Successful partition recovery on a SanDisk Micro SDXC Card
grateful
#1 Post by grateful »
Merci Christophe Grenier!
I could successfully restore two lost partitions on a SanDisk Extreme® microSDXC™ UHS-I card, using the simple commands very well documented on your TestDisk Documentation page: I just confirmed at "Write" with Enter, then pressed y and OK.
160GB of data usable again.
Super easy, worked instantly!
Grazie!
Re: Successful partition recovery on a SanDisk Micro SDXC Card
Thank you for leaving a positive feedback!
On that particular occasion I would like to remind you of a yellowish button on the page
https://www.cgsecurity.org/
which provides you with additionals possibilities of expressing your gratitude! 8-)
