Nicht mehr bootfähig, too small und weiteres
Re: Nicht mehr bootfähig, too small und weiteres
#11 Post by recuperation »
Weihnachtsmann wrote: 05 Jan 2024, 01:59 Von den -d Optionen die ich mir mit smartctl habe anzeigen lassen, verstehe ich absolut gar nichts! Was muss ich hier eingeben?
Das weiß ich auch nicht. Ausprobieren!
Weihnachtsmann
#12 Post by Weihnachtsmann »
Einfach heute nochmal probiert und - es hat -warum auch immer- geklappt:
Ich hoffe dies hilft!
smartctl 7.4 2023-08-01 r5530 [x86_64-w64-mingw32-w10-22H2] (sf-7.4-1)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Blue
Device Model: WDC WD40EZRZ-00GXCB0
Serial Number: WD-WCC7K6AR7769
LU WWN Device Id: 5 0014ee 2655a3695
Firmware Version: 80.00A80
User Capacity: 4.000.787.030.016 bytes [4,00 TB]
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5528
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Jan 10 07:49:46 2024 MZ
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: (44700) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 474) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 189 156 021 Pre-fail Always - 5533
4 Start_Stop_Count 0x0032 097 097 000 Old_age Always - 3407
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 083 083 000 Old_age Always - 12707
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 097 097 000 Old_age Always - 3261
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 140
193 Load_Cycle_Count 0x0032 197 197 000 Old_age Always - 10793
194 Temperature_Celsius 0x0022 131 102 000 Old_age Always - 19
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 23
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
The above only provides legacy SMART information - try 'smartctl -x' for more
#13 Post by recuperation »
Außer dem UDMA-Fehler, der wohl auf Verbindungsprobleme mit dem Rechner hindeutet, kann ich keine Auffälligkeit finden.
Weihnachtsmann
#14 Post by Weihnachtsmann »
:-) Das freut mich natürlich sehr und habe ich nach den Ergebnissen auch nicht anders erwartet. Wie bekomme ich nun die ?Partitionstabelle? wieder geschrieben? Was muss ich machen ?
#15 Post by recuperation »
Zum vierten Mal: Die TestDisk-Logdatei veröffentlichen.
Weihnachtsmann
#16 Post by Weihnachtsmann »
Log Datei -
(Suche nach Partition table EFI/GPT)
Thu Jan 11 00:10:46 2024
TestDisk 7.2-WIP, Data Recovery Utility, February 2023
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=4000098047488
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=500030242816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=65667072
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=4000768327680
Disk \\.\PhysicalDrive0 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - ST4000DM004-2CV104, S/N:ZFN51K9W, FW:0001
Disk \\.\PhysicalDrive1 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - WDC WD40EZRZ-00GXCB0, S/N:WD-WCC7K6AR7769, FW:80.00A80
Disk \\.\PhysicalDrive2 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512 - ST4000DM004-2CV104, S/N:ZFN57CYM, FW:0001
Disk \\.\PhysicalDrive1 - 4000 GB / 3726 GiB - WDC WD40EZRZ-00GXCB0
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive1 - 4000 GB / 3726 GiB - CHS 486401 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=7814037167 (expected 7814037167)
hdr_lba_start=34
hdr_lba_end=7814037134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Reserved 2048 34815 32768 [Microsoft reserved partition]
2 P MS Data 34816 7813006731 7812971916 [Basic data partition] [Windows 10 Sept 2018]
3 P Windows Recovery Env 7813007360 7814033407 1026048
NTFS at 2/42/41
filesystem size 7812971916
mftmirr_lcn 2
NTFS part_offset=17825792, part_size=4000241620992, sector_size=512
NTFS at 2/42/41
mftmirr_lcn 2
