Restoring ExFat partition on SD from backup.
TQKez
#1 Post by TQKez »
Hi there, I'm resorting to asking here because I'm getting conflicting information from the testdisk PDF, the testdisk application, and Disk Utility in macOS.
A Sandisk Extreme 256GB microsd with some important drone footage went bad on me and I'm hoping to get at least some of it.
Disk Utility lists the partition correctly (256GB ExFAT), but wont mount it.
Diskutil List, lists it incorrectly as NTFS
/dev/disk5 (internal, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:     FDisk_partition_scheme                        *255.9 GB   disk5
   1:               Windows_NTFS                         255.8 GB   disk5s1
Testdisk says boot sector and backup sector bad, but I dont know if that's because it's incorrectly recognising an NTFS partition
Disk /dev/disk5 - 255 GB / 238 GiB - 499744768 sectors
 1 P HPFS - NTFS                65536  499744767  499679232
Status: Bad
Status: Bad
Sectors are not identical.
....because when I hit Analyse -> Quick Search, it *does* appear to find the backup sector, correctly identified as ExFAT with the correct size.
>* HPFS - NTFS                65536  499744767  499679232
     Enter: to continue
exFAT found using backup sector, blocksize=262144, 255 GB / 238 GiB
Furthermore I get this message. Is this likely to be true? It sounds spinning disk related.
Warning: the current number of heads per cylinder is 1
but the correct value may be 128.
You can use the Geometry menu to change this value.
It's something to try if
- some partitions are not found by TestDisk
- or the partition table can not be written because partitions overlap.
This message is the only thing giving me hope "exFAT found using backup sector, blocksize=262144, 255 GB / 238 GiB", how do I tell test disk to use it?
Re: Restoring ExFat partition on SD from backup.
TQKez wrote: 27 Nov 2024, 03:07 Hi there, I'm resorting to asking here because I'm getting conflicting information from the testdisk PDF, the testdisk application, and Disk Utility in macOS.
What is the conflicting information from the manual and the TestDisk application?
How do you know that the partition type is ExFAT?
[/quote]Have you changed the partition type information? [quote]
Status: Bad
Status: Bad
     Enter: to continue
Have you tried the p-key to list the files?
I don't know what "spinning disk related" means. Modern operating system do not use geometry information you can ignore that. Besides, that text tells you when to change geometry. Do those criteria apply in your case?
Please post your logfile.
TQKez
#3 Post by TQKez »
recuperation wrote: 27 Nov 2024, 12:45 What is the conflicting information from the manual and the TestDisk application?
I guess confusing is probably more accurate than conflicting. While section 7.4 correctly describes how to enact restoration of the backup sector (which i can't proceed with due to the backup sector being shown as bad in the Adavanced menu), the application is also telling me in the Analyse section that it has found an ExFAT partition using the backup sector, but no where do i see information on what i might be able to action on it.
Because it shows it right there in the screenshot "USB Internal Physical Volume ExFAT', and it has always been ExFAT, it has to be so both the drone and macOS can both write to it.
p-key does list some files, but not the ones i need, and they're in the only folder p-key shows which is .Trashes.
Directory /.Trashes/501
>-rwxr-xr-x     0     0  44002415  8-May-2024 12:33 DJI_0836.MOV
 -rwxr-xr-x     0     0 857147930  8-May-2024 12:35 DJI_0837.MOV
 -rwxr-xr-x     0     0 519008117  8-May-2024 12:51 DJI_0838.MOV
 -rwxr-xr-x     0     0 319054495  8-May-2024 12:52 DJI_0839.MOV
 -rwxr-xr-x     0     0 202506492  8-May-2024 12:53 DJI_0840.MOV
 -rwxr-xr-x     0     0 743513250  8-May-2024 12:54 DJI_0841.MOV
 -rwxr-xr-x     0     0 139051787  8-May-2024 12:55 DJI_0842.MOV
 -rwxr-xr-x     0     0 125509390  8-May-2024 12:55 DJI_0843.MOV
 -rwxr-xr-x     0     0 143002992  8-May-2024 12:55 DJI_0844.MOV
 -rwxr-xr-x     0     0 122085049  8-May-2024 12:56 DJI_0845.MOV
 -rwxr-xr-x     0     0 879509265  8-May-2024 12:57 DJI_0846.MOV
 -rwxr-xr-x     0     0 186509933  8-May-2024 12:58 DJI_0847.MOV
 -rwxr-xr-x     0     0  84829130  8-May-2024 13:00 DJI_0848.MOV
 -rwxr-xr-x     0     0 193281800  8-May-2024 13:00 DJI_0849.MOV
 -rwxr-xr-x     0     0 301736078  8-May-2024 13:01 DJI_0850.MOV
Thanks, thats what i thought, that heads and cylinders are related to spinning disks and not relevant to me.
Well it finds a partition, but it's not finding an ExFAT partition as I would hope. That suggests to me the possibility that my ExFAT partition may be found if I change the geometry. But i think you've explained that now.
UPDATE:
Well this time round i managed to change the partition type to ExFAT, then in Advanced it did list the backup sector as OK, so I selected BackupBS etc but it still doesnt mount.
I guess it's time to try PhotoRec and then call it a day.
TQKez
#4 Post by TQKez »
testdisk.log
(9.49 KiB) Downloaded 663 times
#5 Post by recuperation »
No, at least they apply to SSDs as well. But adressing using CHS-Information (cylinder, head, sector) is outdated. There is a linear numbering scheme called LBA (logical block adress). That is being used.
I would have continued even using "deep search" and would have checked all results.
If that fails, try out commercial software.
PhotoRec is the tool of last resort.
Good luck!
