TrueCrypt - Recovering a hidden partition Topic is solved
teddke
Re: TrueCrypt - Recovering a hidden partition
#11 Post by teddke »
Current log file
Fri Aug 25 11:14:41 2023
TestDisk 7.2-WIP, Data Recovery Utility, February 2023
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=1024209543168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1023430098944
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000381018112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000396321280
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000396321280
filewin32_getfilesize(\\.\J:) GetFileSize err ???????? ???????.
filewin32_setfilepointer(\\.\J:) SetFilePointer err ???????? ???????.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=59055669248
Disk \\.\PhysicalDrive0 - 1024 GB / 953 GiB - CHS 124519 255 63, sector size=512 - SAMSUNG MZVL21T0HCLR-00B00, S/N:0025_38B5_21B7_B8AF., FW:GXA7401Q
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Samsung SSD 970 EVO Plus 2TB, S/N:0025_3853_3190_3887., FW:2B2QEXM7
Disk \\.\PhysicalDrive2 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Samsung Portable SSD T5, S/N:1D39F7654321
Disk \\.\PhysicalDrive3 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate FA GoFlex Desk, S/N:NA0KBJL2, FW:0D0B
Drive O: - 59 GB / 54 GiB - CHS 115343104 1 1, sector size=512
Partition table type defaults to None
Partition table type: None
   P Unknown                        0  115343103  115343104
Change partition type:
   P NTFS                           0  115343103  115343104
ntfs_boot_sector
filesystem size           8922980849155958266 2712177588380243268
sectors_per_cluster       128 54
mft_lcn                   8656922565675998984 14374428631713765566
mftmirr_lcn               17970793733309430699 8450474270428948987
clusters_per_mft_record   94 2
clusters_per_index_record -38 82
Status: Bad
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
ntfs_boot_sector
Status: Bad
Status: Bad
   P FAT32                          0  115343103  115343104
fat32_boot_sector
Bad
Bad
First sectors (boot code and partition information) are not identical.
Second sectors (cluster information) are not identical.
Third sectors (second part of boot code) are not identical.
   P FAT16                          0  115343103  115343104
fat1x_boot_sector
Bad
   P exFAT                          0  115343103  115343104
exFAT_boot_sector
Bad
Backup boot record
Bad
fat32_boot_sector
Bad
Bad
Analyse Drive O: - 59 GB / 54 GiB - CHS 115343104 1 1
file_win32_pread(680,11,buffer,115343096(115343096/0/1)) read err: read after end of file
file_win32_pread(680,11,buffer,115343100(115343100/0/1)) read err: read after end of file
file_win32_pread(680,8,buffer,115343099(115343099/0/1)) read err: read after end of file
file_win32_pread(680,14,buffer,115343092(115343092/0/1)) read err: read after end of file
file_win32_pread(680,14,buffer,115343093(115343093/0/1)) read err: read after end of file
file_win32_pread(680,14,buffer,115343094(115343094/0/1)) read err: read after end of file
file_win32_pread(680,14,buffer,115343095(115343095/0/1)) read err: read after end of file
file_win32_pread(680,14,buffer,115343096(115343096/0/1)) read err: read after end of file
file_win32_pread(680,14,buffer,115343098(115343098/0/1)) read err: read after end of file
file_win32_pread(680,14,buffer,115343100(115343100/0/1)) read err: read after end of file
file_win32_pread(680,14,buffer,115343102(115343102/0/1)) read err: read after end of file
file_win32_pread(680,11,buffer,115343098(115343098/0/1)) read err: read after end of file
file_win32_pread(680,8,buffer,115343101(115343101/0/1)) read err: read after end of file
#12 Post by recuperation »
You did not describe how you performed that copy operation, I wonder if that went wrong.
You can run Photorec on the decrypted drive to see if it finds anything at all.
teddke
#13 Post by teddke »
I will try to explain, but if there is anything unclear please ask again.
In the beginning, I took my Portable SSD 2T and allocated 500GB for TrueCrypt storage, and further, this 500GB was divided into 55GB Hidden Partition and the rest 445GB Regular Partition.
I did the copy operation in two ways.
1. At the beginning, when the failure occurred, I physically copied that 500GB file (which was divided into two partitions by TrueCrypt - the main partition and the hidden 55GB partition) from the Portable SSD to a second SSD hard drive on my laptop. (In the picture in red is Disk 1, which is the primary media, and Disk 2, which is where I copied the copy and which I am now manipulating. That is, now all operations now I make with this copy, which is on disk 2.)
2. On your recommendation, I additionally made a copy, but not from the Portable SSD, but already from the copy. For this purpose I mounted the disk through TrueCrypt then it created a virtual partition with a hidden partition 55GB as usual and then TestDisc program selected this disk (in the picture it is disk O), then "None" - then "Image Creation", and as a result I got the file image.dd (55GB).
Now I ran Photorec also on this disk, and it finds some old files that were probably written to the disk space as I understand it before I even used TrueCrypt. Because the files I'm recovering were encrypted, and none of them were found by Photorec.
#14 Post by recuperation »
If you mounted your hidden partition and saved its content into a file and have the hidden partition already examined by Testdisk and Photorec there is nothing more I can tell you.
teddke
#15 Post by teddke »
But the contents of the hidden partition are still not accessible. It is mounted, but Testdisc doesn't see anything there.
There was a similar story here viewtopic.php?p=26147#p26147 and the person didn't find a solution
#16 Post by recuperation »
But what?
What should I do know?!
