Can My Partition/Hard Drive Be Recovered? "Filesystem seems damaged."
crashtech
#1 Post by crashtech »
(Edit: images are posted as links, hopefully this works better)
Hello, I'm hoping I can recover my external drive which has files important to me. Any help is appreciated.
OS: Debian 13 - Gnome
Hard Drive trying to recover: External USB HDD - 4TB WD MyBook - NTFS
What happened: The drive was always unmounted and safely removed before PC shutdowns or being disconnected. One day the pc was shutdown and the next day after boot the hard drive was inaccessible. The hard drive has over 3TB used. The drive still shows up it just can't be opened and Gnome file manager gives this message: https://ibb.co/jvvgYDYt
The irony is just purchased a hard drive to back it up and this happened before I could. I'm still hoping that I can, worst case there's space for a Photorec recovery. This "back up" hard drive is formatted as EXT4 and is being used but still has enough space to back up the failed hard drive. I worked from the failed hard drive because of how large the image file would be.
Here is the output from fdisk: https://ibb.co/dwH2ywpP
This is Quick Search in Testdisk:
https://ibb.co/LztrcKk9
https://ibb.co/1Jd89LgH
Next I tried to list the files and started a Deep Search:
https://ibb.co/Q31Wy21z
https://ibb.co/xqQF5QgW
https://ibb.co/ynDxCmCn
https://ibb.co/MDWpsynP
https://ibb.co/27MwpWbc
https://ibb.co/G3FR3wPs
https://ibb.co/tpLJcNr7
https://ibb.co/3xgTw3L
https://ibb.co/dscjCWyw
No files were listed:
https://ibb.co/7Jh2w6KV
Next I tried Rebuild Boot Sector:
https://ibb.co/7Jjp38gD
https://ibb.co/PzQNLVJx
https://ibb.co/1YgVfsZG
https://ibb.co/tpxwY2jD
Then tried to list the files again:
https://ibb.co/JwzHjmW3
Tried to change geometry:
https://ibb.co/Kc13k53N
https://ibb.co/N6cXY54Q
https://ibb.co/23b0tPh2
https://ibb.co/Jj6BN7KV
https://ibb.co/qLB1DdqN
Next another Deep Search and List Files:
https://ibb.co/FLfVphbv
https://ibb.co/35F1WJDw
https://ibb.co/6RC0kLjN
https://ibb.co/svgBLfTs
https://ibb.co/mCTftzGq
https://ibb.co/qMwF94BJ
https://ibb.co/5xGjwrQ3
https://ibb.co/2zh0KyX
After that I tried to repair the drive with fsck, but apparently it needs a symlink and/or dependencies to download?:
https://ibb.co/DHdmhBxR
Then I tried to rebuild the boot sector again:
https://ibb.co/My20tTNw
https://ibb.co/0yjLb94M
https://ibb.co/Z6pkzXhv
https://ibb.co/9mjP4ZsD
https://ibb.co/27Lgb13R
https://ibb.co/B2QN3VvY
I decided to stop here and ask for help before I accidentally ruin something.
https://ibb.co/MydTymwq
Re: Can My Partition/Hard Drive Be Recovered? "Filesystem seems damaged."
Quick answer: I don't know. This question cannot be answered.
You linked a lot of web locations instead of pictures. They are not show.
Please modify your posting and link the images files directly.
crashtech
#3 Post by crashtech »
The images are now links, hopefully this is better.
Could you post your TestDisk log file?
crashtech
#5 Post by crashtech »
Here is the testdisk log file:
Mon Mar  2 16:04:56 2026
OS: Linux, kernel 6.12.73+deb13-amd64 (#1 SMP PREEMPT_DYNAMIC Debian 6.12.73-1 (2026-02-17)) x86_64
Compiler: GCC 14.2
ext2fs lib: 1.47.2, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.5
User is not root!
Using locale 'en_US.UTF-8'.
