Partition table lost testdisk finds but will not write it back
jc179
#1 Post by jc179 »
Hi everyone
Looking for some help for a recent blunder I had.
I dd image an old unix disk ( i386 PrimOS ) to a file ( dd if=/dev/sdc of=oldmaxtor.dd ), and didn't check it after doing so, original disk was wiped out, and I am trying to write the image back to a new disk.
fdisk -l oldmaxtor.dd shows nothing, nor does writing it back to the actual disk (in terms of a visible partition structure).
I ran testdisk on the oldmaxtor.dd file
>Disk oldmaxtor.dd - 259 MB / 247 MiB
...and the only menu selection which can find the old partition structure I want to restore is: [None ] Non partitioned media
When I scan the disk with [None ] Non partitioned media -> Quick Search -> Enter to continue -> Deeper Search, I am presented the following;
Disk oldmaxtor.dd - 259 MB / 247 MiB - CHS 32 255 63
>P SysV 4                   0   6  9     1 197 62      28152
 P SysV 4                   5 130 54    31 118 17     416898 [usr]
I want to write this back to the disk! but... cannot as testdisk says "Write isn't available because the partition table type "None" has been selected."
So, since this was an i386 disk, I went back to select disk -> [Intel ] -> Analyze -> Quick search -> Enter -> Deeper Search and get
So I hit "A" to add, and entered in start cyl0, head 6, sector 9, and end on
  No partition             0   6  9     1 197 62      28152
 [Cylinder]  [  Head  ]  [ Sector ]  [Cylinder]  [  Head  ]  [ Sector ]
>[  Type  ]  [  Done  ]
                             Change partition type
I set the partition type to Linux for now, until I can figure out what that was, but I am presented with this screen just before writing the changes... and for some reason I have a EXTended listed first - What!?
 1 E extended                 0   1  1     1 254 63      32067    <- Uh, where'd that come from ?
 5 L Linux                    0   6  9     1 197 62      28152   <- why is this part #5, I want to do part #1
Any ideas how I can restore this properly ?
I have tried to recreate the partitions with fdisk, but those don't seem to quite line up!
thanks for any help!
Jonathan
Re: Partition table lost testdisk finds but will not write it back
jc179 wrote: 20 Apr 2022, 22:57 Hi everyone
The parameter -l does not write anything. It just lists an existing table or do I get something wrong?
>[  Type  ]  [  Done  ]
The number 1,2,3 and 4 are reserved for primary partitions.
You did not document what you did when writing using fdisk.
Why are you using an outdated version of Testdisk?
jc179
#3 Post by jc179 »
Ah, sorry it is probably my communication here - Yes, "fdisk -l" only prints the existing partition table, that is all I was trying to show, is that fdisk -l ddfile does not print (or recognize ) the partition table... : ( I did not make any 'writes' to this image with fdisk at all. I don't know what to write, as the output from testdisk appears to be cyl-heads-sectors, which I do not know how to translate to starting cylinder or sector to even try partitioning in fdisk.
Yes, I want to put back primary partition #1 and Primary partition #2 as shown here :
P SysV 4 0 3 8 28 6 9 14076
SysV4, 14 MB / 13 MiB
P SysV 4 89 2 17 509 4 21 208449 [usr]
SysV4, 213 MB / 203 MiB
to clarify, I did not write anything with fdisk - see above answer on that..
I didn't realize my testdisk version was so old, will update that! thanks !
