Can't open filesystem. Filesystem seems damaged
Post Reply
achalk
#1 Post by achalk »
Using NTFS and Windows 11. My drive is an external Buffalo In use for years. No problems. I get the above message when I try to fix the MBR. Advanced->Boot or Advanced->List TestDisk output from Boot is:
TestDisk 7.2, Data Recovery Utility, February 2024        Christophe GRENIER <grenier@cgsecurity.org>        https://www.cgsecurity.org        Disk \\.\PhysicalDrive1 - 3000 GB / 2794 GiB - CHS 364801 255 63        Partition                  Start        End    Size in sectors        1 P MS Data                     1024 5860532223 5860531200 [HD-LCU3]        Boot sector        Status: OK        Backup boot sector        Status: OK        Sectors are identical.        A valid NTFS Boot sector must be present in order to access        any data; even if the partition is not bootable.
It is as though data is there, but the instructions to read it are gone.
How do I fix this?
What do you need me to provide?
Thanks.
Post Reply
