Ok i have a bit of a complicated setup for the partition in question using software raid 5 and lvm on debian squeeze to host a bunch of virtual machines. Something went wrong the other day and the hypervisor system froze with a bunch of /proc/xxx hung for xxx seconds forcing me to do a hard reset. The system came back up but went into maintance mode and told me to fsck I used this command "fsck -y /dev/mapper/vg1-root" which took hours and corrected lots of errors. I rebooted and again forced into maintance mode but now when i do a fsck on the disk it tells me this
superblock
so i tried this
backup superblock
of corse this did not work so i broke out systemrescuecd and ran testdisk 6.13 did the normal way INTEL type partion and it finds a bunch of partitions none of them right and i cannot (p) list on any of them. I could go on and on about the stuff i have tried the last couple of days, tring to recover using backup superblocks including setting the backup superblock to 0 and 4096 but lets cut to the chase.
I can find the correct partion if i set the partition type to NONE and i can list my files too which is relief
I found this similar post (see below)which gives me hope as i can even see my files with p however it seems a bit compex to go it alone hoping for some guidace here.
http://forum.cgsecurity.org/phpBB3/3tb- ... e&start=20
PS i can see my files when debian boot to maintiance mode and even mounts /dev/mapper/vg1-root but only int read only i think
Thank you in advance for your help
Partition type set to none
Re: Partition type set to none
If you use partition table type None, you'll not able to write any partition table because you've chosen None.
Please copy and paste the content of your testdisk.log or upload a screen.
I'd need infos from Analyse (your current partition table) and your found partition, where you can list your files from.
Might be possible to change geometry, so that your partition will be found.
c0mputerking
Ok i attached the testdisk log file sorry i tried to attach it last post to but i guess it didnt work cause it was too large sorry. This time i did not let the deep scan run to completion as it makes the logfile to large to attach and it just finds a whole bunch of wrong partitions. Also below is a screen shot not much to go on let me know if you need help. Also thank you very much for your help
Disk /dev/mapper/vg1-root - 285 GB / 265 GiB - CHS 556752896 1 1
>P ext4 0 556752895 556752896 [root]
Structure: Ok.
Keys T: change type, P: list files,
Enter: to continue
EXT4 Large file Sparse superblock, 285 GB / 265 GiB
Structure: Ok.
Enter: to continue
- testdisklog.zip
- (58.49 KiB) Downloaded 670 times
For determining your disk geometry, you should use partition table type intel.
If you confirm at analyse, please upload the info.
I'd need especially infos from disk, what's described there.
Also partition information are appreciated.
You can also copy and paste it from the testdisk.log in your post.
c0mputerking
Crap i didnt get notification of your reply thought you forgot about me anyways partition is still broken so maybe you can still help me get it going? I think this is the infos you require testdisk.log of an intel type
PS i made sure to check notifaction this time so i will get an email when you reply.
root % cat testdisk.log
Wed Oct 3 02:45:55 2012
OS: Linux, kernel 3.2.28-std300-amd64 (#2 SMP Tue Aug 21 18:35:38 UTC 2012) x86_64
Compiler: GCC 4.4
Compilation date: 2012-08-12T14:23:52
ext2fs lib: 1.42.5, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: none
/dev/sda: size 488281250 sectors
/dev/sda: user_max 488281250 sectors
/dev/sda: native_max 488281250 sectors
/dev/sda: dco 488281250 sectors
/dev/mapper/pve-root: LBA, HPA, LBA48, DCO support
/dev/mapper/pve-root: size 201326592 sectors
/dev/mapper/pve-root: user_max 488281250 sectors
/dev/mapper/pve-root: native_max 488281250 sectors
/dev/mapper/pve-root: dco 488281250 sectors
/dev/mapper/pve-swap: LBA, HPA, LBA48, DCO support
/dev/mapper/pve-swap: size 8388608 sectors
/dev/mapper/pve-swap: user_max 488281250 sectors
/dev/mapper/pve-swap: native_max 488281250 sectors
/dev/mapper/pve-swap: dco 488281250 sectors
/dev/sr0 is not an ATA disk
/dev/dm-0: LBA, HPA, LBA48, DCO support
