Attempting to Recover an ESXi Disk; Possible?
lildisk
#1 Post by lildisk »
Some background info:
The failed disk is a 500 GB Samsung 860 EVO V-NAND SSD. (/dev/sda)
The disk contains both the vSphere ESXi OS and the VM files (*.vmdk, *.vmx, etc.) for 13 virtual machines.
I have successfully copied the contents (via dd) to a new 500 GB Samsung 870 EVO V-NAND SSD. (/dev/sdf)
Both the original and cloned disks are installed internally and attached to the motherboard's onboard SATA controller.
The motherboard is a SuperMicro Superserver MBD-X11SSL-F-O (x86_64)
I am currently running TestDisk (and other utils) from the Arch Linux 2024.03.01 install media via live DVD.
What has happened so far:
My home server failed on Friday evening after about 150 days of uptime, if I remember correctly. It was running ESXi 7.0U3. There were no prior indications that the boot disk was failing or had any issues.
The server was shut down cleanly and removed from power for about two hours. When it was plugged back in, the server would no longer boot and the VMware vSphere entry was no longer visible in the UEFI boot selection menu.
I booted up a copy of the latest Arch Linux installation media and found (via fdisk) that only one partition (/dev/sda7, 6.3G) was present on the boot disk. The entire disk should be in use, as it contained a VMFS datastore with all of my VMs on it.
I purchased the closest thing I could find to the original disk, and I originally attempted copying to the new disk via a USB enclosure, but I have since learned about the Advanced Format 4Kn problem. I relocated the new disk internally and copied the contents of the original disk to it again. I am currently performing all tests on the new disk/clone (sdf) to prevent any unnecessary/accidental writes to the original (sda).
Both the new disk and the original report the same number of sectors (500107862016 bytes, 976773168 sectors), and the same physical/logical sector sizes (512/512).
Prior to running TestDisk, I also used gpart to see if it would find any errors (it did not), and I tried (without writing any changes!) loading the backup partition table to see if it contained any entries not present in the main table (it did not).
So here is the output of TestDisk run on /dev/sdf:
Disk /dev/sdf - 500 GB /465 GiB - CHS 60801 255 63
Quick Scan
     Partition              Start        End    Size in sectors
 P EFI System                   64     204863     204800 [EFI System Partition] [BOOT]
 P MS Data                  208896    1232895    1024000 [BOOTBANK1]
 P MS Data                 1234944    2258943    1024000 [BOOTBANK2]
 P MS Data                 7086080   15472639    8386560
 P MS Data               412153936  412155535       1600 [NO NAME]
Deeper Search
 D EFI System                   64     204863     204800 [EFI System Partition] [BOOT]
 D MS Data                    8224     520191     511968
 D MS Data                  208896    1232895    1024000 [BOOTBANK1]
 D MS Data                 1234944    2258943    1024000 [BOOTBANK2]
 D MS Data                 1843200    7086079    5242880
 D MS Data                 7086080   15472639    8386560
 D MS Data                 9639936    9642815       2880 [NO NAME]
I am not 100% sure, but I think the disk attached at /dev/sda may have once been used in a different computer, which could explain the presence of the overlapping partitions in the "deeper" search.
I know that VMware made some changes to the way the ESXi boot disk is formatted in ESXi 7.0, and their official literature mentions that the ESX-OSData and VMFS datastore partitions now have "dynamic" sizing. I'm not really familiar with what this actually looks like when examined with a tool like fdisk, so I don't know if what I'm seeing in the Quick Scan makes any sense.
Now that I'm working from a clone of the original disk, I don't see any real harm in attempting to restore the partitions found in the Quick Scan (at least) just to see what happens. But...am I wasting my time? Will TestDisk be useful in this scenario, or will it have problems recognizing the ESXi partitions/partition scheme? Can TestDisk recognize a VMFS partition?
