HDD - 1TB now 32MB RAW partition
itchy
#1 Post by itchy »
after shifting a lot my HDDs in the system, probably caused by SATA cable not plugged all the way, my disk (WD1001FALS) is unreadable in windows, which now ask me to reformat it.
I ran testdisk (log attached), and what i understand the CHS is not correctly set, disk should have CHS(121601, 255,63). Tried to change the CHS in testdisk, but the changes were never applied.
im no expert, could you help me to identify the steps needed to recover this disk? I hope wont need to restore data to a different disk, as this one is my only big disk.
Thank you, Petr
[scroll]{
Sat Sep 29 20:32:19 2012
Compilation date: 2012-09-22T12:26:25
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=33348608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=33348608
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255953207296
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=33348608
Disk /dev/sda - 33 MB / 31 MiB - CHS 4 255 63, sector size=512 - WDC WD10 01FALS-00J7B, S/N:W -DMWTA3V393331, FW:05.0
Disk /dev/sdb - 256 GB / 238 GiB - CHS 117508 224 19, sector size=512 - OCZ-VERT EX4, S/N:CO-Z786X5X828EBT4TBV, FW:1.5
Disk /dev/sda - 33 MB / 31 MiB - WDC WD10 01FALS-00J7B
Analyse Disk /dev/sda - 33 MB / 31 MiB - CHS 4 255 63
NTFS at 0/32/33
NTFS: Can't read MFT
 1 P HPFS - NTFS              0  32 33 121600 247 55 1953517568
Warning: Bad ending cylinder (CHS and LBA don't match)
NTFS at 0/32/33
filesystem size           1953517568
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
file_pread(4,4096,buffer,6293504(391/191/57)) lseek err Invalid argument
file_pread(4,1,buffer,6293504(391/191/57)) lseek err Invalid argument
This partition ends after the disk limits. (start=2048, size=1953517568, end=1953519615, disk end=65134)
file_pread(4,2,buffer,65536(4/20/17)) lseek err Invalid argument
file_pread(4,1,buffer,65536(4/20/17)) lseek err Invalid argument
file_pread(4,2,buffer,66308(4/32/33)) lseek err Invalid argument
file_pread(4,1,buffer,66308(4/32/33)) lseek err Invalid argument
file_pread(4,2,buffer,66371(4/33/33)) lseek err Invalid argument
file_pread(4,1,buffer,66371(4/33/33)) lseek err Invalid argument
file_pread(4,15,buffer,65537(4/20/18)) lseek err Invalid argument
file_pread(4,3,buffer,65552(4/20/33)) lseek err Invalid argument
file_pread(4,3,buffer,65599(4/21/17)) lseek err Invalid argument
file_pread(4,8,buffer,65615(4/21/33)) lseek err Invalid argument
file_pread(4,11,buffer,65662(4/22/17)) lseek err Invalid argument
file_pread(4,2,buffer,67584(4/52/49)) lseek err Invalid argument
Hint: update Windows to support LBA48 (minimum: W2K SP4 or XP SP1)The harddisk (33 MB / 31 MiB) seems too small! (< 1000 GB / 931 GiB)
NTFS at 0/32/33
mftmirr_lcn               2
file_pread(4,2,buffer,65219(4/15/15)) lseek err Invalid argument
file_pread(4,2,buffer,65282(4/16/15)) lseek err Invalid argument
file_pread(4,2,buffer,65345(4/17/15)) lseek err Invalid argument
file_pread(4,1,buffer,65535(4/20/16)) lseek err Invalid argument
}[/scroll]
itchy
Re: HDD - 1TB now 32MB RAW partition
#2 Post by itchy »
update:
ran testdisk as admin in win7 and was able to change the CHS values.
test disk dosnt allow me to list files (filesyste corrupted)
displaying MBR shows some data in the boot sector, and no values in backup boot sector. so copying from backkup doesnt make sense, and copying boot sector to backup doesnt work.
after restart the chs values are back to the incorrect values. log bellow.
can tetdisk still help here?
thank you
scroll]{
Tue Oct  2 20:34:08 2012
New geometry
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63 sector_size=512
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/32/33
Error reading $MFT: Input/Output error.
ntfs_mft_load(): Failed.
NTFS at 0/32/33
mftmirr_lcn               2
file_pread(4,8,buffer,1953519616(121600/247/56)) lseek err Invalid argument
file_pread(4,8,buffer,1953519624(121600/248/1)) lseek err Invalid argument
file_pread(4,3,buffer,1953519632(121600/248/9)) lseek err Invalid argument
file_pread(4,3,buffer,1953519679(121600/248/56)) lseek err Invalid argument
file_pread(4,8,buffer,1953519695(121600/249/9)) lseek err Invalid argument
file_pread(4,11,buffer,1953519742(121600/249/56)) lseek err Invalid argument
file_pread(4,2,buffer,1953521664(121601/25/25)) lseek err Invalid argument
   * HPFS - NTFS              0  32 33 121600 247 55 1953517568
interface_load
file_pread(4,1,buffer,6293505(391/191/58)) lseek err Invalid argument
Not an exFAT boot sector.
