566784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1828603090944
Disk \\.\PhysicalDrive0 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Drive C: - 1000 GB / 931 GiB - CHS 121588 255 63, sector size=512
Drive E: - 85 GB / 79 GiB - CHS 10442 255 63, sector size=512
Drive G: - 1828 GB / 1703 GiB - CHS 222314 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive0 - 2000 GB / 1863 GiB - CHS 243201 255 63
NTFS at 0/1/1
Info: size boot_sector 167766729, partition 167766732
NTFS at 10443/1/1
NTFS at 20886/1/1
Info: size boot_sector 3571490409, partition 3571490412
get_geometry_from_list_part_aux head=255 nbr=10
 1 * HPFS - NTFS              0   1  1 10442 254 63  167766732 [WinXP]
 2 E extended LBA         10443   0  1 243200 254 63 3739257270
 5 L HPFS - NTFS          10443   1  1 20885 254 63  167766732 [Backup]
   X extended             20886   0  1 243200 254 63 3571490475
 6 L HPFS - NTFS          20886   1  1 243200 254 63 3571490412 [Apps]
pread: Input/output error
Failed to calculate number of free clusters: Input/output error.
NTFS at 0/1/1
filesystem size           167766729
sectors_per_cluster       8
mft_lcn                   2
mftmirr_lcn               5789357
clusters_per_mft_record   -10
     HPFS - NTFS              0   1  1 10442 254 60  167766729 [WinXP]
     NTFS, blocksize=4096, 85 GB / 79 GiB
NTFS at 10443/1/1
mft_lcn                   2
mftmirr_lcn               1616558
     HPFS - NTFS          10443   1  1 20885 254 60  167766729 [Backup]
NTFS at 20886/1/1
filesystem size           3571490409
mft_lcn                   2
mftmirr_lcn               78543111
     HPFS - NTFS          20886   1  1 243200 254 60 3571490409 [Apps]
     NTFS, blocksize=4096, 1828 GB / 1703 GiB
file_win32_pread(88,16,buffer,46161439(2873/106/17)) read err: read after end of file
file_win32_pread(88,16,buffer,46161447(2873/106/25)) read err: read after end of file
file_win32_pread(88,1,buffer,46161447(2873/106/25)) read err: read after end of file
dir_partition inode=5
       5 dr-xr-xr-x     0      0         0  8-Aug-2012 16:11 .
       5 dr-xr-xr-x     0      0         0  8-Aug-2012 16:11 ..
    8050 -r--r--r--     0      0         0 21-Nov-2009 09:39 AUTOEXEC.BAT
    4175 -r--r--r--     0      0     47772 25-Mar-2005 11:00 NTDETECT.COM
   23262 -r--r--r--     0      0     65526  8-Oct-2011 13:26 1020.log
    1890 dr-xr-xr-x     0      0         0 17-Mar-2012 21:39 AMD
   58323 -r--r--r--     0      0       262 29-Jun-2012 07:28 boot.ini
   11027 dr-xr-xr-x     0      0         0 31-Jul-2012 21:10 Config.Msi
    8049 -r--r--r--     0      0         0 21-Nov-2009 09:39 CONFIG.SYS
    5731 dr-xr-xr-x     0      0         0 14-Jul-2012 00:26 Crash
   43953 dr-xr-xr-x     0      0         0 29-Feb-2012 23:55 cygdrive
   61351 -r--r--r--     0      0   1681442 17-Sep-2010 18:37 Default.m3u
    4380 dr-xr-xr-x     0      0         0 25-May-2012 02:10 Documents and Settings
   19288 dr-xr-xr-x     0      0         0 11-Dec-2009 22:32 GTK
     886 dr-xr-xr-x     0      0         0 28-Apr-2011 17:14 Intel