If anyone has experience using TestDisk on an ESXi 7.x (or later) boot disk, any input or guidance would be greatly appreciated.
Thanks for reading, and please let me know if I need to provide any additional information!
Edit 1: Quick Update
What the heck, right? I went ahead and allowed TestDisk to restore all the partitions found during the initial Quick Scan. ESXi now boots, but there are issues.
In the vSphere Web UI, some of my VMs are missing, and some remnants are present of VMs that were deleted months ago. It's as if ESXi has been restored to an old state somehow.
There are currently 13 VMs present, including 4 marked as "Invalid" which appear to be the old, deleted VMs mentioned above. At least 1 VM that is missing from the UI is still present on the VMFS Datastore partition. Further investigation is needed, so I'll be digging into the filesystem and logs. Fortunately, the most important VMs are now visible, and I am in the process of copying them to a new location outside of the server.
Since I had already accepted that there would be some data loss, but my three most important VMs appear to be recoverable, I consider this recovery operation to be mostly complete (pending a successful boot of those critical VMs), but I would like to continue testing.
Primarily, I want to know if one of the partitions I restored might have been unnecessary. My theory is: if TestDisk found an old partition in the middle of the large area of the disk that contains the "dynamic" ESX-OSData and VMFS Datastore partitions, I suspect marking it as active could have "corrupted" some things and caused the strangeness I'm seeing in the vSphere UI at the moment.
After all the important data has been copied/backed up, I plan to re-copy the contents of /dev/sda to /dev/sdf, run TestDisk on /dev/sdf again, and only restore 3 partitions to start: EFI System Partition, BOOTBANK1, and BOOTBANK2. I'm curious if the system will boot with only these three, but if not, my plan is to add the others to the partition table one by one until ESXi boots normally.
If I can find a another spare disk, I also plan to do a fresh install of ESXi 7.0U3 to see what a "clean" partition table should look like in fdisk/gdisk/etc.
I'll continue updating this as new information is available.
Edit 2: More initial findings
It's been about 12 hours since the last edit. Most of this time has been spent inspecting files on the datastore on the boot disk (DAS), copying the VM files to multiple other locations on my LAN, and lots of daydreaming; theorizing about what happened, planning out how to restore the server to a production-ready state, and questioning whether now is the time to jump from the sinking VMware ship (thanks, Broadcom!) or if I should bandage everything back up for now.
First up, here's an interesting artifact. This is what ESXi thinks /dev/sdf looks like after I used TestDisk to restore all the partitions it identified in the Quick Scan:
Lots going on there. Not sure what to make of it at the moment.
Anyways, all VMs that were stored on /dev/sdf were successfully exported as OVFs. I've only had the chance to import and boot one of them (via Workstation Player 17). It booted and ran without issues, but I won't trust any of them until I've run full disk checks.
I'm seeing some concerning things in the system logs from prior to the failure, but nothing conclusive yet. I also still need to collect logs from the system again and see if there are any show-stopping errors logged since it has been powered back on. More to come later.
I've been staring at the computer all day, so I'm done for now. Hopefully tomorrow I can start verifying the recovered VMs and maybe get to the TestDisk experiments I want to run. Stay tuned.
Edit 3: A New Day
Back at it again with the borked ESXi server. I decided to move forward with further testing and troubleshooting now that all the important data has been retrieved, and to verify the recovered VMs after some more experimentation with TestDisk. More on that later.
Before moving on, I need to document another issue with the recovered GPT/partition scheme that I hadn't noticed until now: the UEFI boot selection menu now contains two entries for VMware ESXi, both on the Samsung 870 EVO. Fun! That might come up again later as well. (Note from the Edit 4 times: It won't come up again. For some reason, I had my motherboard operating in some "dual" mode that allows booting both legacy and UEFI boot entries. Those responsible have been sacked.)