 1 * HPFS - NTFS              0  32 33 121600 247 55 1953517568
NTFS at 0/32/33
mftmirr_lcn               2
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
file_pread(4,1,buffer,1953519615(121600/247/55)) lseek err Invalid argument
filesystem size           1953517568 1
sectors_per_cluster       8 0
mft_lcn                   786432 0
mftmirr_lcn               2 0
clusters_per_mft_record   -10 0
clusters_per_index_record 1 0
Status: OK
ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
file_pread(4,2,buffer,976760812(60800/139/56)) lseek err Invalid argument
file_pread(4,1,buffer,976760814(60800/139/58)) lseek err Invalid argument
file_pread(4,1,buffer,976760815(60800/139/59)) lseek err Invalid argument
file_pread(4,1,buffer,976760816(60800/139/60)) lseek err Invalid argument
file_pread(4,1,buffer,976760817(60800/139/61)) lseek err Invalid argument
file_pread(4,1,buffer,976760818(60800/139/62)) lseek err Invalid argument
file_pread(4,1,buffer,976760819(60800/139/63)) lseek err Invalid argument
file_pread(4,1,buffer,976760820(60800/140/1)) lseek err Invalid argument
file_pread(4,1,buffer,976760821(60800/140/2)) lseek err Invalid argument
file_pread(4,1,buffer,976760822(60800/140/3)) lseek err Invalid argument
file_pread(4,1,buffer,976760823(60800/140/4)) lseek err Invalid argument
file_pread(4,1,buffer,976760824(60800/140/5)) lseek err Invalid argument
file_pread(4,1,buffer,976760825(60800/140/6)) lseek err Invalid argument
file_pread(4,1,buffer,976760826(60800/140/7)) lseek err Invalid argument
file_pread(4,1,buffer,976760827(60800/140/8)) lseek err Invalid argument
file_pread(4,1,buffer,976760828(60800/140/9)) lseek err Invalid argument
file_pread(4,1,buffer,976760829(60800/140/10)) lseek err Invalid argument
file_pread(4,1,buffer,976760830(60800/140/11)) lseek err Invalid argument
file_pread(4,1,buffer,976760831(60800/140/12)) lseek err Invalid argument
file_pread(4,1,buffer,976760832(60800/140/13)) lseek err Invalid argument
file_pread(4,1,buffer,976760833(60800/140/14)) lseek err Invalid argument
file_pread(4,1,buffer,976760834(60800/140/15)) lseek err Invalid argument
file_pread(4,1,buffer,976760835(60800/140/16)) lseek err Invalid argument
file_pread(4,1,buffer,976760836(60800/140/17)) lseek err Invalid argument
file_pread(4,1,buffer,976760837(60800/140/18)) lseek err Invalid argument
file_pread(4,1,buffer,976760838(60800/140/19)) lseek err Invalid argument
file_pread(4,1,buffer,976760839(60800/140/20)) lseek err Invalid argument
file_pread(4,1,buffer,976760840(60800/140/21)) lseek err Invalid argument
file_pread(4,1,buffer,976760841(60800/140/22)) lseek err Invalid argument
file_pread(4,1,buffer,976760842(60800/140/23)) lseek err Invalid argument
file_pread(4,1,buffer,976760843(60800/140/24)) lseek err Invalid argument
file_pread(4,1,buffer,976760844(60800/140/25)) lseek err Invalid argument
file_pread(4,1,buffer,976760845(60800/140/26)) lseek err Invalid argument
file_pread(4,1,buffer,976760846(60800/140/27)) lseek err Invalid argument
file_pread(4,1,buffer,976760847(60800/140/28)) lseek err Invalid argument
file_pread(4,1,buffer,976760848(60800/140/29)) lseek err Invalid argument
file_pread(4,1,buffer,976760849(60800/140/30)) lseek err Invalid argument
file_pread(4,1,buffer,976760850(60800/140/31)) lseek err Invalid argument
file_pread(4,1,buffer,976760851(60800/140/32)) lseek err Invalid argument
file_pread(4,1,buffer,976760852(60800/140/33)) lseek err Invalid argument
file_pread(4,1,buffer,976760853(60800/140/34)) lseek err Invalid argument
mft at 16, seq=1, main=0 res=1
ntfs_find_mft: mft_lcn             786432
ntfs_find_mft: mftmirr_lcn         2
ntfs_find_mft: mft_record_size     1024
file_pread(4,2,buffer,6293514(391/192/4)) lseek err Invalid argument
file_pread(4,1,buffer,6293514(391/192/4)) lseek err Invalid argument
NTFS Can't read "root directory" in MFT
ntfs_boot_sector
NTFS at 0/32/33
mft_lcn                   786432 0
mftmirr_lcn               2 0
Status: OK
Status: Bad
New options :
 Dump : No
 Align partition: Yes
 Expert mode : Yes
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
mft_lcn                   786432 0
mftmirr_lcn               2 0
Status: OK
Status: Bad
copy original boot sector over backup boot
file_pwrite(4,1,buffer,1953519615(121600/247/55)) seek err Invalid argument
Write error: Can't overwrite NTFS backup boot sector
ntfs_boot_sector
NTFS at 0/32/33
mft_lcn                   786432 0
mftmirr_lcn               2 0
Status: OK
Status: Bad
}[/scroll]