Mon Mar  2 16:05:05 2026
Command line: TestDisk /debug
Compiler: GCC 14.2
/dev/sdb: LBA, LBA48, DCO support
/dev/sdb: size       976773168 sectors
/dev/sdb: user_max   976773168 sectors
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - HP Secure Hard D, FW:YXM7
Disk /dev/sdc - 4000 GB / 3725 GiB - CHS 476926 64 32, sector size=4096 - My Book 1230, FW:1065
Disk /dev/sdc - 4000 GB / 3725 GiB - My Book 1230
Analyse Disk /dev/sdc - 4000 GB / 3725 GiB - CHS 476926 64 32
BAD_RS LBA=256 132
NTFS at 0/8/1
heads/cylinder 255 (NTFS) != 64 (HD)
sect/track 63 (NTFS) != 32 (HD)
Warning: number of heads/cylinder mismatches 255 (NTFS) != 64 (HD)
Warning: number of sectors per track mismatches 63 (NTFS) != 32 (HD)
 1 P HPFS - NTFS              0   8  1 476926  55 32  976745984 [My Book]
NTFS at 0/8/1
filesystem size           976745984
sectors_per_cluster       1
mftmirr_lcn               488372991
clusters_per_mft_record   1
     NTFS, blocksize=4096, 4000 GB / 3725 GiB
Warning: the current number of heads per cylinder is 64 but the correct value may be 8.
   * HPFS - NTFS              0   8  1 476926  55 32  976745984 [My Book]
echo "0 7813967872 linear /dev/sdc 2048" | dmsetup create test0
$MFTMirr does not match $MFT (record 3).
Not an exFAT boot sector.
 1 * HPFS - NTFS              0   8  1 476926  55 32  976745984 [My Book]
NTFS at 0/8/1
BAD_RS LBA=1901241090 507239
     FAT32 LBA            928340  24  3 2680041  53 13 3587484586
This partition ends after the disk limits. (start=1901241090, size=3587484586, end=5488725676, disk end=976746240)
block_group_nr 5
recover_EXT2: "e2fsck -b 40961 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=5/39, s_mnt_count=4/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1992
recover_EXT2: s_blocks_count 319936
recover_EXT2: part_size 79984
Filesystem created: Sun Sep  9 08:27:22 2018
Last mount time:    Sun Sep  9 09:52:17 2018
     Linux                271221  15 32 271260  19 16      79984
     ext4 blocksize=1024 Large_file Sparse_SB Backup_SB, 327 MB / 312 MiB
BAD_RS LBA=5035191068 1399259
     FAT16 <32M           2458589  24 29 3443134   8 10 2016347629
This partition ends after the disk limits. (start=5035191068, size=2016347629, end=7051538697, disk end=976746240)
The hard disk (4000 GB / 3725 GiB) seems too small! (< 28 TB / 26 TiB)
echo "0 639874 linear /dev/sdc 4443688958" | dmsetup create test1
interface_load
BAD_RS LBA=256 132
NTFS at 0/8/1
ntfs_boot_sector
NTFS at 0/8/1
NTFS at 0/8/1
Status: OK
Status: OK
Sectors are identical.
Invalid location of MFT or MFTMirr.
rebuild_NTFS_BS
mft at 488372991
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn             786432
ntfs_find_mft: mftmirr_lcn         0
ntfs_find_mft: mft_record_size     4096
mft at 786432
ntfs_find_mft: sectors_per_cluster 1
ntfs_find_mft: mft_record_size     4096 bytes
ntfs_find_mft: index_block_size    4096
             New / Current boot sector
filesystem size           976745984 976745984
sectors_per_cluster       1 1
mft_lcn                   786432 786432
mftmirr_lcn               0 488372991
clusters_per_mft_record   1 1
clusters_per_index_record 1 1
ntfs_boot_sector
NTFS at 0/8/1
NTFS at 0/8/1
Status: OK
Status: OK
BAD_RS LBA=256 132
NTFS at 0/8/1
New geometry
Disk /dev/sdc - 4000 GB / 3725 GiB - CHS 3815415 8 32 sector_size=4096
Analyse Disk /dev/sdc - 4000 GB / 3725 GiB - CHS 3815415 8 32
BAD_RS LBA=256 132
NTFS at 1/0/1
heads/cylinder 255 (NTFS) != 8 (HD)
Warning: number of heads/cylinder mismatches 255 (NTFS) != 8 (HD)
 1 P HPFS - NTFS              1   0  1 3815414   7 32  976745984 [My Book]
NTFS at 1/0/1
   * HPFS - NTFS              1   0  1 3815414   7 32  976745984 [My Book]
 1 * HPFS - NTFS              1   0  1 3815414   7 32  976745984 [My Book]