First up is a fresh install of ESXi 7.0U3n. Here's a screenshot of the new Samsung 870 EVO SSD (/dev/sdf, so far) from the WebUI of the new install:
It's immediately evident in comparing this with the previous screencap from the environment recovered by TestDisk that something went very very wrong. I'm now even more confounded by the fact that it not only booted, but allowed me to export all my VMs without crashing — and I also now trust those exported VMs even less...
Next, I booted the Arch Linux install media environment again and ran fdisk, gdisk, and TestDisk for comparisons now that I have a healthy install of ESXi. I'll be using these for comparisons with my later testing.
fdisk output for both disks.
/dev/sda, the original (failed) disk:
Disk model: Samsung SSD 860
Units: sectors of 1 * 512 = 512 bytes
Disklabel type: gpt
Disk identifier: 187BCE4E-516C-454A-8011-C9D399CFD0DA
Device       Start      End  Sectors  Size Type
/dev/sda7  2260992 15470591 13209600  6.3G unknown
/dev/sdf, the new disk with the fresh install of ESXi:
Disk /dev/sdf: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: Samsung SSD 870
Disklabel type: gpt
Disk identifier: 64B77D9A-49C7-4FC1-83AA-FDC39F0106E7
/dev/sdf1         64    204863    204800   100M EFI System
/dev/sdf5     208896   8595455   8386560     4G Microsoft basic data
/dev/sdf6    8597504  16984063   8386560     4G Microsoft basic data
/dev/sdf7   16986112 268435455 251449344 119.9G unknown
/dev/sdf8  268437504 976773134 708335631 337.8G VMware VMFS
gdisk primary partition table printed from both disks:
Partition table scan:
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
Found valid GPT with protective MBR; using GPT.
Disk /dev/sda: 976773168 sectors, 465.8 GiB
Model: Samsung SSD 860
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): 187BCE4E-516C-454A-8011-C9D399CFD0DA
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 976773134
Partitions will be aligned on 2048-sector boundaries
Total free space is 963563501 sectors (459.5 GiB)
Number  Start (sector)    End (sector)  Size       Code  Name
   7         2260992        15470591   6.3 GiB     FFFF  OSDATA
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
Disk /dev/sdf: 976773168 sectors, 465.8 GiB
Model: Samsung SSD 870
Disk identifier (GUID): 64B77D9A-49C7-4FC1-83AA-FDC39F0106E7
Partitions will be aligned on 64 sector boundaries
Total free space is 10206 sectors (5.0 MiB)
  1               64          204863   100.0 MiB   EF00  BOOT
  5           208896         8595455   4.0 GiB     0700  BOOTBANK1
  6          8597504        16984063   4.0 GiB     0700  BOOTBANK2
  7         16986112       269435455   119.9 GiB   FFFF  OSDATA
  8        268437504       976773134   337.8 GiB   FB00  datastore1
And last, but certainly not least, here's the initial TestDisk analysis of the partition table on the fresh install of ESXi (/dev/sdf)
https:// www.cgsecurity.org
Disk /dev/sdf - 500 GB / 465 GiB - CHS 60801 255 63
 1 P EFI System                     64     204863     204800 [BOOT]
check_FAT: Unusual number of reserved sectors 2 (FAT), should be 1.
Warning: number of heads/cylinder mismatches 64 (FAT) != 255 (HD)
 5 P MS Data                   208896    8595455    8386560 [BOOTBANK1] [BOOTBANK1]
Warning: number of heads/cylinder mismatches 64 (FAT), != 255 (HD)
 6 P MS Data                  8597504   16984063    8386560 [BOOTBANK2] [BOOTBANK2]
 7 P Unknown                 16986112  268435455  251449344 [OSDATA]
 8 P Unknown                268437504  976773134  708335631 [datastore1]
Lots to analyze here. I'll return to this later when I have more data.
