RAW parts, MFT fault...
lomba
#1 Post by lomba »
I'm facing since several days to a massive data loss, and I'm trying to recover them before going to a disk doctor. I tried some actions with testdisk, but I need your help because I reached my limits.
For the history, I lost access to Windows without any warning, probably due to many electrical stops (fan problem). This disk was encrypted but it seems I could unencrypt it before loosing access (Windows was indicating "disk unencrypted").
When I mount this disk in a new notebook, Windows asks me to format the disk. This is a Seagate 500GB. The original partitions was the following :
- P1 : Boot, NTFS, "Reserved to system", 100 MB
- P2 : Main, NTFS, "System", 78 GB
- P3 : Main, NTFS, "Data", 220 GB
- P4 : Main, FAT32, "HP_Tools", 2 GB
The other space is free space.
When I mount this disk through my USB dock, Windows displays the following parts :
H: and I: (which were C: and D:) are displayed like RAW partitions.
I'm using Testdisk 6.14 in Windows. It perfectly detects my disk /dev/sdb. The partitions are displayed :
First problem : P2 is "invalid NTFS boot" ; P3 appears twice.
I run Quick Scan on partitions. Here is the result :
The third part is not visible. I try to browse P2 content :
Content is not valid ! I run a Deeper Scan. Result :
Same problem : the partitions I want to recover are not readable. I do again analysis of P2 :
I just add the, for this part, the initial status was "OK" for boot and "Bad" for the copy. I did a Rebuild BS.
P3 partition :
At this point, I'm blocked. I don't know what to do. I tried some recovery tools (GetDataBack, OnTrack) but none can't see data.
Here is the Testdisk log :
Fri Aug 24 09:22:05 2012
TestDisk 6.14-WIP, Data Recovery Utility, July 2012
Compilation date: 2012-08-14T11:59:29
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Fonction incorrecte.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=102604210176
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=395248140288
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2147483648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=83781222400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=234027483136
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=2147483648
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST9500420AS, S/N:2020202020202020202020205635424a4350444a, FW:0006HPM1
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST950042 3AS, FW:SDM5
Disk /dev/sdb - 500 GB / 465 GiB - ST950042 3AS
NTFS at 0/32/33
NTFS at 12/223/20
FAT32 at 38650/233/48
Info: size boot_sector 4194304, partition 4194304
FAT1 : 8222-12302
FAT2 : 12303-16383
start_rootdir : 16384 root cluster : 2
Data : 16384-4194303
sectors : 4194304
cluster_size : 8
no_of_cluster : 522240 (2 - 522241)
fat_length 4081 calculated 4081
 1 * HPFS - NTFS              0  32 33    12 223 19     204800 [Réservé au système]
 2 P HPFS - NTFS             12 223 20 10198 177 27  163635200
Invalid NTFS or EXFAT boot
 3 P HPFS - NTFS          10198 177 28 38650 233 47  457084928
 4 P FAT32 LBA            38650 233 48 38911 254 63    4194304 [HP_TOOLS]
Incomplete multi sector transfer detected in $MFT.
ntfs_mft_load(): Failed.
NTFS at 0/32/33
filesystem size           204800
sectors_per_cluster       8
mft_lcn                   8533
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS at 12/223/20
filesystem size           163635200
mftmirr_lcn               2
     NTFS, blocksize=4096, 83 GB / 78 GiB
FAT1 : 8222-12302
FAT2 : 12303-16383
sectors : 4194304
cluster_size : 8
     FAT32, blocksize=4096, 2147 MB / 2048 MiB
file_pread(5,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(5,11,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(5,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(5,14,buffer,976775170(60801/112/50)) lseek err Invalid argument
file_pread(5,3,buffer,976775184(60801/113/1)) lseek err Invalid argument
file_pread(5,3,buffer,976775231(60801/113/48)) lseek err Invalid argument
file_pread(5,8,buffer,976775247(60801/114/1)) lseek err Invalid argument
file_pread(5,11,buffer,976775294(60801/114/48)) lseek err Invalid argument
file_pread(5,2,buffer,976777216(60801/145/17)) lseek err Invalid argument
Not an exFAT boot sector.
 3 P FAT32 LBA            38650 233 48 38911 254 63    4194304 [HP_TOOLS]
$MFT has invalid magic.