MS Data 34816 7813006731 7812971916 [Windows 10 Sept 2018]
NTFS, blocksize=4096, 4000 GB / 3725 GiB
NTFS at 486337/54/54
filesystem size 1026048
mft_lcn 42752
mftmirr_lcn 2
MS Data 7811981313 7813007360 1026048
NTFS found using backup sector, blocksize=4096, 525 MB / 501 MiB
mft_lcn 42752
mftmirr_lcn 2
MS Data 7813007360 7814033407 1026048
NTFS, blocksize=4096, 525 MB / 501 MiB
NTFS at 486401/53/52
filesystem size 7814000640
mftmirr_lcn 2
MS Data 34816 7814035455 7814000640 [Windows 10 Sept 2018]
NTFS found using backup sector, blocksize=4096, 4000 GB / 3726 GiB
mftmirr_lcn 2
NTFS: Can't read MFT
MS Data 7814035455 15628036094 7814000640
NTFS, blocksize=4096, 4000 GB / 3726 GiB
This partition ends after the disk limits. (start=7814035455, size=7814000640, end=15628036094, disk end=7814037168)
file_win32_pread(400,11,buffer,7814037158(486401/80/54)) read err: read after end of file
file_win32_pread(400,11,buffer,7814037160(486401/80/56)) read err: read after end of file
file_win32_pread(400,11,buffer,7814037166(486401/80/62)) read err: read after end of file
file_win32_pread(400,8,buffer,7814037161(486401/80/57)) read err: read after end of file
file_win32_pread(400,3,buffer,7814037167(486401/80/63)) read err: read after end of file
file_win32_pread(400,8,buffer,7814037165(486401/80/61)) read err: read after end of file
file_win32_pread(400,14,buffer,7814037156(486401/80/52)) read err: read after end of file
file_win32_pread(400,14,buffer,7814037157(486401/80/53)) read err: read after end of file
file_win32_pread(400,14,buffer,7814037158(486401/80/54)) read err: read after end of file
file_win32_pread(400,14,buffer,7814037159(486401/80/55)) read err: read after end of file
file_win32_pread(400,14,buffer,7814037160(486401/80/56)) read err: read after end of file
file_win32_pread(400,14,buffer,7814037162(486401/80/58)) read err: read after end of file
file_win32_pread(400,14,buffer,7814037164(486401/80/60)) read err: read after end of file
file_win32_pread(400,14,buffer,7814037166(486401/80/62)) read err: read after end of file
The hard disk (4000 GB / 3726 GiB) seems too small! (< 8001 GB / 7452 GiB)
Weihnachtsmann
#17 Post by Weihnachtsmann »
Nochmal - erweitert (einige Dateinamen gekürzt)
Thu Jan 11 00:56:02 2024
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 2/42/41
mftmirr_lcn 2
NTFS at 2/42/41
mftmirr_lcn 2
mft_lcn 42752
mftmirr_lcn 2
mft_lcn 42752
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
file_win32_pread(556,11,buffer,7814037158(486401/80/54)) read err: read after end of file
file_win32_pread(556,11,buffer,7814037160(486401/80/56)) read err: read after end of file
file_win32_pread(556,11,buffer,7814037166(486401/80/62)) read err: read after end of file
file_win32_pread(556,8,buffer,7814037161(486401/80/57)) read err: read after end of file
file_win32_pread(556,3,buffer,7814037167(486401/80/63)) read err: read after end of file
file_win32_pread(556,8,buffer,7814037165(486401/80/61)) read err: read after end of file
file_win32_pread(556,14,buffer,7814037156(486401/80/52)) read err: read after end of file
file_win32_pread(556,14,buffer,7814037157(486401/80/53)) read err: read after end of file
file_win32_pread(556,14,buffer,7814037158(486401/80/54)) read err: read after end of file
file_win32_pread(556,14,buffer,7814037159(486401/80/55)) read err: read after end of file
file_win32_pread(556,14,buffer,7814037160(486401/80/56)) read err: read after end of file
file_win32_pread(556,14,buffer,7814037162(486401/80/58)) read err: read after end of file
file_win32_pread(556,14,buffer,7814037164(486401/80/60)) read err: read after end of file
file_win32_pread(556,14,buffer,7814037166(486401/80/62)) read err: read after end of file
NTFS Volume is dirty.