    8051 -r--r--r--     0      0         0 21-Nov-2009 09:39 IO.SYS
   12164 -r--r--r--     0      0     12697  8-Oct-2011 13:29 M1319.log
    8052 -r--r--r--     0      0         0 21-Nov-2009 09:39 MSDOS.SYS
   10694 dr-xr-xr-x     0      0         0 27-May-2011 16:17 MSOCache
    4174 -r--r--r--     0      0    297072 21-Nov-2009 10:45 ntldr
   11044 dr-xr-xr-x     0      0         0 26-Nov-2011 12:29 O2003updates
   11284 dr-xr-xr-x     0      0         0 26-Nov-2011 12:42 Office2003
   34060 -r--r--r--     0      0     13030 25-Oct-2011 18:52 PDOXUSRS.NET
    4571 dr-xr-xr-x     0      0         0 24-Jun-2012 16:38 Program Files
    4575 dr-xr-xr-x     0      0         0 26-Jul-2012 20:37 Program Files (x86)
   17392 dr-xr-xr-x     0      0         0 21-Nov-2009 10:58 RECYCLER
    4377 dr-xr-xr-x     0      0         0 17-Mar-2012 21:56 System Volume Information
   12479 dr-xr-xr-x     0      0         0 25-Oct-2011 18:49 TIS
   43930 dr-xr-xr-x     0      0         0 24-Jun-2012 17:26 tmp
      28 dr-xr-xr-x     0      0         0  4-Aug-2012 15:25 WINDOWS
      28 -r--r--r--     0      0        24  4-Aug-2012 15:25 WINDOWS:6CE9E8CA9FEB2EF0
       5 dr-xr-xr-x     0      0         0 25-Aug-2012 22:20 .
       5 dr-xr-xr-x     0      0         0 25-Aug-2012 22:20 ..
    6234 dr-xr-xr-x     0      0         0 25-Aug-2012 22:07 $RECYCLE.BIN
    4577 dr-xr-xr-x     0      0         0  2-Aug-2012 01:02 Cache
     853 dr-xr-xr-x     0      0         0 22-Nov-2009 09:36 CD Burning
     854 dr-xr-xr-x     0      0         0  9-Aug-2011 16:11 Drivers
   17854 dr-xr-xr-x     0      0         0 23-Nov-2009 11:13 Garmin
      30 dr-xr-xr-x     0      0         0 21-Nov-2009 10:58 RECYCLER
      27 dr-xr-xr-x     0      0         0 17-Mar-2012 21:56 System Volume Information
    1602 dr-xr-xr-x     0      0         0  8-Aug-2012 16:11 Temp
   24630 dr-xr-xr-x     0      0         0 26-May-2012 00:46 Temporary Internet Files
    1601 -r--r--r--     0      0      6029 27-Apr-2007 14:22 UNWISE.INI
   13238 dr-xr-xr-x     0      0         0 25-Aug-2012 22:07 $RECYCLE.BIN
     198 dr-xr-xr-x     0      0         0 21-Nov-2009 12:17 d12861324f8f50660fa8
      36 dr-xr-xr-x     0      0         0 27-Jul-2012 01:31 Games
   44387 dr-xr-xr-x     0      0         0 29-Feb-2012 00:28 MapSource
      37 dr-xr-xr-x     0      0         0 21-Nov-2009 13:02 msdownld.tmp
      35 dr-xr-xr-x     0      0         0 27-Jun-2012 21:28 Program Files
   46155 dr-xr-xr-x     0      0         0 19-Jul-2012 23:11 Program Files (x86)
      31 dr-xr-xr-x     0      0         0 21-Nov-2009 10:58 RECYCLER
add_ext_part_i386: max
add_ext_part_i386: min
write_all_log_i386: CHS: 10443/0/1,lba=167766795
write_all_log_i386: CHS: 20886/0/1,lba=335533590
#3 Post by cgrenier »
Try to copy your most valuable files using TestDisk.
As it looks like the disk contains bad sectors, the best solution remains to clone the disk to a new empty one as described in http://www.cgsecurity.org/wiki/Damaged_Hard_Disk
Good luck