Next up: I need to dig up an old disk—I'm sure there's one around here somewhere—and install ESXi on it to see how the partition sizes differ on a larger disk. Then I'm doing one (final) copy of /dev/sda to /dev/sdf, running TestDisk again, and restoring a different selection of partitions than the first time around, hopefully armed with new information about how the dynamic sizing of the ESX-OSData and VMFS datastore partitions affects the actual layout when viewed with these tools.
Be back soon!
Edit 4: Whole day I'm busy only get few money (or perhaps more accurately, Why Must I Be Sad?)
I found a decommissioned TB WD10EAVS-00D (1TB) drive in the back of my closet, popped it into the server, and installed ESXi 7.0U3n onto it. Here's what that disk looks like:
ESXi Host Client WebUI
fdisk
Disk /dev/sdf: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: WDC WD10EAVS-00D
Disklabel type: gpt
Disk identifier: B03F3111-F4E0-4B81-BEF1-CACAC97B3D0D
Device
/dev/sdf8  268437504 1953525134 1685087631 803.5G VMware VMFS
gdisk
  MBR: protective
  BSD: not present
  APM: not present
  GPT: present
Disk /dev/sdf: 1953525168 sectors, 931.5 GiB
Model: WDC WD10EAVS-00D
Disk identifier (GUID): B03F3111-F4E0-4B81-BEF1-CACAC97B3D0D
First usable sector is 34, last usable sector is 1953525134
Partitions will be aligned on 64-sector boundaries
   7        16986112       268435455   119.9 GiB   FFFF  OSDATA
   8       268437504      1953525134   803.5 GiB   FB00  datastore1
TestDisk
Disk /dev/sdf - 1000 GB / 931 GiB - CHS 121601 255 63
 8 P Unknown                268437504 1953525134 1685087631 [datastore1]
Here are my takeaways from what I've gathered so far:
The BOOTBANK1/2 partitions are not the same size on the fresh installs. The original disk had been through at least one update/upgrade, so maybe the partition sizing was different in the version that was first installed. If I remembered which version that was, I could install it and check. Unfortunately, that road ends here.
Despite the dynamic sizing touted by VMware, the BOOTBANK1, BOOTBANK2, and ESX-OSData partitions are the same size on both the 500GB SSD and 1TB HDD immediately after a fresh install. Only the VMFS datastore1 partition is larger on the HDD (which has a larger capacity). It could potentially take ages to test if/when/how those partition sizes change over time as the server is used, so another road unfortunately ends at this point. (I do want my server back, after all...)
The mystery 6.3 GiB partition that remains on the original failed disk is still...well, a mystery. Given that the EFI partition is probably 100 MiB, and assuming based on the partitions recovered by TestDisk that the two BOOTBANK partitions were 1 GiB each, the start sector for /dev/sda7 is probably correct, but the end sector is in a very odd position.
If we trust that BOOTBANK2 really ends on 2258943, the sda7 start sector of 2260992 is 2049 sectors away. This is probably the beginning of the ESX-OSData partition on the failed disk.
Compare this with the fresh install on the 870 SSD: BOOTBANK2 ends on 16984063, and the ESX-OSData partition begins on 16986112, also a difference of 2049 sectors. Makes sense. Nothing too crazy/proprietary going on there.
But in the TestDisk scans of the failed disk, none of the sectors found begin on 2260992. After BOOTBANK2, the next detected partition begins at 7086080 and ends at 15472639; that's a 4 GiB partition well inside of where the ESX-OSData partition should be.
I can only conclude that TestDisk is completely missing the ESX-OSData and VMFS datastore1 partitions. ESXi OS disks are not a supported use case for TestDisk, after all; it's totally understandable that its detection methods don't work here. If that's the case, it must be picking up on something else in the disk's contents that makes it think it has found a partition, just...not the partition I'm looking for. And thus, another road dead ends.
So my final test begins. I've copied all the data from the Samsung 860 EVO to the new 870 EVO again. I'm now going to use TestDisk to restore the EFI, BOOTBANK1, and BOOTBANK2 partitions on the 870, then see if it boots. Be back soon.