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 7-Dec-2023 04:00 .
5 dr-xr-xr-x 0 0 0 7-Dec-2023 04:00 ..
231 dr-xr-xr-x 0 0 0 17-Oct-2023 16:48 $Recycle.Bin
407767 dr-xr-xr-x 0 0 0 17-Dec-2021 01:08 $SysReset
241 dr-xr-xr-x 0 0 0 17-Nov-2023 11:52 $WinREAgent
888 dr-xr-xr-x 0 0 0 24-Jan-2019 10:42 AAA SAFE
42840 dr-xr-xr-x 0 0 0 3-Oct-2020 14:48 AdwCleaner
9011 dr-xr-xr-x 0 0 0 20-Oct-2020 20:58 Air Force One Boeing 747-8i-12-1-1-1598281591
75241 dr-xr-xr-x 0 0 0 13-Sep-2019 04:54 Bu
260974 dr-xr-xr-x 0 0 0 5-Dec-2023 02:33 Config.Msi
294083 dr-xr-xr-x 0 0 0 22-Feb-2019 18:31 CyberLink
75242 dr-xr-xr-x 0 0 0 13-Sep-2019 04:54 Der.
28887 dr-xr-xr-x 0 0 0 28-Aug-2019 01:14 Documents and Settings
144 dr-xr-xr-x 0 0 0 17-Sep-2018 12:48 Dokumente und Einstellungen
101310 dr-xr-xr-x 0 0 0 19-May-2020 21:28 EP
237196 dr-xr-xr-x 0 0 0 23-Sep-2018 02:29 MSOCache
260260 dr-xr-xr-x 0 0 0 12-Oct-2018 08:51 Mozilla
553932 dr-xr-xr-x 0 0 0 7-Dec-2019 10:14 PerfLogs
17810 dr-xr-xr-x 0 0 0 21-Jun-2020 16:36 P
553933 dr-xr-xr-x 0 0 0 29-Mar-2023 11:27 Program Files
556825 dr-xr-xr-x 0 0 0 10-Nov-2023 23:58 Program Files (x86)
556934 dr-xr-xr-x 0 0 0 9-Dec-2023 14:06 ProgramData
156 dr-xr-xr-x 0 0 0 17-Sep-2018 12:48 Programme
194224 dr-xr-xr-x 0 0 0 13-Sep-2023 14:26 Recovery
22225 dr-xr-xr-x 0 0 0 9-Jun-2022 13:02 SA
63432 dr-xr-xr-x 0 0 0 27-Sep-2018 14:07 Sandbox
85483 dr-xr-xr-x 0 0 0 7-Dec-2023 02:59 System Volume Information
84873 dr-xr-xr-x 0 0 0 14-Oct-2019 16:28 T
161114 dr-xr-xr-x 0 0 0 25-Nov-2019 13:50 Ue
557077 dr-xr-xr-x 0 0 0 17-Oct-2023 16:49 Users
557135 dr-xr-xr-x 0 0 0 19-Nov-2023 22:10 Windows
84275 dr-xr-xr-x 0 0 0 12-Sep-2019 04:40 fc_
163378 dr-xr-xr-x 0 0 0 31-May-2023 08:44 st
258309 dr-xr-xr-x 0 0 0 30-Oct-2018 17:34 usr
10975 dr-xr-xr-x 0 0 0 14-Oct-2023 21:17 vi
453949 -r--r--r-- 0 0 0 18-May-2019 13:03 $WINRE_BACKUP_PARTITION.MARKER
84494 -r--r--r-- 0 0 386869 20-May-2014 10:56 AGR Akuter Erstickungsanfall.pdf
84494 -r--r--r-- 0 0 26 20-May-2014 10:56 AGR Akuter Erstickungsanfall.pdf:Zone.Identifier
47751 -r--r--r-- 0 0 3357960 20-Oct-2020 19:41 Air Force One Boeing 747-8i-12-1-1-1598281591.rar
47751 -r--r--r-- 0 0 256 20-Oct-2020 19:41 Air Force One Boeing 747-8i-12-1-1-1598281591.rar:Zone.Identifier
84289 -r--r--r-- 0 0 370709 15-Feb-2017 04:22 Con
84289 -r--r--r-- 0 0 26 15-Feb-2017 04:22 Con
84482 -r--r--r-- 0 0 19141732 19-May-2017 15:38 Cossa_195_006.tif
