How to check integrity of downloaded TestDisk zip file? Topic is solved
Thyroid
Re: How to check integrity of downloaded TestDisk zip file?
#11 Post by Thyroid »
1. I downloaded the file by clicking the big green button that says TestDisk 7.2, on the following page:
https://www.cgsecurity.org/wiki/TestDisk_Download
2. Name of the file: testdisk-7.2.win.zip
3. Length of the file: 27581226
4. I ran the command `openssl dgst -sha3-512 testdisk-7.2.win.zip`in a bash console, but you can also use the following site and see for yourself that the hash is not the same as the one you posted.
https://emn178.github.io/online-tools/s ... cksum.html
#12 Post by recuperation »
Thyroid wrote: 01 Feb 2025, 19:28 1. I downloaded the file by clicking the big green button that says TestDisk 7.2, on the following page:
Upon the first problem I wrote to you:
recuperation wrote: 01 Feb 2025, 15:54 Here are the hashes for the Win64-version 7.2, file size: 27.354.549
Am I demanding too much expecting that you tell me that your file size does not match mine?
When I speak about the "win64-version 7.2" didn't this raise a question for you that there are different versions around?
Maybe my expectations are inadequate.
I feel like I need to bang my head against the wall.
Please post your hash!
Thyroid
#13 Post by Thyroid »
96448b9ed41f9d7f62194727a337aa196b6136162be24e287086b1685e3bb9c210551140d53d9511af23584cd2889a0bbb1aacd2e8e5f8806bbce13f05241095
#14 Post by recuperation »
TestDisk is not a security application like Truecrypt or Veracrypt.
I strongly doubt that Christophe Grenier will modify the whole publication process so that the fast-changing 7.3-WIP will have hash files added upon.
If you fear virus contamination use virustotal.com to check your download or use
https://www.heise.de/download/product/t ... 3/download
The people at heise edition run antivirus software against the files that they download.
Keep in mind that cgsecurity.org is THE primary download source - everything else is secondary.
Here is my SHA3-512 hash for the file
with a length of
27.581.226 bytes:
96448B9ED41F9D7F62194727A337AA196B6136162BE24E287086B1685E3BB9C210551140D53D9511AF23584CD2889A0BBB1AACD2E8E5F8806BBCE13F05241095
Happy comparing!
Thyroid
#15 Post by Thyroid »
OK thanks.
