TestDisk write operation damaged my disk
MPSEEMA
#1 Post by MPSEEMA »
I ran Testdisk for the first time on my 500 GB internal hard disk which was not mounting on linux , but all partitions were clearly visible in GPARTED and test disk and I could see all my files also in all those partitions using Test Disk by pressing the 'P" key. Once having confirmed all the partitions and files were correct, I entered the write operation of Test Disk to populate the partition table. But after rebooting the system, now my partitions are not coming in GPARTED. even Test Disk is throwing innumerable read errors and taking ages to complete, whereas in the first run, it took few minutes. Has the write ooperation corrupted my disk? How to recover the files and folders now?
Has write operation of Test disk corrupted the files and folders in that partition?
Re: TestDisk write operation damaged my disk
MPSEEMA wrote: 26 Mar 2022, 11:30 I ran Testdisk for the first time on my 500 GB internal hard disk which was not mounting on linux , but all partitions were clearly visible in GPARTED and test disk and I could see all my files also in all those partitions using Test Disk by pressing the 'P" key. Once having confirmed all the partitions and files were correct, I entered the write operation of Test Disk to populate the partition table.
If your partitions were visible in GParted there was no reason to rewrite the partition table.
It seems that your drive is about to die. A write operation only overwrites approximately one sector per incorrectly selected partition when being in MBR mode.
You can try to duplicate the drive as described in the manual or consult a professional recovery service.
No.
alexx
#3 Post by alexx »
You should check the SMART status of the drive to see if it's ok on the hardware side.
If SMART indicates any problems then be very careful as any further operations could make things worse and it should go to a lab.
If SMART shows no problems than it's likely a software problem and you should do some file recovery.
The write operations that Testdisk does only involve a small amount of data and do not format so the files should still be on there and hopefully retrievable.