84675 -r--r--r-- 0 0 11058268 19-May-2017 15:38 Cossa_246_007.tif
84676 -r--r--r-- 0 0 11219720 19-May-2017 15:38 Cossa_246_008.tif
84677 -r--r--r-- 0 0 16688460 19-May-2017 15:38 Cossa_276_002.tif
84678 -r--r--r-- 0 0 16761508 19-May-2017 15:38 Cossa_276_003.tif
597350 -r--r--r-- 0 0 70746112 7-Nov-2019 02:31 C
464631 -r--r--r-- 0 0 162640574 10-May-2020 15:04 Derrick_Folge_132-Kranzniederlegung_1985.mp4
464631 -r--r--r-- 0 0 0 10-May-2020 15:04 Derrick_Folge_132-Kranzniederlegung_1985.mp4
464631 -r--r--r-- 0 0 236 10-May-2020 15:04 Derrick_Folge_132-Kranzniederlegung_1985.mp4:Zone.Identifier
2492 -r--r--r-- 0 0 8192 16-Jan-2022 12:30 DumpStack.log
3099 -r--r--r-- 0 0 8192 4-Dec-2023 16:45 DumpStack.log.tmp
84550 -r--r--r-- 0 0 484313 4-Dec-2014 09:04 Je
84550 -r--r--r-- 0 0 26 4-Dec-2014 09:04 Jen
84551 -r--r--r-- 0 0 3717413 8-Oct-2015 17:10 Jur
84551 -r--r--r-- 0 0 26 8-Oct-2015 17:10 Ju
84552 -r--r--r-- 0 0 21937 16-Dec-2015 14:20 Kr
84552 -r--r--r-- 0 0 26 16-Dec-2015 14:20 Krt
84549 -r--r--r-- 0 0 1915973 7-Apr-2015 19:57 LG-
84549 -r--r--r-- 0 0 26 7-Apr-2015 19:57 LG-M
84872 -r--r--r-- 0 0 24472 19-Feb-2018 21:54 LeagueGothic-Regular.otf
84872 -r--r--r-- 0 0 27 19-Feb-2018 21:54 LeagueGothic-Regular.otf:Zone.Identifier
84548 -r--r--r-- 0 0 80124 19-May-2015 16:43 Merkblatt Rechnungen und Vorsteuerabzug.pdf
84548 -r--r--r-- 0 0 26 19-May-2015 16:43 Merkblatt Rechnungen und Vorsteuerabzug.pdf:Zone.Identifier
84554 -r--r--r-- 0 0 188863 17-Dec-2015 04:36 Merkblatt_Unternehmenskonzept.pdf
84554 -r--r--r-- 0 0 26 17-Dec-2015 04:36 Merkblatt_Unternehmenskonzept.pdf:Zone.Identifier
84594 -r--r--r-- 0 0 2057139 21-Oct-2015 07:37 MidasReport.pdf
84594 -r--r--r-- 0 0 26 21-Oct-2015 07:37 MidasReport.pdf:Zone.Identifier
30419 -r--r--r-- 0 0 235986 13-Nov-2013 12:12 M
30419 -r--r--r-- 0 0 26 13-Nov-2013 12:12 M
84595 -r--r--r-- 0 0 2929335 21-Apr-2014 10:36 MysticThumbs.zip
84595 -r--r--r-- 0 0 26 21-Apr-2014 10:36 MysticThumbs.zip:Zone.Identifier
84307 -r--r--r-- 0 0 76333 8-Jun-2014 09:07 Pedalschalter.pdf
84307 -r--r--r-- 0 0 26 8-Jun-2014 09:07 Pedalschalter.pdf:Zone.Identifier
84672 -r--r--r-- 0 0 34528 26-Sep-2009 20:07 PeperoncinoPepper_clip_art_hight.png
84673 -r--r--r-- 0 0 15479 26-Sep-2009 20:07 PeperoncinoPepper_clip_art_medium.png
84674 -r--r--r-- 0 0 4245 26-Sep-2009 20:07 PeperoncinoPepper_clip_art_small.png
84276 -r--r--r-- 0 0 389758 2-Oct-2012 09:05
