When talking about trying "this option" I was refering to "Rebuild BS".recuperation wrote: 04 Dec 2021, 11:09 As I can't tell you which differences exist between a Bitlocker partition and an unencrypted one I can't tell you if the backup boot sector may be different from the boot sector due to encryption.
You can try this option after backing up your boot sector to see if that gives you acces to your partition.
After doing so and rebooting/disconnecting and reconnecting your drive you can then try if your are able to open your encrypted Bitlocker partition.
The "p"-key (list files) cannot work with encrypted information.
Therefore Testdisk can't show you the content inside.