/dev/dm-0: size 201326592 sectors
/dev/dm-0: user_max 488281250 sectors
/dev/dm-0: native_max 488281250 sectors
/dev/dm-0: dco 488281250 sectors
/dev/dm-1: LBA, HPA, LBA48, DCO support
/dev/dm-1: size 8388608 sectors
/dev/dm-1: user_max 488281250 sectors
/dev/dm-1: native_max 488281250 sectors
/dev/dm-1: dco 488281250 sectors
Disk /dev/sda - 250 GB / 232 GiB - CHS 30394 255 63, sector size=512 - WDC WD2502ABYS-18B7A0, S/N:WD-WCAT1H970269, FW:02.03B05
Disk /dev/mapper/pve-root - 103 GB / 96 GiB - CHS 201326592 1 1, sector size=512 - WDC WD2502ABYS-18B7A0, S/N:WD-WCAT1H970269, FW:02.03B05
Disk /dev/mapper/pve-swap - 4294 MB / 4096 MiB - CHS 8388608 1 1, sector size=512 - WDC WD2502ABYS-18B7A0, S/N:WD-WCAT1H970269, FW:02.03B05
Disk /dev/sr0 - 363 MB / 346 MiB - CHS 177452 1 1 (RO), sector size=2048 - HL-DT-ST BD-RE BH12LS35, S/N:K9MB2SH2043, FW:1.00
Disk /dev/dm-0 - 103 GB / 96 GiB - CHS 201326592 1 1, sector size=512 - WDC WD2502ABYS-18B7A0, S/N:WD-WCAT1H970269, FW:02.03B05
Disk /dev/dm-1 - 4294 MB / 4096 MiB - CHS 8388608 1 1, sector size=512 - WDC WD2502ABYS-18B7A0, S/N:WD-WCAT1H970269, FW:02.03B05
Disk /dev/mapper/pve-root - 103 GB / 96 GiB - WDC WD2502ABYS-18B7A0
Analyse Disk /dev/mapper/pve-root - 103 GB / 96 GiB - CHS 201326592 1 1
Ask the user for vista mode
search_vista_part: 0
block_group_nr 1
recover_EXT2: part_offset problem
BAD_RS LBA=879066043 384
FAT16 LBA 879066043 4232554595 3353488553
This partition ends after the disk limits. (start=879066043, size=3353488553, end=4232554595, disk end=201326592)
NTFS at 582423/0/1
heads/cylinder 16 (NTFS) != 1 (HD)
sect/track 2 (NTFS) != 1 (HD)
filesystem size 6174
sectors_per_cluster 1
mft_lcn 2058
mftmirr_lcn 5162
clusters_per_mft_record 2
clusters_per_index_record 8
HPFS - NTFS 582423 588596 6174 [Boot]
NTFS, 3161 KB / 3087 KiB
NTFS at 637823/0/1
mft_lcn 2058
mftmirr_lcn 5162
HPFS - NTFS 637823 643996 6174 [Boot]
block_group_nr 3
block_group_nr 5
block_group_nr 7
block_group_nr 9
block_group_nr 25
block_group_nr 27
block_group_nr 49
block_group_nr 81
block_group_nr 125
LVM2 magic value at 47514548/0/1
part_size 0
Linux LVM 47514548 47514547 0
LVM2, 0 B
Partition not added.
BAD_RS LBA=2925073112 127
FAT32 2925073112 3817308592 892235481
This partition ends after the disk limits. (start=2925073112, size=892235481, end=3817308592, disk end=201326592)
BAD_RS LBA=2470999318 197
HPFS - NTFS 2470999318 6132560619 3661561302
This partition ends after the disk limits. (start=2470999318, size=3661561302, end=1837593323, disk end=201326592)
LVM2 magic value at 51873540/0/1
part_size 0
Linux LVM 51873540 51873539 0
LVM2, 0 B
BAD_RS LBA=1491115772 485
FAT32 1491115772 5688299263 4197183492
This partition ends after the disk limits. (start=1491115772, size=4197183492, end=1393331967, disk end=201326592)
BAD_RS LBA=2369594287 913
FAT12 2369594287 3399099740 1029505454
This partition ends after the disk limits. (start=2369594287, size=1029505454, end=3399099740, disk end=201326592)
BAD_RS LBA=2929417976 127
FAT32 2929417976 3821653456 892235481
This partition ends after the disk limits. (start=2929417976, size=892235481, end=3821653456, disk end=201326592)
Linux 56069113 56069112 0
LUKS 0 (Data size unknown), 0 B
LVM2 magic value at 57165076/0/1
part_size 0
Linux LVM 57165076 57165075 0
LVM2, 0 B
Linux 58920481 58920480 0
recover_EXT2: s_block_group_nr=0/44, s_mnt_count=2/34, s_blocks_per_group=8192, s_inodes_per_group=2008
recover_EXT2: s_blocks_count 361428
recover_EXT2: part_size 722856
Linux 60326303 61049158 722856 [boot]
EXT3 Sparse superblock, 370 MB / 352 MiB
LVM2 magic value at 62259924/0/1
part_size 0
Linux LVM 62259924 62259923 0
LVM2, 0 B
block_group_nr 243
LVM2 magic value at 65997356/0/1
part_size 0
Linux LVM 65997356 65997355 0
LVM2, 0 B
BAD_RS LBA=2943449360 127
FAT32 2943449360 3835684840 892235481
This partition ends after the disk limits. (start=2943449360, size=892235481, end=3835684840, disk end=201326592)
Linux 70764521 70764520 0
block_group_nr 1
recover_EXT2: "e2fsck -b 8193 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=1/44, s_mnt_count=0/34, s_blocks_per_group=8192, s_inodes_per_group=2008
Linux 73878125 74600980 722856 [boot]
EXT3 Sparse superblock Backup superblock, 370 MB / 352 MiB
block_group_nr 343
