Drive reports "Bad relative sector"
DOOMsayer
#1 Post by DOOMsayer »
I have a 320GB Samsung drive ,with 3 NTFS partitions on it (one of them has Windows installed on it)
Recently the drive has reported during boot "NTLDR is missing" ,so I went on to try and recover it.
I connected the disk as a slave to my Linux machine ,and TD gave me the following output:
Analyse Disk /dev/sdb - 320 GB / 298 GiB - CHS 38913 255 63
Geometry from i386 MBR: head=116 sector=50
BAD_RS LBA=1869771365 1093248
check_part_i386 1 type 69: no test
BAD_RS LBA=1701519481 5967333
check_part_i386 2 type 73: no test
BAD_RS LBA=2573 5967333
check_part_i386 3 type 74: no test
1 * Novell 116387 225 36 126888 82 1 168689522
Bad relative sector.
2 * Sys=73 105914 175 47 222309 108 57 1869881465
3 * Sys=74 0 40 54 0 40 53 0
Running both quick search ,and deep search ,gave me the below message:
Ask the user for vista mode
Computes LBA from CHS for Disk /dev/sdb - 320 GB / 298 GiB - CHS 38914 255 63
search_vista_part: 1
Can you suggest what can I do in order to restore the partitions?
Thanks,
Doom.
Re: Drive reports "Bad relative sector"
After Quick Search, try Deeper Search. If your partitions are found, rewrote the partition table.
