Big problem, small solution?
Bassdude
#1 Post by Bassdude »
Hi everybody,
I seem to have a problem with the HDD of my laptop. One day it refused to boot windows, not even from CD. I won't get me to Windows Recovery. It did boot Knoppix 7.0 off a DVD, so I'm using that right now. It comes with Testdisk 6.13. It recognized two partitions but was able to mount only one, and that's not the one windows is installed on. I used Testdisk to recover my files to an external HDD (so a monumental MERCI BEAUCOUP to Mr. Grenier here!!!), which gave me no errors or anything (via analyze - quick search - list files - copy). The entire folder structure and all the data seems to be fine.
Then I did a 'deeper search' (via analyze - quick search - select partition, press enter - deeper search).
This gave me the following results:
During the search I got this...
HPFS - NTFS              0  32 33  1305 138 49   20971520 [BIOS_RVY]
  HPFS - NTFS           1305 138 50  1318  74 36     204800 [System]
  HPFS - NTFS           1318  74 37 37008  13 61  573356032 [OS_Install]
  HPFS - NTFS          37008  13 62 60801  47 46  382236672 [Data]
Invalid FAT boot sector
 0 D FAT16 >32M           140145 235  1 157446 222 34  277939780
This message underneath the partition list appeared about 83% into the search.
When it finished, it gave me this:
Disk /dev/sda - 500 GB / 465 GiB - CHS 60802 255 63
The harddisk (500 GB / 465 GiB) seems too small! (< 1295 GB / 1206 GiB)
[ Continue ]
142 GB / 132 GiB
What does all this mean? Should I somehow get it to rewrite the FAT boot sector?
Also, what I've noticed when I do a 'quick search'...
>D HPFS - NTFS              0  32 33  1305 138 49   20971520 [BIOS_RVY]
 D HPFS - NTFS           1305 138 50  1318  74 36     204800 [System]
 D HPFS - NTFS           1318  74 37 37008  13 61  573356032 [OS_Install]
 D HPFS - NTFS          37008  13 62 60801  47 46  382236672 [Data]
     Enter: to continue
NTFS, 10 GB / 10 GiB
...is that the partitions all have a D in front of them, meaning that they are deleted, which I never manually did.
What should I do to be able to boot windows normally again? I feel like it's not a hard problem, because I can still view and copy my files, and Testdisk shows the size of the disk correctly.
Any help would be greatly appreciated!
Bassdude
Re: Big problem, small solution?
#2 Post by Bassdude »
...anyone?
Bassdude
#3 Post by Bassdude »
Ah, I found out the MFT is corrupt:
Any suggestions?...
Bassdude
#4 Post by Bassdude »
Ok, nevermind then... I zerofilled the disk and reinstalled windows.