NTFS at 0/32/33
mft_lcn                   8533
mftmirr_lcn               2
NTFS at 12/223/19
mft_lcn                   8533
mftmirr_lcn               2
NTFS at 12/223/20
mftmirr_lcn               2
NTFS at 10198/177/27
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 83 GB / 78 GiB
FAT1 : 8222-12302
FAT2 : 12303-16383
sectors : 4194304
cluster_size : 8
FAT32 at 38650/233/54
FAT1 : 8222-12302
FAT2 : 12303-16383
sectors : 4194304
cluster_size : 8
     FAT32 LBA            38650 233 48 38911 254 63    4194304 [NO NAME]
     FAT found using backup sector!, 2147 MB / 2048 MiB
NTFS at 38912/97/33
filesystem size           4184064
mft_lcn                   174336
mftmirr_lcn               2
     HPFS - NTFS          38651 238 52 38912  97 33    4184064
     NTFS found using backup sector, blocksize=4096, 2142 MB / 2043 MiB
NTFS at 38913/5/4
filesystem size           461295616
mftmirr_lcn               2
     HPFS - NTFS          10198 177 28 38913   5  4  461295616
     NTFS found using backup sector, blocksize=4096, 236 GB / 219 GiB
file_pread(5,1,buffer,976775167(60801/112/47)) lseek err Invalid argument
mftmirr_lcn               2
     HPFS - NTFS          10198 177 27 20384 131 34  163635200
dir_partition inode=5
       5 dr-xr-xr-x     0      0         0 23-Aug-2012 09:57 .
       5 dr-xr-xr-x     0      0         0 23-Aug-2012 09:57 ..
     100 dr-xr-xr-x     0      0         0 22-Aug-2012 12:13 $RECYCLE.BIN
      35 dr-xr-xr-x     0      0         0  3-Aug-2011 15:14 Boot
      86 -r--r--r--     0      0    383786 20-Nov-2010 13:40 bootmgr
      97 -r--r--r--     0      0      8192  3-Aug-2011 15:14 BOOTSECT.BAK
      98 dr-xr-xr-x     0      0         0  3-Apr-2012 13:02 System Volume Information
dir_partition inode=0
FAT: cluster=2(0x2), pos=620943360
       3 drwxr-xr-x     0      0         0 29-Aug-2011 10:49 Hewlett-Packard
    1058 drwxr-xr-x     0      0         0 29-Aug-2011 11:46 $RECYCLE.BIN
  458757 drwxr-xr-x     0      0         0 12-Jun-2012 11:00 System Volume Information
X      6 drwxr-xr-x     0      0      4096 23-Aug-2012 09:57 MSI8f2e3.tmp
X      6 drwxr-xr-x     0      0      4096 22-Aug-2012 00:50 628d2f1c-c44b
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 14:27 MSI4e42a.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 14:31 MSI2a23a.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 14:31 MSI2a241.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 14:32 MSI3ac95.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 14:40 MSI2f3f1.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 14:48 MSI4b77f.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 14:48 MSI5235a.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 14:49 MSI644bf.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 14:51 MSI83c75.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 14:53 MSI9b4c0.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 14:54 MSIaabf9.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 15:11 MSI5b0aa.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 15:11 MSI5b0af.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 15:11 MSI5b0b4.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 15:12 _SI62608.TMP
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 16:53 MSI4894e.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 16:54 _SI48951.TMP
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 16:54 MSI613e0.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 16:56 MSI50ccb.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 16:58 MSI91db0.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 16:59 MSIa8bec.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 17:01 MSIc172b.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 17:05 MSIfe581.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 17:05 MSIfe584.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 17:05 MSI50cec.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 17:07 MSI15d4f.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 17:10 MSI4a009.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 17:12 MSI5c20a.tmp
X   1061 drwxr-xr-x     0      0      4096 29-Aug-2011 17:21 MSIe3130.tmp
X      2 drwxr-xr-x     0      0      4096 29-Aug-2011 17:46 MSIaae1.tmp
X      2 drwxr-xr-x     0      0      4096 29-Aug-2011 17:47 MSI1404d.tmp
X      2 drwxr-xr-x     0      0      4096 29-Aug-2011 18:20 MSIf30e3.tmp
X      2 drwxr-xr-x     0      0      4096 29-Aug-2011 18:20 _115199_
X      2 drwxr-xr-x     0      0      4096 29-Aug-2011 18:20 MSIf30ea.tmp
X      2 drwxr-xr-x     0      0      4096 29-Aug-2011 18:21 MSIf30f0.tmp
X      2 drwxr-xr-x     0      0      4096 29-Aug-2011 18:21 MSIf30f5.tmp
X      2 drwxr-xr-x     0      0      4096 29-Aug-2011 18:21 MSIf30fa.tmp
X      2 drwxr-xr-x     0      0      4096 29-Aug-2011 18:26 MSIf3100.tmp
X    532 drwxr-xr-x     0      0      4096 29-Aug-2011 18:26 MSIf3109.tmp
X    532 drwxr-xr-x     0      0      4096 29-Aug-2011 18:26 MSIf3111.tmp
X    532 drwxr-xr-x     0      0      4096 16-Sep-2011 20:51 MSI5a139.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 10:53 _671078_
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 10:58 MSI2f187.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 10:58 MSI2f19f.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 10:58 MSI2f1b6.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 10:59 MSI2f1bf.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 10:59 _012268_
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 10:59 MSI2f1c7.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:07 MSI2f1e6.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:07 MSI2f1ff.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:07 MSI2f209.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:07 MSI2f223.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:08 MSI2f233.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:08 MSI2f24b.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:09 MSI2f259.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:09 MSI2f263.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:10 MSI2f27e.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:10 MSI2f288.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:10 MSI2f298.tmp
X    532 drwxr-xr-x     0      0      4096 18-Sep-2011 11:11 MSI2f2b0.tmp
X    532 drwxr-xr-x     0      0      4096  3-Oct-2011 09:32 _207654_
ntfs_readdir failed
       5 dr-xr-xr-x     0      0         0  3-Aug-2011 14:54 .
