I have a WD 3TB mybook that went raw. I had used it the day before and suspect the Thermaltake dock I am using for it may have a fault internally(power issues)
I used Testdisk about 2 months ago to successfully recover this 700+gb lol and now its unreadable again.
it is set to GPT EFI and NTFS.
when I do a quick scan, it hangs at 99% for a healthy amount of time. Then finally completes. When i try to list files it says no files - file system may be damaged.
I can see the drive in disk management and with crystaldisk info - although it says caution.
I may have made a mistake at first when i began this time and pressed write as soon as it said it found the files, but i hadnt used P to list yet, turns out i think i wrote in a intel/pc partition. because now when i go to disk management the disk has 2 partitions. 2000gb of healthy drive and 748gb of unallocated data - which i know is my lost data.
when i use advanced, it shows my partition start end size in sectors, and it knows the name i gave the drive when i got it. tried type and put it to efi and ntfs. when i hit boot, boot sector ok back up sector ok sectors are identical. a valid ntfs boot sector must be present in order to access any data comes up. so, i am very beginner and i recovered the data last time by just following forums, but my sectors didnt match time.
so i hit list, wont list files, filesystem damaged. hit rebuild bs and search mft starts, then comes to extrapolated boot sector and current boot sector are different. i am LOST lol
i felt like id fly through this and the drive would be working in no time. HELP
700gb suddenly goes raw overnight.