recover_EXT2: s_block_group_nr=0/768, s_mnt_count=1/24, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 25165824
recover_EXT2: part_size 201326592
Linux 100405656 301732247 201326592
EXT3 Large file Sparse superblock Recover, 103 GB / 96 GiB
This partition ends after the disk limits. (start=100405656, size=201326592, end=301732247, disk end=201326592)
Linux 100405768 301732359 201326592
This partition ends after the disk limits. (start=100405768, size=201326592, end=301732359, disk end=201326592)
Linux 100405840 301732431 201326592
This partition ends after the disk limits. (start=100405840, size=201326592, end=301732431, disk end=201326592)
Linux 101794577 101794576 0
FAT32 at 103302826/0/1
Bad root_cluster
FAT12 at 103302827/0/1
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
FAT differs, FAT sectors=0-9/9
heads/cylinder 2 (FAT) != 1 (HD)
sect/track 18 (FAT) != 1 (HD)
FAT12 103302827 103305706 2880 [NO NAME]
FAT12, 1474 KB / 1440 KiB
FAT32 at 103483330/0/1
Bad root_cluster
FAT12 at 103483331/0/1
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 103483331 103486210 2880 [NO NAME]
block_group_nr 3
recover_EXT2: "e2fsck -b 24577 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=3/44, s_mnt_count=0/34, s_blocks_per_group=8192, s_inodes_per_group=2008
Linux 136959957 137682812 722856 [boot]
Linux Swap 137695965 139800460 2104496
SWAP2 version 1, 1077 MB / 1027 MiB
recover_EXT2: s_block_group_nr=0/8, s_mnt_count=1/25, s_blocks_per_group=32768, s_inodes_per_group=7312
recover_EXT2: s_blocks_count 263064
recover_EXT2: part_size 2104512
Linux 139835816 141940327 2104512 [inst]
EXT3 Large file Sparse superblock, 1077 MB / 1027 MiB
recover_EXT2: s_block_group_nr=0/6, s_mnt_count=11/36, s_blocks_per_group=32496, s_inodes_per_group=28128
recover_EXT2: s_blocks_count 196788
recover_EXT2: part_size 1574304
Linux 141975730 143550033 1574304 [storage]
EXT3 Large file Sparse superblock Recover, 806 MB / 768 MiB
recover_EXT2: s_block_group_nr=0/42, s_mnt_count=20/27, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 1407687
recover_EXT2: part_size 11261496
Linux 143576596 154838091 11261496 [root]
EXT3 Large file Sparse superblock Recover, 5765 MB / 5498 MiB
recover_EXT2: s_block_group_nr=0/8, s_mnt_count=5/21, s_blocks_per_group=32768, s_inodes_per_group=29680
recover_EXT2: s_blocks_count 267072
recover_EXT2: part_size 2136576
Linux 155032553 157169128 2136576 [log]
EXT3 Large file Sparse superblock Recover, 1093 MB / 1043 MiB
recover_EXT2: s_block_group_nr=0/4, s_mnt_count=21/26, s_blocks_per_group=32768, s_inodes_per_group=6640
recover_EXT2: s_blocks_count 132528
recover_EXT2: part_size 1060224
Linux 157204566 158264789 1060224 [tmp]
EXT3 Large file Sparse superblock Recover, 542 MB / 517 MiB
FAT12 at 158488060/0/1
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 158488060 158490939 2880
FAT12 at 158525100/0/1
FAT1 : 1-6
FAT2 : 7-12
start_rootdir : 13
Data : 45-7688
sectors : 7692
cluster_size : 4
no_of_cluster : 1911 (2 - 1912)
fat_length 6 calculated 6
heads/cylinder 64 (FAT) != 1 (HD)
sect/track 32 (FAT) != 1 (HD)
FAT12 158525100 158532791 7692 [OCS-EFI]
FAT12, 3938 KB / 3846 KiB
BAD_RS LBA=3574942274 1019
FAT16 >32M 3574942274 4880296993 1305354720
This partition ends after the disk limits. (start=3574942274, size=1305354720, end=585329697, disk end=201326592)
BAD_RS LBA=4249575660 1041
FAT12 4249575660 8397490645 4147914986
This partition ends after the disk limits. (start=4249575660, size=4147914986, end=4102523349, disk end=201326592)
BAD_RS LBA=2579706518 197
HPFS - NTFS 2579706518 6241267819 3661561302
This partition ends after the disk limits. (start=2579706518, size=3661561302, end=1946300523, disk end=201326592)
BAD_RS LBA=1599483164 485
FAT32 1599483164 5796666655 4197183492
This partition ends after the disk limits. (start=1599483164, size=4197183492, end=1501699359, disk end=201326592)
BAD_RS LBA=2477942735 913
FAT12 2477942735 3507448188 1029505454
This partition ends after the disk limits. (start=2477942735, size=1029505454, end=3507448188, disk end=201326592)
block_group_nr 625
block_group_nr 729
The harddisk (103 GB / 96 GiB) seems too small! (< 4299 GB / 4004 GiB)
get_geometry_from_list_part_aux head=1 nbr=30
get_geometry_from_list_part_aux head=8 nbr=3
Store new MBR code
