Writed wrong partition at wrong sector start, would like to go back..
Dragomitch
#1 Post by Dragomitch »
Hello there !
First of all, I've seen that recuperation is the most active user on there in question of helping others. For that, bigg kuddos mate !
I've a problem about 2 disks... The second one that I caused stupidly. First one that has sectors and harware problems that I'm trying to retrieve all the files for a friend.
Doing so, I started by trying to testdisk it, see if it was not only a problem of partitions or something that testdisk could fix fast.... Which was not ( as said above ) it is really a hardware problem. So I wanted to dd it as a backup first ( and finished by doing it through ddrescue because dd had also problems).
There, I did a mistake when specifying the end destination folder ... And ended "trying" to restore it to /dev/sdd/ which I cancelled quiet instantly realizing the mistake. Nonetheless, it did make the drive on which I was doing the copy corrupt ( or at least the FS table ).
So I did the ddrescue on another disk, because I knew it will take time etc etc. Long story short, now, I would like to fix it.
So stupidly skipped the backup part for my own disk, so I dont have any about that. But I've the logs where we have the correct description about the FS and was able to see the files also. There is the log of that:
Disk /dev/sdd - 1000 GB / 931 GiB - WD My Passport 0820
Partition table type: EFI GPT
Analyse Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121597 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953458175 (expected 1953458175)
hdr_lba_start=34
hdr_lba_end=1953458142
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Data                     2048 1953456127 1953454080 [Elements SE]
     exFAT, blocksize=262144, 1000 GB / 931 GiB
NTFS at 121597/37/40
filesystem size           1953456128
sectors_per_cluster       8
mftmirr_lcn               122091007
clusters_per_mft_record   -10
     MS Data                     2048 1953458175 1953456128 [My Passport]
     NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
echo "0 1953454080 linear /dev/sdd 2048" | dmsetup create test0
echo "0 1953456128 linear /dev/sdd 2048" | dmsetup create test1
dir_partition inode=5
       5 dr-xr-xr-x     0      0         0 31-May-2022 13:37 .
       5 dr-xr-xr-x     0      0         0 31-May-2022 13:37 ..
    2895 dr-xr-xr-x     0      0         0 12-Jan-2022 09:13 $RECYCLE.BIN
   75150 dr-xr-xr-x     0      0         0 29-Jul-2016 12:16 .minidlna
      45 dr-xr-xr-x     0      0         0 13-May-2022 04:00 Formations
      64 dr-xr-xr-x     0      0         0 31-May-2022 13:42 SaveOldDDCaroline
      27 dr-xr-xr-x     0      0         0 14-May-2016 10:15 System Volume Information
      44 dr-xr-xr-x     0      0         0 12-Jan-2022 11:34 Videos Surveillance
   84583 dr-xr-xr-x     0      0         0 11-Jul-2017 15:33 msdownld.tmp
   74757 dr-xr-xr-x     0      0         0 12-Jan-2022 11:19 zzz_NewDownloads
dir_partition inode=74757
Directory /zzz_NewDownloads
   74757 dr-xr-xr-x     0      0         0 12-Jan-2022 11:19 .
   84584 dr-xr-xr-x     0      0         0 25-Sep-2016 09:14 Greys Anatomy
   84132 dr-xr-xr-x     0      0         0  9-May-2020 09:58 Jeux
   86573 dr-xr-xr-x     0      0         0  9-May-2020 09:58 Magazines
   84037 dr-xr-xr-x     0      0         0  9-May-2020 10:13 Musique
   74852 dr-xr-xr-x     0      0         0  9-May-2020 09:55 Naruto
   74864 dr-xr-xr-x     0      0         0  6-Jul-2021 16:34 One Piece
   75070 dr-xr-xr-x     0      0         0 11-Jul-2016 14:56 Sailor Moon Crystal
   85003 dr-xr-xr-x     0      0         0  9-May-2020 09:53 Softwares
   74936 dr-xr-xr-x     0      0         0  4-Aug-2016 10:31 The Big Bang Theory
   74871 dr-xr-xr-x     0      0         0  9-May-2020 09:51 The Flash
   72087 dr-xr-xr-x     0      0         0  9-May-2020 10:00 TorrentFiles
So I've attempted to repair and write the partition back... Which I failed because I probably make it start at 0 instead of after the 2048 bytes .... ( MBR, or alike structure, I presume?)
There's the log of that:
interface_load
 1 P MS Data                     2048 1953458175 1953456128 [My Passport]
write!
ntfs_boot_sector
filesystem size           1 35
sectors_per_cluster       0 0
mft_lcn                   0 1953458142
mftmirr_lcn               0 5010996442594911293
clusters_per_mft_record   0 -107
clusters_per_index_record 0 123
Status: Bad
Status: Bad
Sectors are not identical.
There, I retried because I didn't understood why it was in a bad status since that operation ...
