External drive corrupted by "badblocks"
guidobartoli80
#1 Post by guidobartoli80 »
Hello everyone, I wanted to ask your advice on how I can solve a problem with access from Linux to an external drive.
It is a 2 TB drive that has been working normally until today, but then due to a power outage during a copy, some files got corrupted. Naively (and foolishly!) I used the "badblocks" command with the "-w" option to try to fix the problem, but it actually overwritten a small part of the drive with unusable data (I stopped it as soon as I noticed, it was only 0.23%, but enough to do damage :evil: ).
So I launched "testdisk" following the official tutorial:
  1. The "Analyse" command found the primary partition twice as seen in the tutorial.
  2. The "Quick Search" command produced a long list of strange partitions (FAT12, Mac, ...), while only the first one was NTFS, I tried to see the files inside, but got the message: "Can't open filesystem. Filesystem seems damaged."
  3. I still used the command to write the partition table and rebooted everything, the disk is present in the devices (/dev/sdb1), but the partition is of unknown type and is not mounted by the operating system
  4. I ran "testdisk" again (this time the "Analyze" command was very fast) and used the "RebuildFS" function, but nothing changed. :|
The final situation is this:
Disk /dev/sdb - 2000 GB / 1862 GiB - CHS 243197 255 63
 1 P MS Data                     2048 3906961407 3906959360
Status: OK
Status: OK
Sectors are identical.
From this, when I try to "List" the files, the message is still "Can't open filesystem. Filesystem seems damaged."
Does anyone have any other suggestions? I know I can use Photorec, but the disk contained so many small files, and even if they were recovered, it would be impossible for me to trace them back to their original names.
Many thanks in advance!
Re: External drive corrupted by "badblocks"
guidobartoli80 wrote: 28 Aug 2022, 23:39 Hello everyone, I wanted to ask your advice on how I can solve a problem with access from Linux to an external drive.
This statement tells you that Testdisk is not able to recover the partition.
If you are referring to "RebuildBS" please write it correctly. I am not aware of a function called "RebuildFS". I searched the whole source code for "RebuildFS" to make sure I am not wrong in my asssumption.
Try out some other software.
