You don't have to justify yourself. I wanted to explain you some things about creating a custom signature.
The most important thing is to answer my questions. If you don't answer the questions of your doctor, he can't treat you. Depending on the answer your work might be completely useless for a second reason. You were already told the first reason.
If people ignore my questions my support ends.
Have a good day!
folder file .photorec.sig
Re: folder file .photorec.sig
as can be seen from the posts, I answered all the questions and requests that were made to me, but without any help or example to solve the problem, except for always requesting more information without building a useful path to the solution . As I don't know the right way to solve my problem, I can't even know what I'm missing to indicate the problem. I agree that if I meet a doctor for the first time, there is a need for him to get to know me, but it must be the doctor, based on the problem I ask him to ask me all the necessary and inherent questions to resolve the same, otherwise if I leave From the beginning, the doctor can be misled from the correct diagnosis by giving too much information that is not needed. in fact in this case, so much information was requested that the doctor had also lost the data he had already provided initially.
Thanks anyway for the time you wasted and have a good day too.
while searching the forum for the same problem I noticed that there are few questions,
and almost no answers explaining the procedure for creating a personalized signature.
I already told you that Photorec has xcf support. You don't want to believe it, trying to create an individual xcf signature.
I was asking for the name of your disk manufacturer and model trying to potentially provide you, the non-believer, with another reason why you technically may not be able to recover.
Sorry, I have no patience for your case anymore.
I should have already known when you reposted your issue, shouting in the title line.
I think you made a big mistake about me, please, I understand that it's not easy trying to give answers in a forum when dealing with different people, but to think you understand a person's mentality/personality by reading a couple of posts I think it's very difficult even for the best psychologist in the world.recuperation wrote: 13 Sep 2023, 07:58 I should have already known when you reposted your issue, shouting in the title line.
I'll tell you a secret, which perhaps you missed from your subtle analysis, I don't speak English, and I use the translator to be able to communicate on this forum, so if I didn't initially specify all the things you asked me, it wasn't due to my negligence , but apart from the fact that I didn't know exactly what to indicate, having to then use the translator I also didn't want what I was about to write not to be understood (as perhaps has happened now)
just for completeness and to confirm that I am not the person you want to paint, I attach the image taken from the guide file you shared where it explains the passage that interests me, all I did was copy the chapter title and paste it as the topic title for the post thinking the title was the best way to explain my problem.
you say that you want to help me solve the problem, but so far you have not yet suggested anything to me regarding this problem, if you really "want" to help me we will start all over again, we will erase the misunderstandings of the past, you explain to me the correct steps and I will follow them. at this point I don't care which extension to take into consideration, you decide on an extension of your choice, whether it's already "present or not" in the photorec list I don't care at this point it's a question of principle because I'm convinced that the steps that I make sure they are almost all correct, 1 or 2 corrections are missing.
what can I say, now it's your turn to act, I'm available for a constructive dialogue, if, as you said, you are really willing to help me, this is the right time to demonstrate it. a greeting.
I can also use a pen-drive/micro-SD if, as you say, with my disk due to technical problems it is not possible to carry out the search successfully, I use a micro-SD and an extension chosen by you with the relevant explanation with the steps I need. you point. If I start from scratch and do everything following your instructions I should be able to recover deleted files by creating a custom signature, right?
- Untitled.png (89.61 KiB) Viewed 41129 times
Hello
I have
- updated signatures for XCF files in latest PhotoRec 7.2-WIP
https://github.com/cgsecurity/testdisk/ ... e4c3ec63ff
- added a warning in the documentation about file signature location
https://www.cgsecurity.org/testdisk_doc ... n-photorec
"If you are using a .photorec.sig in your HOME directory, be warned that when running photorec as root (ie. via the sudo command), photorec will search in /root/.photorec.sig, not in your user home directory. So you may have to copy the .photorec.sig file first."
I have