I'll just post the entire log there (including the past 2 parts) :
Thu Jun  2 19:51:59 2022
OS: Linux, kernel 5.17.5-76051705-generic (#202204271406~1653440576~22.04~6277a18 SMP PREEMPT Wed May 25 01) x86_64
Compiler: GCC 11.2
ext2fs lib: 1.46.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.3
/dev/sda: size       468877312 sectors
/dev/sda: user_max   468877312 sectors
/dev/sda: native_max 468877312 sectors
/dev/sdb: size       3907029168 sectors
/dev/sdb: user_max   3907029168 sectors
/dev/sdb: native_max 3907029168 sectors
Warning: can't get size for Disk /dev/loop1 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop2 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop3 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop4 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop5 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop6 - 0 B - 0 sectors, sector size=512
Warning: can't get size for Disk /dev/loop7 - 0 B - 0 sectors, sector size=512
Disk /dev/sda - 240 GB / 223 GiB - CHS 29186 255 63, sector size=512 - SanDisk SSD PLUS 240 GB, S/N:174302803264, FW:UF3000RL
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DL001-9VT156, S/N:5YD0WF5P, FW:CC41
Disk /dev/sdc - 248 GB / 231 GiB - CHS 30159 255 63, sector size=512, FW:PMAP
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512 - WD My Passport 0820, FW:1007
Disk /dev/sde - 4000 GB / 3725 GiB - CHS 3815415 64 32, sector size=512 - WD Elements 25A3, FW:1021
Disk /dev/loop0 - 3167 MB / 3020 MiB - 6186728 sectors (RO), sector size=512
Disk /dev/nvme0n1 - 2000 GB / 1863 GiB - CHS 1907729 64 32, sector size=512
Disk /dev/nvme1n1 - 1000 GB / 931 GiB - CHS 953869 64 32, sector size=512
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
   72346 dr-xr-xr-x     0      0         0  9-May-2020 10:24 XxX
interface_load
gpt_change_part_type
Change partition type:
     EFI System                     1 1953458175 1953458175
     Unknown                        1 1953458175 1953458175
 1 P EFI System                     1 1953458175 1953458175
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
interface_load
write!
ntfs_boot_sector
Status: Bad
Status: Bad
Thu Jun  2 20:01:51 2022
Compiler: GCC 11.2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
dir_partition inode=0
     exFAT found using backup sector, blocksize=262144, 1000 GB / 931 GiB
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
     MS Data                        1 1953458175 1953458175
     exFAT                          1 1953458175 1953458175
SIGINT detected! TestDisk has been killed.
Thu Jun  2 20:06:11 2022
Compiler: GCC 11.2
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
exFAT_boot_sector
exFAT OK
Backup boot record
exFAT OK
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
interface_load
   P EFI System                  2048 1953456127 1953454080
   P ext2                        2048 1953456127 1953454080
Invalid partition structure.
Thu Jun  2 20:14:50 2022
Compiler: GCC 11.2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
The end state is looking like that:
NTFS signature is missing.
     exFAT                       2048 1953456127 1953454080
     NTFS                        2048 1953458175 1953456128
     exFAT                       2048 1953458175 1953456128
write!
I've just did a retrieval of the files through photorec but I still would prefer to have them with their name etc if possible.
Is there anyway to do that?
Thanks for taking the time to read me !
Re: Writed wrong partition at wrong sector start, would like to go back..
Would you please be so kind as to replace the gamer-speak abbreviations like "FS" into a name that I and others can understand?
Thank you for using English as a language because the French accents are a pain to reach on a German keyboard.
What is the operating system that was used to read the content of this drive?
Dragomitch
#3 Post by Dragomitch »
Dragomitch wrote: 08 Jun 2022, 20:13 Hello there !
I have a problem about 2 disks.
First one that has sectors and harware problems that I'm trying to retrieve all the files for a friend. Lets call it DISK0
The second one being a mistake I caused stupidly while trying to retrieve the data of the friend. Lets call this one MY_DISK
I started by trying to scan, through testdisk, DISK0, to see if it was not only a problem of partitions or something that testdisk could fix fast and easily.... Which was not the case, as it is really an hardware problem.
So I wanted to use dd to backup DISK0 first ( and finished by doing it through ddrescue because dd had also problems).
There, I did a mistake when specifying the destination folder ... And ended "trying" to restore it to /dev/sdd/ which I cancelled quiet instantly realizing the mistake. Nonetheless, it corrupted the MY_DISK by doing so ( or at least the FileSystem(FS) table ).
So I restarted the ddrescue of DISK0 on another harddrive.
I didn't backup MY_DISK as I didn't expect to erase the content. But I kept the logs of testDisk where we see different information about the FileSystem and was able to see the files also. There is the log of that:
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
So I've attempted to repair and write the partition back... Which I failed because I probably made it start at 0 instead of after the sector/MasterBootRecord/table of 2048 bytes ?
interface_load
write!
ntfs_boot_sector
Status: Bad
Status: Bad
Compiler: GCC 11.2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
interface_load
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
interface_load
write!
ntfs_boot_sector
Status: Bad
Status: Bad
Compiler: GCC 11.2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Compiler: GCC 11.2
New options :
 Dump : No
 Expert mode : No
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
exFAT_boot_sector
exFAT OK
Backup boot record
exFAT OK
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
interface_load
Compiler: GCC 11.2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
write!
I have already did a retrieval of the files through photorec but I still would prefer to have them with their name etc if possible.
Hello there !
I had some vacations and had hard time coming back at work, so I totally forgot about all of this until my friend asked me again about the HardDrive, 2 days ago.
So I'm coming back to you for seeking help :D .
I have edited in the quotation (because I can't edit the first post) all the parts that could be unclear or that was using abreviations.
I used Pop-Os, a linux distribution based on Ubuntu.
Please let me know if you need any other information that I can provide to find help you finding a solution.
Dragomitch wrote: 08 Jun 2022, 20:13 I've just did a retrieval of the files through photorec but I still would prefer to have them with their name etc if possible.
You would simply try out if the "p"-key in Testdisk yields results that you expect. In case of the directory being shown you can use Testdisk to copy files and folders to a safe location.
If the copies do not meet your expectation, try out any other recovery software for better results.