       5 dr-xr-xr-x     0      0         0  3-Aug-2011 14:54 ..
NTFS at 0/32/33
NTFS at 12/223/20
FAT1 : 8222-12302
FAT2 : 12303-16383
sectors : 4194304
cluster_size : 8
Change partition type:
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mft_lcn                   8533
mftmirr_lcn               2
Status: OK
Status: OK
Sectors are identical.
ntfs_boot_sector
NTFS at 12/223/20
NTFS at 12/223/20
mftmirr_lcn               2
Status: OK
Status: OK
ntfs_boot_sector
filesystem size           4704045984691713348 2122442775132650031
sectors_per_cluster       206 54
mft_lcn                   911151509 3922555207
mftmirr_lcn               2401006066 895649204
clusters_per_mft_record   54 3
clusters_per_index_record 53 -31
Status: Bad
Status: Bad
Sectors are not identical.
fat32_boot_sector
FAT1 : 8222-12302
FAT2 : 12303-16383
sectors : 4194304
cluster_size : 8
FAT1 : 8222-12302
FAT2 : 12303-16383
sectors : 4194304
cluster_size : 8
OK
OK
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
If you have any idea, please feel free to ask me. Do you know a disk doctor could solve my problem ?
Thanks in advance.
Regards
Alexis
Re: RAW parts, MFT fault...
Your second partition looks like the file system is faulty.
Your third partition indicates an invalid boot sector.
Can you diagnose your boot sector on this partition?
Please select your affected third partition.
Confirm at Boot.
If it's finished, please post the info or upload a screen.
Infos will follow.
Lito
#3 Post by Lito »
The picture you uploaded of Windows Management, gives a clean bill of health to the partitions.
An alternative to fix the boot sector, may be to use FixMBR and /or Bootfix from Microsoft.
I think the disk would have to be in its original HP box, albeit for a short while.
There is a tool that you could download for free, and burn to a CD, to use now or at a later time,
from this site:
http://www.partitionwizard.com/
Download the free CD image (iso file) and burn with any tool. For example Nero (not free), ImgBurn (free), K3B (free with Linux), etc. I personally use this tool to quickly format or wipe clean my disks, and it does work. Mind i never have used it to solve a problem such as yours.
Bootfix and FixMBR are in the instalation disk for Windows XP. You will find instructions on how to use them in many sites. Is best to follow the advise of Microsoft, to avoid dodgie sites.
It may be worth your while to look at Redo - Backup and Recovery (includes a copy of PhotoRec). It also burns to a CD, and later you can boot from it. The main tasks that Redo performs is that allows you to make an image of the partitions on your drive (or the whole disk) for your pice of mind. Should anything go wrong, you will have a backup.
I have used this tool to recover files from a neighbours computer, (without having to hold their computer for days) and it does work. I did recover many of their lost pictures, working from images made with Redo. Partly using the included copy of PhtoRec, although using this tool from the CD was hard going, because it can only save files to root, and root is in memory.
lomba
#4 Post by lomba »
Fiona, I tried to rebuild my partitions a lot of times : it lasts each time more than 12 hours and nothing change. I've no error message, but I can't access the data. There is nothing specific in the log file. That's the reason of my long delay to answer, because I tried many times to rebuild the part and I wasn't sure of the result (I wasn't each time in front of my computer due to the long rebuild time).
I think there is no more to do :(
Regards
#5 Post by Fiona »
MFT (Master File Table) indicates that your file system is faulty.
If TestDisk doesn't find another partition displaying your data and rebuilding your boot sector doesn't work either, so it looks like that you need datarrcovery software.
PhotoRec migfht be an idea.
But it doesn't recover file names and directories.
Please let me know what kind of file types you'd like to recover.
Otherwise you'd need commercial datarecovery software.
