Undelete files from an exFAT SD card
oxon
#1 Post by oxon »
I am trying to undelete some photo and movie files from a 128 GB SD card which is formatted with exFAT. I can recover a part of them by using PhotoRec, but due to filename loss in PhotoRec, I would like to try TestDisk as well.
When I list the photo and movie directory on the card, namely /DCIM/100CANON for Canon cameras, the error message "No file found, filesystem may be damaged." is shown.
 1 P HPFS - NTFS                32768  241729535  241696768
Directory /DCIM/100CANON
Use Left arrow to go back, Right to change directory, h to hide deleted files
    q to quit, : to select the current file, a to select all files
    C to copy the selected files, c to copy the current file
Is TestDisk able to list deleted files on exFAT? The document says yes, but my files, which can be recovered by PhotoRec, are not listed.
Re: Undelete files from an exFAT SD card
Please post your Testdisk logfile.
oxon
#3 Post by oxon »
Wed Mar  2 15:59:23 2022
OS: Darwin, kernel 21.3.0 (Darwin Kernel Version 21.3.0: Wed Jan  5 21:37:58 PST 2022; root:xnu-8019.80.24~20/RELEASE_X86_64) x86_64
Compiler: GCC 4.2
ext2fs lib: none, ntfs lib: none, reiserfs lib: none, ewf lib: none, curses lib: ncurses 5.7
Disk /dev/disk2 - 123 GB / 115 GiB - 241729536 sectors (RO), sector size=512
Disk /dev/rdisk2 - 123 GB / 115 GiB - 241729536 sectors (RO), sector size=512
Media is opened in read-only.
Disk /dev/rdisk2 - 123 GB / 115 GiB (RO)
Analyse Disk /dev/rdisk2 - 123 GB / 115 GiB - 241729536 sectors (RO)
BAD_RS LBA=32768 20
get_geometry_from_list_part_aux head=1 nbr=2
     exFAT, blocksize=131072, 123 GB / 115 GiB
Warning: the current number of heads per cylinder is 1 but the correct value may be 128.
   * HPFS - NTFS                32768  241729535  241696768
dir_partition inode=0
     130 drwxr-xr-x     0      0    131072  9-Feb-2022 07:45 DCIM
     131 drwxr-xr-x     0      0    131072  9-Feb-2022 07:45 MISC
       5 drwxr-xr-x     0      0    131072  1-Mar-2022 20:55 .fseventsd
dir_partition inode=130
Directory /DCIM
     132 drwxr-xr-x     0      0    131072  9-Feb-2022 07:45 100CANON
     133 drwxr-xr-x     0      0    131072  9-Feb-2022 07:45 CANONMSC
dir_partition inode=132
Directory /DCIM
Directory /DCIM
Directory /DCIM
SIGINT detected! TestDisk has been killed.
oxon
#4 Post by oxon »
Thank you for your help. The card was initialized by Canon EOS R5. I did not see any card error or damage so far while shooting photos and copying them to a Mac. I just want to recover some photos that I accidentally deleted.
#5 Post by recuperation »
If the directory entries on your SDcard have been overwritten since you deleted the pictures Testdisk can't help you. The fact that you can only recover some parts of your deleted files underline my assumption.
oxon
#6 Post by oxon »
I did not intentionally change the directory structure but macOS automatically updated the /.fseventsd directory when I connected the card to my Mac. Does it also affect on the file listing in other directories?
$ ls -la /Volumes/EOS_DIGITAL
total 1024
drwxrwxrwx  1 oxon  staff  131072 Jan  1  1980 .
drwxr-xr-x  9 root  wheel     288 Mar  2 14:55 ..
drwxrwxrwx  1 oxon  staff  131072 Mar  2 14:55 .fseventsd
drwxrwxrwx  1 oxon  staff  131072 Feb  9 07:45 DCIM
drwxrwxrwx  1 oxon  staff  131072 Feb  9 07:45 MISC
#7 Post by recuperation »
The clusters used by your deleted files have been freed upon deletion.
Any succeeding write process can lead to them used by other new files.
If you deleted your files in one subdirectory and your operating system was writing to another one, then the subdirectory entries should be still there but the clusters they point to may already be used by other files.
oxon
#8 Post by oxon »
Would it really happen? There were ~1000 files in that directory, /DCIM/100CANON, but all the deleted files become invisible to TestDisk even by adding a single tiny file?
#9 Post by recuperation »
oxon wrote: 02 Mar 2022, 17:58 Would it really happen? There were ~1000 files in that directory, /DCIM/100CANON, but all the deleted files become invisible to TestDisk even by adding a single tiny file?
I explained the mechanism to you. There is nothing to add. Terms like "1000 files" and "single tiny file" are completely meaningless. I don't explain why, I think that is too obvious.
oxon
#10 Post by oxon »
Thank you for your explanation, but I do not still understand the mechanism.
On exFAT or FAT32 SD cards used in digital cameras, deleted files can be undelete by TestDisk in many cases even after taking additional photos on the same card. Because taking several photos (~100 MB) cannot overwrite whole deleted photos.
Similarly, automatic generation of /.fseventsd that uses less than 1 MB by macOS will not entirely overwrite the deleted photos that are more than 20 GB. That's why a part of the 20 GB data can be recovered by PhotoRec.
Does your mechanism happen only when adding a new directory?
The directory structure is as follows. Photo and movie files are stored in /DCIM/100CANON.
/.fseventsd
/.fseventsd/fseventsd-uuid
/DCIM
/DCIM/100CANON
/DCIM/CANONMSC
/MISC
