Unable to Install/Run TestDisk on Linux Mint 20.3
Richa999
#1 Post by Richa999 »
I am following the instructions in TestDisk Documentation Release 7.1 on https://www.cgsecurity.org/testdisk.pdf
I followed this section:-
2.1.9 Ubuntu
As root on the Ubuntu system,
apt update
apt install testdisk
This appeared to run successfully with the last part showing
The following NEW packages will be installed:
  testdisk
0 upgraded, 1 newly installed, 0 to remove and 6 not upgraded.
Need to get 362 kB of archives.
After this operation, 1,457 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu focal/universe amd64 testdisk amd64 7.1-5 [362 kB]
Fetched 362 kB in 2s (220 kB/s)
Selecting previously unselected package testdisk.
(Reading database ... 321593 files and directories currently installed.)
Preparing to unpack .../testdisk_7.1-5_amd64.deb ...
Unpacking testdisk (7.1-5) ...
Setting up testdisk (7.1-5) ...
Processing triggers for man-db (2.9.1-1) ...
richard@Linux-Box:~$
I then looked in the Mint Menu for TestDisk but couldn't find it so I went to Section 6.3 Running TestDisk, PhotoRec under Linux
Here it says:-
You need to be root to run TestDisk.
cd testdisk-7.1
sudo ./testdisk_static
Problem is the cd does not work probably because I can't find any trace of a folder called testdisk-7.1 or similar.
Where has it installed TestDisk?
I'm a relative newbie to Linux so would appreciate any pointers as to what I am doing wrong.
Thanks
Re: Unable to Install/Run TestDisk on Linux Mint 20.3
Thank you for the good problem description!
The manual is not precise here what made you mixing up both alternatives as described below:
Alternative 1: running the precompiled binaries
If you download
https://www.cgsecurity.org/testdisk-7.2 ... 64.tar.bz2
from here:
https://www.cgsecurity.org/wiki/TestDisk_Download
you will get the so-called precompiled binaries.
The handbook is referring to them.
You unpack the bz2-archive and open up the folder with the archive content.
You navigate ("cd") into the unpacked folder and key in:
Alternative 2: Installing Testdisk using the Linuxmint installer
After installation as described by you running
sudo testdisk
in a terminal should start Testdisk.
Richa999
#3 Post by Richa999 »
Great, thanks for the quick response.
Used your alternative 2 seeing as I was half way there and started TestDisk fine.
I had already started Gparted > Data Rescue. That just has a status bar going backwards and forwards for the last 48hrs +, not sure whether it's actually progressing as status bar doesn't show actual progress. Manual and forums say it can take a while so I'll leave for another night but if it hasn't finished in the morning I'll cancel it and try TestDisk to recover my RAID array.
