recover mail takeout
huburt
#1 Post by huburt »
I have lost a zip archive from google takeout, as a result of a hhd crash, I have run a recovery with photorec and found most of the files that were lost but not my takeout.zip. what I have after the zip file is mbox, html. txt, sqlite, elt , jsonlz4, gz. some are large 3gb. the files that contain data from mail zip are located in 9 different recup_dir. is there a way to assemble the takeout.zip file and make mail date readable, usable. ? ;)
Re: recover mail takeout
huburt wrote: 25 Apr 2024, 14:06 I have lost a zip archive from google takeout, as a result of a hhd crash, I have run a recovery with photorec and found most of the files that were lost but not my takeout.zip. what I have after the zip file is mbox, html. txt, sqlite, elt , jsonlz4, gz. some are large 3gb. the files that contain data from mail zip are located in 9 different recup_dir. is there a way to assemble the takeout.zip file and make mail date readable, usable. ? ;)
If your file "takeout.zip" was not lost, just unpack that file at the location you want it to be.
huburt
#3 Post by huburt »
yes that is the problem, I have lost the .zip and now I will recreate it, but don't know how to.
I think I have all files recovered but they are in different format, all the files that I am aiming at her have the word
'tarkout' in them, so what commands du you run and which program to install?.
huburt wrote: 26 Apr 2024, 06:46 yes that is the problem, I have lost the .zip and now I will recreate it, but don't know how to.
There is no "tarkout" support in Photorec.
Use Windows Explorer or any zip programm to combine individual files into a zip archiv.
huburt
#5 Post by huburt »
thanks
that is what I experience, all attempts fail.
solved.