BAD_RS LBA=256 132
NTFS at 1/0/1
NTFS at 1/0/1
NTFS at 1/0/1
BAD_RS LBA=558903295 199705
     FAT12                2183215   7 32 4146332   1 30  502557758
This partition ends after the disk limits. (start=558903295, size=502557758, end=1061461053, disk end=976746240)
BAD_RS LBA=3907381373 65326
     FAT32 LBA            15263208   3 30 18923946   1  3  937148837
This partition ends after the disk limits. (start=3907381373, size=937148837, end=4844530210, disk end=976746240)
BAD_RS LBA=414142931 142957
     FAT16 >32M           1617745   6 20 4524180   4 29  744047305
This partition ends after the disk limits. (start=414142931, size=744047305, end=1158190236, disk end=976746240)
BAD_RS LBA=1901241090 64615
     FAT32 LBA            7426723   0  3 21440334   5 13 3587484586
BAD_RS LBA=530697536 75956
     FAT32 LBA            2073037   2  1 14414291   0 24 3159360983
This partition ends after the disk limits. (start=530697536, size=3159360983, end=3690058519, disk end=976746240)
BAD_RS LBA=4066788187 101653
     FAT16 >32M           15885891   2 28 17324670   4 20  368327480
This partition ends after the disk limits. (start=4066788187, size=368327480, end=4435115667, disk end=976746240)
block_group_nr 5
     Linux                2169769   7 32 2170082   3 16      79984
block_group_nr 5
     Linux                2169770   0  1 2170082   3 16      79984
recover_EXT2: s_block_group_nr=0/39, s_mnt_count=66/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1992
Last mount time:    Sat Sep  1 07:56:35 2018
     Linux                2172259   1  1 2172571   4 16      79984
     ext4 blocksize=1024 Large_file Sparse_SB Recover, 327 MB / 312 MiB
BAD_RS LBA=625956416 32
     FAT16 LBA            2445142   2  1 2460894   0 31    4032479
BAD_RS LBA=2406796979 43756
     FAT32 LBA            9401550   5 20 19954997   3  9 2701682358
This partition ends after the disk limits. (start=2406796979, size=2701682358, end=5108479336, disk end=976746240)
BAD_RS LBA=3916939498 165493
     FAT16 <32M           15300544   7 11 29108425   0 23 3534817324
This partition ends after the disk limits. (start=3916939498, size=3534817324, end=7451756822, disk end=976746240)
BAD_RS LBA=2410531324 230771
     HPFS - NTFS          9416137   7 29 14736086   3 15 1361906802
This partition ends after the disk limits. (start=2410531324, size=1361906802, end=3772438126, disk end=976746240)
BAD_RS LBA=2403092623 19501
     FAT32 LBA            9387080   4 16 10396743   5 27  258473771
This partition ends after the disk limits. (start=2403092623, size=258473771, end=2661566394, disk end=976746240)
BAD_RS LBA=5035191068 180699
     FAT16 <32M           19668715   0 29 27545073   0 10 2016347629
BAD_RS LBA=1470527848 46351
     FAT12                5744249   3  9 15806053   7 30 2575821973
This partition ends after the disk limits. (start=1470527848, size=2575821973, end=4046349821, disk end=976746240)
NTFS at 3815414/7/32
     NTFS found using backup sector, blocksize=4096, 4000 GB / 3725 GiB
The hard disk (4000 GB / 3725 GiB) seems too small! (< 30 TB / 27 TiB)
     Linux                2169770   0  1 2170082   7 32      80128
     ext4 blocksize=1024 Large_file Sparse_SB Backup_SB, 328 MB / 313 MiB
     Linux                2172259   1  1 2172571   7 32      80096
     ext4 blocksize=1024 Large_file Sparse_SB Recover, 328 MB / 312 MiB
     FAT16 LBA            2445142   2  1 2460894   0 32    4032480
echo "0 641024 linear /dev/sdc 4443688960" | dmsetup create test2
echo "0 640768 linear /dev/sdc 4448786688" | dmsetup create test3
echo "0 32259840 linear /dev/sdc 5007651328" | dmsetup create test4
dir_partition inode=2
ext2fs_dir_iterate failed with error 2133571354.
dir_partition inode=0
FAT: Can't list files, bad cluster size.