84276 -r--r--r-- 0 0 26 2-Oct-2012 09:05
84320 -r--r--r-- 0 0 51721680 22-Mar-2013 17:35
84320 -r--r--r-- 0 0 26 22-Mar-2013 17:35
84588 -r--r--r-- 0 0 3374680 28-Jan-2014 14:02
84588 -r--r--r-- 0 0 26 28-Jan-2014 14:02
84590 -r--r--r-- 0 0 198087 22-Jun-2014 12:29
84590 -r--r--r-- 0 0 26 22-Jun-2014 12:29
84627 -r--r--r-- 0 0 889816 27-May-2015 13:22 SalzburgAi4c3ad61f12587.pdf
84627 -r--r--r-- 0 0 26 27-May-2015 13:22 SalzburgAi4c3ad61f12587.pdf:Zone.Identifier
84592 -r--r--r-- 0 0 95147 30-Jan-2013 18:58 Scan-130130-0001.pdf
84592 -r--r--r-- 0 0 26 30-Jan-2013 18:58 Scan-130130-0001.pdf:Zone.Identifier
84629 -r--r--r-- 0 0 118377 28-Jan-2016 17:12 Schnitzelbratenjagd.pdf
84629 -r--r--r-- 0 0 26 28-Jan-2016 17:12 Schnitzelbratenjagd.pdf:Zone.Identifier
84636 -r--r--r-- 0 0 46081 8-Jun-2014 09:04
84636 -r--r--r-- 0 0 26 8-Jun-2014 09:04
84670 -r--r--r-- 0 0 129071 17-Jun-2015 07:36 TagdpWqS89r1.zip
84670 -r--r--r-- 0 0 26 17-Jun-2015 07:36 TagdpWqS89r1.zip:Zone.Identifier
84624 -r--r--r-- 0 0 53861 8-Jun-2014 09:05 Tempomat.pdf
84624 -r--r--r-- 0 0 26 8-Jun-2014 09:05 Tempomat.pdf:Zone.Identifier
84666 -r--r--r-- 0 0 218993 21-Jun-2013 15:51 Toyota Deutschland Media-Website - Toyota Hilux _ der Allrounder.pdf
84666 -r--r--r-- 0 0 26 21-Jun-2013 15:51 Toyota Deutschland Media-Website - Toyota Hilux _ der Allrounder.pdf:Zone.Identifier
84667 -r--r--r-- 0 0 2362997 20-Mar-2014 02:09
84667 -r--r--r-- 0 0 26 20-Mar-2014 02:09
84668 -r--r--r-- 0 0 26 19-Aug-2015 14:48
84638 -r--r--r-- 0 0 136925 29-Mar-2016 12:53
84638 -r--r--r-- 0 0 26 29-Mar-2016 12:53
84637 -r--r--r-- 0 0 24114 14-Oct-2015 15:33 Vollmacht.pdf
84637 -r--r--r-- 0 0 26 14-Oct-2015 15:33 Vollmacht.pdf:Zone.Identifier
259999 -r--r--r-- 0 0 264 12-Oct-2018 08:49 desktop.ini
84267 -r--r--r-- 0 0 6087640 20-Jan-2017 11:55 exiftool-10.40.zip
84267 -r--r--r-- 0 0 26 20-Jan-2017 11:55 exiftool-10.40.zip:Zone.Identifier
84266 -r--r--r-- 0 0 1390256 20-Jan-2017 13:26 exiftoolgui516.zip
84266 -r--r--r-- 0 0 26 20-Jan-2017 13:26 exiftoolgui516.zip:Zone.Identifier
84671 -r--r--r-- 0 0 248946 15-Jun-2009 19:55 ghostship_1280_2.jpg
242123 -r--r--r-- 0 0 6843879424 9-Dec-2023 14:06 hiberfil.sys
84277 -r--r--r-- 0 0 996642 15-Mar-2016 23:18 horroroid.zip
84277 -r--r--r-- 0 0 26 15-Mar-2016 23:18 horroroid.zip:Zone.Identifier
84555 -r--r--r-- 0 0 47366 10-Dec-2013 22:37 light_up_the_world.zip
84555 -r--r--r-- 0 0 26 10-Dec-2013 22:37 light_up_the_world.zip:Zone.Identifier
