flashed windows media creation tool to external hard drive and wiped it
O5CARMAN
Re: flashed windows media creation tool to external hard drive and wiped it
#11 Post by O5CARMAN »
hi recuperation
is this the report you are talking about? I used GSmartControl. Is there a better way? Sorry i am sure this is frustrating for you....
There are 52 ATA errors...
so given my situation is there anything else i can do to try to get Testdisk to work? and is photorec the next step?
Thank you for your patience. i am plugging along here. Would you be able to tell me why Testdisk wont work in my case when i have read others have been successful? Have i done something wrong or missed something?
Appreciate your help.
O5CARMAN
#12 Post by O5CARMAN »
and i saw this report. I am not sure but it doesn't look good to me. Can i move everything as it is somewhere else and work on it there? Geeezzzzzz, going from bad to worse?
EDIT !
Here is the error log
O5CARMAN
#13 Post by O5CARMAN »
hey recuperation
so EaseUS does show the files as being recoverable. just trying to learn and not spend a lot of money. I just cant seem to get Testdisk to work properly...I will continue to work on this and if you have any more suggestions, w would really appreciate it.
thank you for all of your help so far
#14 Post by recuperation »
Your drive is starting to fail.
O5CARMAN
#15 Post by O5CARMAN »
Hey recuperation
ok so that is not so good. Any advice on next step? Is there a way to put the contents as is on another hard drive and work on it? can i fix the mismatch issue and use Testdisk? What do you recommend?
How would you approach this if you were not as smart and experienced as you are....say you were someone like me.
Thanks
#16 Post by recuperation »
This is not about being smart or not. I don't write novels. I already told you everything. If you fail to read I can't help you. This is driving me mad and destroying any fun in helping.
O5CARMAN
#17 Post by O5CARMAN »
ok, sorry i am missing what you are saying. I do not have a lot of experience using these types of programs but like to learn. i am trying and do appreciate your help. One last question and i will leave it be. Would it help to delete the FAT32 partition and then run Testdisk?
