Trouble creating custom signature
moosington
#1 Post by moosington »
I'm trying to recover some of my wife's school files off her usb stick and I'm having trouble with creating a custom signature. The file is a .cxm and from the hex editor the first line is this:
------------------------------------------CPS EXPORT SECTION type=1 name=Mac
so for the photorec.sig file i was using this:
cxm 0 "------------------------------------------CPS"
when i run fidentity it comes up as a text file:
Documents/database.cxm: txt
and I'm not sure what im doing wrong, any ideas are greatly appreciated. Thanks!
stumpyuk
Re: Trouble creating custom signature
#2 Post by stumpyuk »
You would be better of using the string "CPS EXPORT SECTION" as your signature. Count the number of "-" characters before the string and use the start of the string as your file offset, so if there were 20 "-" characters before "CPS EXPORT SECTION", your custom signature would be:
cxm 19 "CPS EXPORT SECTION"
That should work, assuming there are consistently 20 hyphen characters at the start of the cxm file.
moosington
#3 Post by moosington »
thanks i'll give it a shot