BAD_RS LBA=256 132
NTFS at 1/0/1
ntfs_boot_sector
NTFS at 1/0/1
NTFS at 1/0/1
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 1/0/1
NTFS at 1/0/1
Status: OK
Status: OK
rebuild_NTFS_BS
mft at 488372991
mft at 786432
ntfs_boot_sector
NTFS at 1/0/1
NTFS at 1/0/1
Status: OK
Status: OK
#6 Post by recuperation »
TestDisk cannot open the partition located at 1/0/1.
There is a least one issue with the location of the MFT as the location in the NTFS boot sector differs from the NTFS mirror.
What you could try out is to clone your disk using ddrescue as described in the manual.
Keep in mind that your disk has a sector size of 4096 bytes . This is an important information that may be needed later on.
The partition data (not the content) of the found partition
looks plausible but the partition contains at least one error according to the log file:
"$MFTMirr does not match $MFT (record 3)."
You could then try out if overwriting the current information about the MFT location from the information in the so-called MFT mirror heals the problem.
Select your partition and go to Advanced/Boot/Repair MFT.
In order to changes taking effect you need to be root user - you did not operate TestDisk in root mode so far.
You could then try out to look into the partition(s) found again.
I don't know if TestDisk needs disconnecting and reconnecting the failing external disk or even a restart after this repair. I would let TestDisk do the repair, exit TestDisk, disconnect the disk, reconnect and start TestDisk again.
When creating a new log file it should not contain the line
"$MFTMirr does not match $MFT (record 3)." anymore.
Then try TestDisk again using the p-key ("list files").
If that fails use commercial recovery software and try out those products.
If they fail, use PhotoRec as the last line of defense.
crashtech
#7 Post by crashtech »
I appreciate the help so far, it will take me a while to try this so I have a few questions before I start this process.
If I remember correctly I started TestDisk as:"testdisk" but then with sudo as prompted by TestDisk, I think it shows in the log. Do I need to run "su" first and then run "testdisk"?
Do you think it's worth trying to repair either the clone or actual drive with fsck?
Should I analyze the disk again or go straight to trying to repair MFT?
After repairing MFT and I reconnect and start TestDisk again do I analyze the disk?
After the MFT repair I'm assuming that if the files are listed then I restore the partition or filesystem with TestDisk?
This might too far away but assuming that the MFT repair works on the clone should I backup the clone or would it better to apply the repair to the drive and backup it up? I would like to eventually format that drive to EXT4 if that helps.
Any recommendations on what commercial software to use?
#8 Post by recuperation »
crashtech wrote: 12 Mar 2026, 04:19 I appreciate the help so far, it will take me a while to try this so I have a few questions before I start this process.
Use "sudo" as its always available.
Just follow the advice already given.
You need to try out if TestDisk can list files within the currently broken partition then.
Read here to learn how to reach that point:
There is nothing to restore. You are trying to repair the content of an already existing partition that contained a NTFS file system.
I don't know what you mean by "restore".
See what the MFT repair gives. I don't want to answer lots of questions ahead.
crashtech
#9 Post by crashtech »
This is an update:
I used ddrescue to clone the disk to another drive as an image file, it only has been one pass. Since it was the first pass I didn't use the -r option. There were zero errors.
Just to be cautious a few questions before moving on:
Since there were no errors there is no reason to for additional passes with ddrescue, correct?
Should I next attempt to repair or overwrite the MFT with TestDisk on the image file?
This is the logfile from ddrescue:
# Mapfile. Created by GNU ddrescue version 1.29
# Command line: ddrescue -d /dev/sdb mybook.img mybook.logfile
# Start time:   2026-03-20 16:26:25
# Current time: 2026-03-21 04:01:07
# Finished
# current_pos  current_status  current_pass
0x3A37F6F0000     +               1
#      pos        size  status
0x00000000  0x3A37F700000  +
This is a screenshot:
ddrescue mybook.jpg (40.96 KiB) Viewed 81404 times
#10 Post by recuperation »
crashtech wrote: 22 Mar 2026, 01:46 Since there were no errors there is no reason to for additional passes with ddrescue, correct?
Yes.
Post Reply