84265 -r--r--r-- 0 0 28365 26-Apr-2017 18:44 mobsters.zip
84265 -r--r--r-- 0 0 26 26-Apr-2017 18:44 mobsters.zip:Zone.Identifier
85491 -r--r--r-- 0 0 7855611904 8-Dec-2023 19:50 pagefile.sys
84385 -r--r--r-- 0 0 230792 4-Dec-2015 00:26 pottymouthbb_tt.zip
84385 -r--r--r-- 0 0 26 4-Dec-2015 00:26 pottymouthbb_tt.zip:Zone.Identifier
84587 -r--r--r-- 0 0 127253 19-Nov-2012 11:18
84587 -r--r--r-- 0 0 26 19-Nov-2012 11:18
84622 -r--r--r-- 0 0 7737337 19-Feb-2014 11:16 reisetipps_03-10_Teil2.pdf
84622 -r--r--r-- 0 0 26 19-Feb-2014 11:16 reisetipps_03-10_Teil2.pdf:Zone.Identifier
84787 -r--r--r-- 0 0 18232 12-Dec-2016 14:05 robot_head.png
84787 -r--r--r-- 0 0 26 12-Dec-2016 14:05 robot_head.png:Zone.Identifier
84625 -r--r--r-- 0 0 27254 19-May-2015 15:47 selbst_Rechnungsausstellung2004.pdf
84625 -r--r--r-- 0 0 26 19-May-2015 15:47 selbst_Rechnungsausstellung2004.pdf:Zone.Identifier
84631 -r--r--r-- 0 0 111464 9-Nov-2014 01:57 sf_movie_poster.zip
84631 -r--r--r-- 0 0 26 9-Nov-2014 01:57 sf_movie_poster.zip:Zone.Identifier
84686 -r--r--r-- 0 0 506 28-Mar-2015 14:10
84686 -r--r--r-- 0 0 1150 28-Mar-2015 14:10
84635 -r--r--r-- 0 0 1227218 21-Jan-2015 17:36 ssshot14.zip
84634 -r--r--r-- 0 0 81877 16-Dec-2015 13:53
84634 -r--r--r-- 0 0 26 16-Dec-2015 13:53
84633 -r--r--r-- 0 0 81877 16-Dec-2015 13:29
84633 -r--r--r-- 0 0 26 16-Dec-2015 13:29
84669 -r--r--r-- 0 0 223361 26-Nov-2015 06:17 sv5_2009_pdf.pdf
84669 -r--r--r-- 0 0 26 26-Nov-2015 06:17 sv5_2009_pdf.pdf:Zone.Identifier
85494 -r--r--r-- 0 0 268435456 4-Dec-2023 16:45 swapfile.sys
84663 -r--r--r-- 0 0 45268568 2-Sep-2012 22:11
84663 -r--r--r-- 0 0 26 2-Sep-2012 22:11
84664 -r--r--r-- 0 0 45324 22-Mar-2013 16:02 ticket.pdf
84664 -r--r--r-- 0 0 26 22-Mar-2013 16:02 ticket.pdf:Zone.Identifier
84665 -r--r--r-- 0 0 604849 25-Aug-2014 16:38 tk-broschuere-arthrose.pdf
84665 -r--r--r-- 0 0 26 25-Aug-2014 16:38 tk-broschuere-arthrose.pdf:Zone.Identifier
75241 dr-xr-xr-x 0 0 0 13-Sep-2019 04:54 Bunt bedrucktes Papier
17810 dr-xr-xr-x 0 0 0 21-Jun-2020 16:36 Politische Witze
84281 dr-xr-xr-x 0 0 0 12-Sep-2019 04:41 mobsters
163378 dr-xr-xr-x 0 0 0 31-May-2023 08:44 steuer
84668 -r--r--r-- 0 0 105757 19-Aug-2015 14:48
84587 -r--r--r-- 0 0 127253 19-Nov-2012 11:18 prednisolon.pdf
84587 -r--r--r-- 0 0 26 19-Nov-2012 11:18 prednisolon.pdf:Zone.Identifier
#18 Post by recuperation »
Das sieht für mich bis jetzt alles sehr gut aus!
