Thunderbird Mailbox
emash
Thunderbird Mailbox
#1 Post by emash »
Hello everyone!
I am trying to ressurect a Thunderbird mailbox which was lost due to changing account name in Thunderbird. So far I was only able to recover some of the contents (or all of contents) via .txt selection in photorec. The question is, are there any tips on creating a custom header file to undelete all of the 'mailbox files' for thunderbird to reenable my archive in Thunderbird as whole. Thank you, cheers.
Re: Thunderbird Mailbox
In my mbox-based Email Client Emails begin with a header line starting with "From - ". If you are using a different file format I have no hint for you.
Check your mail files on a different machine and open one of your mail files within your profile folder using a text editor like Notepad++. Open a smaller file preferrably.
Here is an example:
From - Thu Jan 29 19:32:33 2009
The rest of the line corresponds to a certain format but will vary as a function of date and time and does not qualify as a fixed fingerprint.
