can't find internal mac hard drive
stray359
#1 Post by stray359 »
I am admittedly very unfamiliar with macs and data recovery, but am hoping to get some precious personal files from my mac. I have one internal hard drive with a single partition in the HFS+ format. So, from what I gather, I need to use PhotoRec instead of TestDisk. However, when I simply double click the PhotoRec icon, no hard drives show up in the terminal. I receive a message that says I need to run the program as the root user. So I navigate to the TestDisk folder and sudo ./photorec. After I enter my password, the program doesn't load and nothing appears to happen (see below). Does anyone have an idea of what I'm doing incorrectly?
Thanks for any help you can provide!
Last login: Sun Jun 24 21:50:02 on console
-macbook:~ johndoe$ cd /Users/johndoe/Downloads/testdisk-6.14-WIP
-macbook:testdisk-6.14-WIP johndoe$ ls
78 README ico
AUTHORS THANKS photorec
COPYING VERSION photorec.8
ChangeLog documentation.html readme.txt
INFO fidentify testdisk
NEWS fidentify.8 testdisk.8
-macbook:testdisk-6.14-WIP johndoe$ sudo ./photorec
WARNING: Improper use of the sudo command could lead to data loss
or the deletion of important system files. Please double-check your
typing when using sudo. Type "man sudo" for more information.
To proceed, enter your password, or type Ctrl-C to abort.
Password:
Re: can't find internal mac hard drive
Disconnect your USB card reader, external disks... and check if you still have the problem.
If you start PhotoRec, does it work better if you select [Sudo] in the menu ?