Bitte die nicht mehr bootende Festplatte an ein zweites Windows-System mit mindestens Windows Vista anschließen und versuchen auf das Laufwerk "Windows 10 Sept 2018" zuzugreifen.
Dann eventuell noch nicht gesicherte Daten sichern, und per chkdsk-Befehl wie im Handbuch beschrieben das oben genannte Laufwerk reparieren.
Wenn der Laufwerkszugriff nicht klappt, also keine Inhalte von "Windows 10 Sept 2018" angezeigt werden, wäre es sinnvoll mit ddrescue unter Linux die Festplatte zu klonen und erst dann chkdsk aufzurufen.
Die Festplatte dann wieder in den Ursprungsrechner einbauen. Rechner starten und im BIOS prüfen, ob der Startmodus auf UEFI/GPT (nicht legacy oder MBR oder ähnliches eingestellt ist).
Wenn der Rechner jetzt nicht startet, mit Hilfe eines Wiederherstellungsdatenträgers oder der vielleicht schon installierten Recovery-Umgebung versuchen die Installation zu reparieren.
Scheitert das, das System bitte neu installieren.
Hinweis:
Ich nutze selber kein Windows 10 und der obige Text beinhaltet ziemlich allgemeine Ratschläge!
Daten und Installation besser auf zwei Datenträger aufteilen, z.B. SSD für's Betriebssystem und HDD für die Daten!
Weihnachtsmann
#19 Post by Weihnachtsmann »
Das freut mich!!!
Es ist kein Zugriff möglich. Bild der Datenträgerverwaltung im Anhang.
Versuche ich über den Explorer D oder F aufzurufen, kommt der Hinweis - Ich müsse den Datenträger erst formatieren (Screenshot)
Ich versuche jetzt nochmal zu klonen und führe dann chkdsk aus.
Weihnachtsmann
#20 Post by Weihnachtsmann »
Hallo recuperation - ich bin dran! ABER...
Ich möchte ja eine 1zu1 Kopie, einen KLON und keine Imagedatei?! um dann an/mit dem Klon weiterzuarbeiten (chkdsk).
Nun finden sich im Internet zahlreiche teils widersprüchliche Verwendungen der Begriffe, eine Vielzahl an Kommandos und jeder hat da irgendeine "Verbesserung" oder schreibt Romane, in denen er sich selbst widerspricht bzw. mit den Begriffen Image/Abbild/Klon jongliert, bis er offensichtlich selbst nicht mehr weiß, wovon er redet.
Ich habe jetzt Knoppix 9.1
Die defekte Platte ist die sdb
von dieser möchte ich eine exakte 1 zu 1 Kopie (KLON) auf die neue Platte sda
Jetzt will ich natürlich nichts falsch machen - ist
ddrescue -f /dev/sdb /dev/sda
der richtige Befehl?
Oder muss ich mit -d direct access und oder -r3 arbeiten? Da ich 0, EXAKT NULL Ahnung von Linux habe und bevor ich irgendwas mache, was vermeintliche Experten schreiben, wäre es toll. Ich bekomme von Ihnen die richtige, aus ihrer Sicht sinnvollste Kommandozeile!
Danke!
