Lost partition after partition resize
scramblerdoodle
#1 Post by scramblerdoodle »
Hi, everyone.
I have a dual-boot with Ubuntu 20.04 / Windows 10 on a 256 GB SSD.
Yesterday I had to resize their respective partitions (previously being about 150GB to Windows 10, and 50 GB to Ubuntu -- in hindsight, a very silly partition given how much I use Ubuntu, but that's besides the point) to a new size of about 100 GB each (details below).
The resizing for the Windows part ran without issue using Windows' own Disk Management software. The problem happened when I booted up a LiveUSB with Ubuntu to run GParted. I'm also assuming that the LiveUSB installation was corrupted, as I lost all GUI and began having some PCIexpress error messages pop up (not the first time that had happened with this LiveUSB). Either way, I ended up restarting my computer, so the resize was forcefully stopped.
I then re-installed Ubuntu on the LiveUSB, alongside TestDisk, and here's the log from TestDisk's Deeper Search:
     MS Data                     2048    1050623    1048576 [NO NAME]
     FAT32, blocksize=4096, 536 MB / 512 MiB
     MS Data                     2054    1050629    1048576 [NO NAME]
     MS Data                    32768  291868671  291835904 [SSD]
     NTFS, blocksize=4096, 149 GB / 139 GiB
     MS Data                    32768  402460664  402427897 [SSD]
     NTFS found using backup sector, blocksize=4096, 206 GB / 191 GiB
     MS Data                    32775  402460671  402427897
     MS Data                  1266139    1272312       6174
     MS Data                  1272312    1278485       6174 [Boot]
     MS Data                  1272331    1278504       6174
     MS Data                  1278504    1284677       6174 [Boot]
     MS Data                  1278523    1284696       6174
     MS Data                  1284696    1290869       6174 [Boot]
     MS Data                  1284715    1290888       6174
     MS Data                  1290888    1297061       6174 [Boot]
     MS Data                  3003419    3009592       6174
     MS Data                  3009592    3015765       6174 [Boot]
     EFI System              48507712   48510591       2880 [EFI System Partition] [EFISECTOR]
     EFI System              59506240   59509119       2880 [EFI System Partition] [EFISECTOR]
     EFI System              60771232   60774111       2880 [EFI System Partition] [EFISECTOR]
     EFI System              61150648   61153527       2880 [EFI System Partition] [EFISECTOR]
     EFI System              63012280   63015159       2880 [EFI System Partition] [EFISECTOR]
     EFI System              63828032   63830911       2880 [EFI System Partition] [EFISECTOR]
     Linux filesys. data     64561009   65932992    1371984 [GW<B9><A4>ث݊<BD><CD>(b<9E>dS<DC>]
     cramfs, 702 MB / 669 MiB
     Linux filesys. data     64561010   65932993    1371984 [GW<B9><A4>ث݊<BD><CD>(b<9E>dS<DC>]
     Mac HFS                287598822  421816551  134217730
     HFS found using backup sector!, 68 GB / 64 GiB
     Linux filesys. data    291868670  500116917  208248248
     ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 106 GB / 99 GiB
     Linux filesys. data    291868672  500116919  208248248
     ext4 blocksize=4096 Large_file Sparse_SB, 106 GB / 99 GiB
     Linux Swap             292147192  292147207         16
     SWAP2 version 0, pagesize=8192, 8192 B
     Linux Swap             292147200  296341487    4194288
     SWAP2 version 1, pagesize=4096, 2147 MB / 2047 MiB
     Linux filesys. data    402460670  500116917   97656248
     ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 49 GB / 46 GiB
     Linux filesys. data    402460672  500116919   97656248
     ext4 blocksize=4096 Large_file Sparse_SB, 49 GB / 46 GiB
     Linux Swap             402739192  402739207         16
     Linux Swap             402739200  406933487    4194288
     MS Data                461564603  461567482       2880 [NO NAME]
     MS Data                461564627  461567506       2880 [NO NAME]
     MS Data                461565483  461568362       2880 [NO NAME]
I had a lot more info on my original post, such as the specific sectors allocated to each section according to parted, as well as some personal findings (I'm able to see which partitions found by TestDisk correspond to my old ones, which correspond to my new ones, etc).
My biggest question is: is it worth it trying to restore the old partitions in order to try and properly resize the partition? Or should I cut my losses and get a fresh Ubuntu install, given as I did save a backup before doing all of this?
I also had a few more questions, mostly to learn more, but they also have been lost to time. I do remember one of them, though: the MSR partition does not seem to be found by TestDisk. Should I add it manually (again, a priori I know exactly which sectors belong to it) or is that generally a bad idea?
P.S.: smartmontools shows no problems with the SDD, as evidenced by:
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.13.0-30-generic] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:     LITEON CV3-8D256-HP
Serial Number:    0018152000CD
LU WWN Device Id: 5 002303 1011a1c09
Firmware Version: V381
User Capacity:    256,060,514,304 bytes [256 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    Solid State Device
Form Factor:      M.2
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-4, ATA/ATAPI-7 T13/1532D revision 4a
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Apr  3 07:51:22 2022 UTC
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x02)	Offline data collection activity
					was completed without error.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(   10) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					command.
					Self-test supported.
					No Conveyance Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 (  10) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   100   100   050    Pre-fail  Always       -       0
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       1502
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       1639
171 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
172 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
173 Unknown_Attribute       0x0032   099   099   005    Old_age   Always       -       33
174 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       81
176 Erase_Fail_Count_Chip   0x0022   100   100   000    Old_age   Always       -       0
181 Program_Fail_Cnt_Total  0x0022   100   100   000    Old_age   Always       -       0
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x003b   100   100   097    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       64 (Min/Max 28/65)
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
241 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       361702
242 Total_LBAs_Read         0x0032   100   100   000    Old_age   Always       -       532968
243 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       528832
SMART Error Log Version: 0
No Errors Logged
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%         3         -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Completed [00% left] (0-65535)
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Re: Lost partition after partition resize
After the failure of the Live USB you started your Windows installation successfully. What about the linux installation?
You are now talking about a SSD whereas you mentioned a hybrid SSD in the posting I disapproved. The one in the smartmontools log file is just a M.2 SSD and not a hybrid one.
Please explain!
scramblerdoodle
#3 Post by scramblerdoodle »
The Windows partition was resized with no issue whatsoever. If I override the boot I can easily access it.
The Linux installation got completely destroyed -- no boot, only a couple of the files that were on the old partition got copied to the new resized one.
Maybe there was a misunderstanding at some point, but I currently have two disks on my computer: sda being an HDD that I use mostly to keep files, that's working as intended, whereas sdb is the M.2 SDD where I keep the operating systems. I mentioned the HDD to ask if I would be able to copy the files from the old partition onto this other HDD.
I would simply reinstall linux.
As for the Microsoft reserved partition, Testdisk will show it if its exists.
As your Windows runs fine even without its existence there is no need to fool around with the disk.
scramblerdoodle
#5 Post by scramblerdoodle »
Yeah, that's what I was just thinking. Given that the rest of the disk seems to work fine, I was afraid of messing around with it and destroying Windows' installation as well.
Luckily I ran a personal backup before all of this and, even if I hadn't, thanks to the tool I would've been able to recover my files.
This was mostly a learning endeavor rather than a necessity, as I was hoping to understand exactly what was going on with my SSD, but I suppose I can let it go since overall it's working fine.
Alright, that's good enough for me.
Cheers, and thanks for the attention!
#6 Post by recuperation »
I forgot to say:
Always completely shut down your operating system in a dual-boot environment.