Edit 5: Booting with no data partitions
Well, that was fast. Ran TestDisk, restored the first three partitions, wrote changes, and rebooted. And something happened!
Unfortunately, a PSOD is what happened. But that magenta hellscape has led me to VMware KB91136. The specific error on-screen says:
An error occurred while backing up VFAT partition files before re-partitioning: Failed to calculate size for temporary
Ramdisk: expected str, bytes or os.PathLike object, not NoneType. This might be due to VFAT corruption, please refer to
 KB 91136 for steps to remediate the issue.
That's all I have the time or energy for today. Tune in again tomorrow for the thrilling conclusion!
Re: Attempting to Recover an ESXi Disk; Possible?
lildisk wrote: 11 Mar 2024, 05:11 Some background info:
The disk contains both the vSphere ESXi OS and the VM files (*.vmdk, *.vmx, etc.) for approximately 10 virtual machines.
My home server
Well, running 10 virtual machines is what the average "home user" is doing today! :lol:
failed on Friday evening after about 150 days of uptime, if I remember correctly. It was running ESXi 8.x, but I don't remember the exact revision (i.e., if I had installed 8.0U2b yet). There were no prior indications that the boot disk was failing or had any issues.
So here is the output of TestDisk run on /dev/sdf/:
Quick Scan
Deeper Search
As you can see here, there is no support for VMWare partitions:
In case of me being wrong you can still continue to run a deep scan.
Basically my answer ends here but as I have not read such a fine case description for a long time this is what I would do:
Keep in mind that I don't have any knowledge about ESXI products!
After running the deep scan with no results assumably, set up a new ESXCi installation on a third disk using the same installation media that you used for your "home server" and run TestDisk to see what it shows.
Based on the VMWare docs about ESXI server 7.0 and above that you find using a search engine you end up with a link looking like
https://docs.vmware.com/en/VMware-vSphe ... stall.doc/....
you learn that you are missing two partitions:
ESX-OSData
VMFS datastore
I assume that both partitions start with a kind of boot sector which probably contains at least one variable data which is the partition size.
Use a fourth disk with a different disk size than the third one and big enough that ESXI server will install both partitions above. That minimum size requirement applies to the third disk as well!
The idea is to find out locations where the boot sector content varies.
I guess that the boot sectors of ESX-OSData will vary at least where the partition size is coded within the partition.
It might as well be that the boot sector contains an ID that will vary from one installation to another.
What VMWare writes about dynamic partition size might only apply to the space within one partition.
You have to find the common denominator of both installations (on the third and on the fourth disk). If you have friends who could pass you their boot sectors as well this would be advantage.
You would then search the whole disk for the common denominator (a byte sequence) on your broken ESXI server. If you find nothing you would need to reduce the size of the sequence and run again.
If you think that you found the partition you would manually add it to the partition table using TestDisk.
There might be no requirement to make your broken server bootable, perhaps by adding the repaired disk to a working ESXI server you might be able to look inside ESX-OSData.
The same strategy applies to the partition "VMFS datastore".
Do not forget, I am just guessing!
Good luck.
lildisk
#3 Post by lildisk »
Thanks, recuperation! I think you and I are on the same wavelength about the next steps.
At this point, I am also just guessing, since in an enterprise production vSphere environment, we'd have blown away the ESXi host and redeployed from backups long before attempting a partition table recovery. :lol: (Mind you, we also wouldn't be storing the VMs on the same disk as the OS boot partition...that's just poor practice on my part.)
I think an interesting finding in all this is that TestDisk can actually recognize some of the ESXi partitions even though this is an unsupported edge case.
I'm deep in the weeds of inspecting the filesystem and copying data off the server at the moment, but I'll keep updating this post if there are new developments. If nothing else, hopefully someone else might find it useful in the future!
